Solved v2.18.0 update gave black screen, then nothing.
@richard238 Just google update npm and update node. Once those are updated then you can do the rest. Uninstall mysql and run npm install in the MMM-MysqlQuery folder. Hopefully that will resolve the issues.
Ok, step one completed and looking much more up-to-date:
pi@magicmirror:~ $ npm -v 8.3.0 pi@magicmirror:~ $ node -v v17.3.0
And step two:
pi@magicmirror:~/MagicMirror $ npm uninstall mysql up to date, audited 758 packages in 10s 66 packages are looking for funding run `npm fund` for details found 0 vulnerabilities
pi@magicmirror:~/MagicMirror $ cd modules/MMM-MysqlQuery pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm install npm ERR! code ERESOLVE npm ERR! ERESOLVE unable to resolve dependency tree npm ERR! npm ERR! While resolving: mmm-mysqlquery@1.0.0 npm ERR! Found: stylelint@8.4.0 npm ERR! node_modules/stylelint npm ERR! dev stylelint@"^8.3.0" from the root project npm ERR! npm ERR! Could not resolve dependency: npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0 npm ERR! node_modules/grunt-stylelint npm ERR! dev grunt-stylelint@"latest" from the root project npm ERR! npm ERR! Fix the upstream dependency conflict, or retry npm ERR! this command with --force, or --legacy-peer-deps npm ERR! to accept an incorrect (and potentially broken) dependency resolution. npm ERR! npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-01-06T12_51_27_088Z-debug-0.log pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $
@richard238 can you check if package-lock.json exist. if it does delete it
rm package-lock.json
then try again. Also, did you do the uninstall in the MagicMirror folder first? -
Yes, I did.pi@magicmirror:~ $ sudo rm package-lock.json pi@magicmirror:~ $ cd ~/MagicMirror pi@magicmirror:~/MagicMirror $ cd modules/MMM-MysqlQuery pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm install npm ERR! code ERESOLVE npm ERR! ERESOLVE unable to resolve dependency tree npm ERR! npm ERR! While resolving: mmm-mysqlquery@1.0.0 npm ERR! Found: stylelint@8.4.0 npm ERR! node_modules/stylelint npm ERR! dev stylelint@"^8.3.0" from the root project npm ERR! npm ERR! Could not resolve dependency: npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0 npm ERR! node_modules/grunt-stylelint npm ERR! dev grunt-stylelint@"latest" from the root project npm ERR! npm ERR! Fix the upstream dependency conflict, or retry npm ERR! this command with --force, or --legacy-peer-deps npm ERR! to accept an incorrect (and potentially broken) dependency resolution. npm ERR! npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-01-06T13_37_32_112Z-debug-0.log pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $
@richard238 seems like styleint is giving issues, Can you just try and install mysql and see if that resolves your issue?
Install mysql - how and where?
Apologies for the detail request, but having got this far, I don’t want to break anything else.
Thank you.
@richard238 In the MMM-MysqlQuery folder,
npm i mysql
pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql npm ERR! code ERESOLVE npm ERR! ERESOLVE unable to resolve dependency tree npm ERR! npm ERR! While resolving: mmm-mysqlquery@1.0.0 npm ERR! Found: stylelint@8.4.0 npm ERR! node_modules/stylelint npm ERR! dev stylelint@"^8.3.0" from the root project npm ERR! npm ERR! Could not resolve dependency: npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0 npm ERR! node_modules/grunt-stylelint npm ERR! dev grunt-stylelint@"latest" from the root project npm ERR! npm ERR! Fix the upstream dependency conflict, or retry npm ERR! this command with --force, or --legacy-peer-deps npm ERR! to accept an incorrect (and potentially broken) dependency resolution. npm ERR! npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-01-06T14_02_53_804Z-debug-0.log pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $
