    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
      pastormingle @mumblebaj
      @mumblebaj do you have an example of your config?
      P mumblebajM 2 Replies Last reply
        pastormingle @pastormingle
        @pastormingle I sent my weather module to use the same as the clock position but still nothing…
        • mumblebajM
          mumblebaj Module Developer @pastormingle
          @pastormingle I used one of the default.
                      module: 'MMM-Carousel',
                          transitionInterval: 10000,
                          ignoreModules: [],
                          mode: 'positional',
                          top_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 15000},
                          top_right: {enabled: true, ignoreModules: ['currentweather']}
          Just tested the Global option and it works fine and rotates all the modules one by one.
          Here is the config for global
                          ignoreModules: ['clock'],
                          mode: 'global'
          P 1 Reply Last reply
            @mumblebaj hum… this is my config…
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
             * see https://docs.magicmirror.builders/getting-started/configuration.html#general
             * and https://docs.magicmirror.builders/modules/configuration.html
            let config = {
            	address: "localhost", 	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
            	language: "en",
            	locale: "en-US",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "US Holidays",
            						symbol: "calendar-check",
            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
            			module: "compliments",
            			position: "lower_third"
            			module: "weather",
            				type: "current",
            				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				apiKey: "YOUR_OPENWEATHER_API_KEY"
            			module: "weather",
            			header: "Weather Forecast",
            				type: "forecast",
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
                            ignoreModules: [],
                            mode: 'global'
            mumblebajM S 2 Replies Last reply
            • mumblebajM
              @pastormingle Are there any errors where you start the mirror? I.e. if you do npm start are there any errors in the terminal window or if you use pm2 you can check the pm2 logs. You can also check the Developer Console, do shift_ctrl + i and select the console tab. See if there are any errors there. If no errors you should see something like the below, modules suspended…module resumed
              P 2 Replies Last reply
                sdetweil @pastormingle
                @pastormingle please use code block around config info
                  mumblebajM 1 Reply Last reply
                    pastormingle @sdetweil
                    @sdetweil not sure what that means?
                    • mumblebajM
                      @pastormingle That means that something is already running with that IP. Do you only have 1 instance of MM running?
                        @mumblebaj The IP conflict is due to me ssh into the pi and starting magic mirror… I am referring to the commits from sdetweil that said “please use code block around config info” So still not working… But it looks like the carousel module is working…
                        • mumblebajM
                          @pastormingle What Sam was saying was the when posting your config, you need to set it in a code block. That is done by selecting the config you posted and then pressing the </> button at the top of the window. That would wrap the config in a code block and make it look “pretty”.
                          I am glad your Carousel is now working.
                          P S 2 Replies Last reply
                            @mumblebaj sorry mumblebaj that was a typo it’s not working… Any other suggestions?
                              @mumblebaj
                              /* Magic Mirror Config Sample
                              * MIT Licensed.
                              let config = {
                                 port: 8080,
                                 language: "en",
                                 locale: "en-US",
                                 timeFormat: 24,
                                 units: "metric",
                                 		module: "alert",
                                 		position: "top_bar"
                                 		module: "clock",
                                 		module: "newsfeed",
                                 			feeds: [
                                             transitionInterval: 1000,
                                             ignoreModules: [],
                                             mode: 'global'
                              • mumblebajM
                                @pastormingle As mentioned previously, are the any errors in the developers window? Do you have any errors in the terminal window? I am using the exact same config as you for Carousel and it work just fine for me
                                  sdetweil @mumblebaj
                                  @mumblebaj said in MMM-Carousel not displaying:
                                  not pretty, just more readable
                                    sdetweil @mumblebaj
                                    @mumblebaj yes, generally, w package.json you would need an npm install. but in this case, the dependencies after for testing not running
                                      @sdetweil ```
                                      Here is what is in my developer window under the console tab… I don’t see anything that stands out.
                                      loader.js:164 Translations loaded for: clock
                                      loader.js:184 Load script: modules/default/calendar/calendar.js
                                      module.js:501 Check MagicMirror version for module ‘calendar’ - Minimum version: 2.1.0 - Current version: 2.16.0
                                      module.js:503 Version is ok!
                                      module.js:509 Module registered: calendar
                                      loader.js:155 Bootstrapping module: calendar
                                      loader.js:244 File already loaded: moment.js
                                      loader.js:160 Scripts loaded for: calendar
                                      loader.js:203 Load stylesheet: modules/default/calendar/calendar.css
                                      loader.js:244 File already loaded: font-awesome.css
                                      loader.js:162 Styles loaded for: calendar
                                      loader.js:164 Translations loaded for: calendar
                                      loader.js:184 Load script: modules/default/compliments/compliments.js
                                      module.js:509 Module registered: compliments
                                      loader.js:155 Bootstrapping module: compliments
                                      loader.js:160 Scripts loaded for: compliments
                                      loader.js:162 Styles loaded for: compliments
                                      loader.js:164 Translations loaded for: compliments
                                      loader.js:184 Load script: modules/default/newsfeed/newsfeed.js
                                      module.js:509 Module registered: newsfeed
                                      loader.js:155 Bootstrapping module: newsfeed
                                      loader.js:160 Scripts loaded for: newsfeed
                                      loader.js:203 Load stylesheet: modules/default/newsfeed/newsfeed.css
                                      loader.js:162 Styles loaded for: newsfeed
                                      loader.js:164 Translations loaded for: newsfeed
                                      loader.js:184 Load script: modules/MMM-Carousel/MMM-Carousel.js
                                      module.js:501 Check MagicMirror version for module ‘MMM-Carousel’ - Minimum version: 2.3.0 - Current version: 2.16.0
                                      module.js:509 Module registered: MMM-Carousel
                                      loader.js:155 Bootstrapping module: MMM-Carousel
                                      loader.js:160 Scripts loaded for: MMM-Carousel
                                      loader.js:203 Load stylesheet: modules/MMM-Carousel/MMM-Carousel.css
                                      loader.js:162 Styles loaded for: MMM-Carousel
                                      loader.js:164 Translations loaded for: MMM-Carousel
                                      loader.js:203 Load stylesheet: css/custom.css
                                      :8080/modules/default/alert/alert.js:165 Starting module: alert
                                      :8080/modules/defaul…enotification.js:21 Starting module: updatenotification
                                      :8080/modules/default/clock/clock.js:46 Starting module: clock
                                      :8080/modules/defaul…ndar/calendar.js:87 Starting module: calendar
                                      :8080/modules/defaul…s/compliments.js:38 Starting module: compliments
                                      :8080/modules/defaul…feed/newsfeed.js:63 Starting module: newsfeed
                                      main.js:499 All modules started!
                                      9
                                      XHR finished loading: GET “”.
                                        @sdetweil I tried to manual run the MMM-Carousel.js but returned the following. 20bc915c-97a4-40af-9e49-7932576b932b-image.png MMM-c93303dc-dee4-475f-9a04-d0f51fd8b8f2-image.png
                                          @pastormingle don’t know why you would do that. it has to run under MagicMirror…
                                          • mumblebajM
                                            @pastormingle Do you see any of the module suspended or module resumed stuff?
                                            • 2 / 5
