    MMM-Carousel w/ Slide Navigation
    1 Posts 1 Posters 222 Views 1 Watching
    • kusselinK Offline
      kusselin
      Hi all, I installed the MMM-Carousel w/ Slide Navigation module…but now it doesn’t show me the “Slides”…here’s my config:
                  module: 'MMM-Carousel',
                      transitionInterval: 45000,
                      showPageIndicators: true,
                      showPageControls: true,
                      ignoreModules: ['clock', 'alert', 'calendar', 'MMM-Fuel', 'MMM-OpenmapWeather', 'weatherforecast', 'newsfeed', 'compliments', 'MMM-Tools', 'MMM-Traffic'],
                      mode: 'slides',
                      slides: {
                          main: ['calendar', 'compliments', 'currentweather'],
                          "Slide 2": ['MMM-PublicTransportHafas', 'MMM-Formula1'],
                          "Slide 3": ['MMM-COVID19-AMPEL', 'MMM-Tankerkoenig', 'MMM-ioBroker', 'MMM-SoccerLiveScore']
      Can you please explain what I am doing wrong?
      I only have a small display and I just want to be able to display the other modules one after the other with the slides.
      About eien feedback thank you very much.
      Greetings
      pi@raspberrypi:~/MagicMirror $ npm run config:check
      > magicmirror@2.17.1 config:check /home/pi/MagicMirror
      > node js/check_config.js
      [23.12.2021 15:16.43.363] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
      [23.12.2021 15:16.43.969] [INFO]  Your configuration file doesn't contain syntax errors :)
