    MMM-awesom-alexa
    13 Posts 2 Posters 3.9k Views 2 Watching
    • ToramanderlerT Offline
      Toramanderler
      hello i was trying to install magic mirror awesome alexa module but config-helper is not working i get the following output
        sdetweil @Toramanderler
        @toramanderler did u do the npm install in the module folder per the instructions?
        ToramanderlerT 1 Reply Last reply Reply Quote 0
          Toramanderler @sdetweil
          yes, first I tried to install it myself, when I got the same result, I bought it as an automatic package. Source: https://github.com/freedomwebtech/Magic-Mirror-Alexa
            @toramanderler i don’t know about that link
            anyhow… I copied the steps in the wiki and made a script
            https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
            download, mark executable,
            erase the MagicMirror/modules/MMM-AwesomeAlexa folder
            then run the script…
            i didn’t write the steps… just made a script of the steps…
            so far its worked every time, on every platform I’ve used it on.
            as for Alexa, see this , amazon really doesn’t care
            https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
            ToramanderlerT 2 Replies Last reply Reply Quote 0
              @sdetweil I have started the download now. my main goal is Turkish assistant, but no voice control module supports Turkish. I’m just at the beginning of the road trying to understand how things are progressing. I think I can set up a smart home system more easily with alexa. I wanted my internship from Alexa, if there is any other module you can suggest, I can evaluate it.
                Toramanderler @Toramanderler
                  @sdetweil failed but thank you for your effort
                    @toramanderler there will be lots of errors. only the end matters.
                    cannot read screen shot.
                    use ssh and then u can copy paste text.
                    u cannot control devices any more. azon requires your Alexa ‘device’ to pass security audit, and execute exactly like Alexa on echo.
                      @sdetweil sam thank you for taking care of me i have been trying to install this module for 2 days. If I can’t manage my devices, there’s no point in using it. Is there another module you can recommend? I will be able to use spotify, turn the lights on and off, and most importantly, talk and get things done.
                        An unhandled error occurred inside electron-rebuild
                        node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy'.
                        For more information, rerun with the DEBUG environment variable set to "electron-rebuild".
                        Error: `make` failed with exit code: 2
                        Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy'.
                            at NodeGyp.rebuildModule (/home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy/node_modules/electron-rebuild/lib/src/module-type/node-gyp.js:117:19)
                            at processTicksAndRejections (node:internal/process/task_queues:96:5)
                            at async ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy/node_modules/electron-rebuild/lib/src/module-rebuilder.js:94:9)
                            at async ModuleRebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy/node_modules/electron-rebuild/lib/src/module-rebuilder.js:124:14)
                            at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:145:13)
                            at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:108:17)
                            at async /home/pi/MagicMirror/modules/MMM-awesome-alexa/snowboy/node_modules/electron-rebuild/lib/src/cli.js:154:9
