    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 43.9k Views 4 Watching
      Richard238 @mumblebaj
      @mumblebaj
      pi@magicmirror:~/MagicMirror $ npm uninstall mysql
      npm WARN EBADENGINE Unsupported engine { package: 'magicmirror@2.18.0',
      npm WARN EBADENGINE   required: { node: '>=12' },
      npm WARN EBADENGINE   current: { node: 'v10.24.1', npm: '7.24.2' } }
      npm WARN EBADENGINE Unsupported engine { package: '@es-joy/jsdoccomment@0.13.0',
      npm WARN EBADENGINE   required: { node: '^12 || ^14 || ^16 || ^17' },
      npm WARN EBADENGINE Unsupported engine { package: '@eslint/eslintrc@1.0.5',
      npm WARN EBADENGINE   required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/experimental-utils@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/scope-manager@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/types@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/typescript-estree@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/visitor-keys@5.8.0',
      npm WARN EBADENGINE Unsupported engine { package: 'commander@8.3.0',
      npm WARN EBADENGINE   required: { node: '>= 12' },
      npm WARN EBADENGINE Unsupported engine { package: 'comment-parser@1.3.0',
      npm WARN EBADENGINE   required: { node: '>= 12.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'data-urls@3.0.1',
      npm WARN EBADENGINE Unsupported engine { package: 'domexception@4.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint@8.5.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jest@25.3.0',
      npm WARN EBADENGINE   required: { node: '^12.13.0 || ^14.15.0 || >=16.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jsdoc@37.4.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-scope@7.1.0',
      npm WARN EBADENGINE Unsupported engine { package: 'eslint-visitor-keys@3.1.0',
      npm WARN EBADENGINE Unsupported engine { package: 'espree@9.2.0',
      npm WARN EBADENGINE Unsupported engine { package: 'html-encoding-sniffer@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'husky@7.0.4',
      npm WARN EBADENGINE Unsupported engine { package: 'jsdoc-type-pratt-parser@2.0.0',
      npm WARN EBADENGINE   required: { node: '>=12.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'jsdom@19.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'playwright@1.17.1',
      npm WARN EBADENGINE Unsupported engine { package: 'playwright-core@1.17.1',
      npm WARN EBADENGINE Unsupported engine { package: 'postcss-safe-parser@6.0.0',
      npm WARN EBADENGINE   required: { node: '>=12.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'stylelint@14.2.0',
      npm WARN EBADENGINE   required: { node: '^12.20.0 || ^14.13.1 || >=16.0.0' },
      npm WARN EBADENGINE Unsupported engine { package: 'stylelint-config-prettier@9.0.3',
      npm WARN EBADENGINE Unsupported engine { package: 'stylelint-prettier@2.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'tr46@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'w3c-xmlserializer@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'webidl-conversions@7.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'whatwg-encoding@2.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'whatwg-mimetype@3.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'whatwg-url@10.0.0',
      npm WARN EBADENGINE Unsupported engine { package: 'xml-name-validator@4.0.0',
      removed 4 packages, and audited 758 packages in 14s
      66 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
      pi@magicmirror:~/MagicMirror $ cd modules/MMM-MysqlQuery
      pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm install
      npm ERR! code ERESOLVE
      npm ERR! ERESOLVE unable to resolve dependency tree
      npm ERR!
      npm ERR! While resolving: mmm-mysqlquery@1.0.0
      npm ERR! Found: stylelint@8.4.0
      npm ERR! node_modules/stylelint
      npm ERR!   dev stylelint@"^8.3.0" from the root project
      npm ERR!
      npm ERR! Could not resolve dependency:
      npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
      npm ERR! node_modules/grunt-stylelint
      npm ERR!   dev grunt-stylelint@"latest" from the root project
      npm ERR!
      npm ERR! Fix the upstream dependency conflict, or retry
      npm ERR! this command with --force, or --legacy-peer-deps
      npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
      npm ERR!
      npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
      npm ERR!     /home/pi/.npm/_logs/2022-01-06T12_07_55_731Z-debug.log
      • mumblebajM Offline
        mumblebaj Module Developer @Richard238
        @richard238 It seems your versions of npm and node might be older than the required versions. run the following
        node -v
        npm -v
          @mumblebaj
           $ node -v     v10.24.1
           $ npm -v      7.24.2
            @richard238 You want to update both first.
              @mumblebaj
              Great ok, thank you.
              What’s the best way to do those two updates, please?
                @richard238 Just google update npm and update node. Once those are updated then you can do the rest. Uninstall mysql and run npm install in the MMM-MysqlQuery folder. Hopefully that will resolve the issues.
                  @mumblebaj
                  Ok, step one completed and looking much more up-to-date:
                  pi@magicmirror:~ $ npm -v
                  8.3.0
                  pi@magicmirror:~ $ node -v
                  v17.3.0
                    Richard238 @Richard238
                    @richard238
                    And step two:
                    up to date, audited 758 packages in 10s
                    npm ERR!
                    npm ERR!
                    npm ERR!
                    npm ERR!
                    npm ERR!     /home/pi/.npm/_logs/2022-01-06T12_51_27_088Z-debug-0.log
                      @richard238 can you check if package-lock.json exist. if it does delete it rm package-lock.json then try again. Also, did you do the uninstall in the MagicMirror folder first?
                        @mumblebaj
                        Yes, I did.
                        pi@magicmirror:~ $ sudo rm package-lock.json
                        pi@magicmirror:~ $ cd ~/MagicMirror
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!     /home/pi/.npm/_logs/2022-01-06T13_37_32_112Z-debug-0.log
                          @richard238 seems like styleint is giving issues, Can you just try and install mysql and see if that resolves your issue?
                            @mumblebaj
                            Install mysql - how and where?
                            Apologies for the detail request, but having got this far, I don’t want to break anything else.
                            Thank you.
                              @richard238 In the MMM-MysqlQuery folder, npm i mysql
                                @mumblebaj
                                pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql
                                npm ERR!
                                npm ERR!
                                npm ERR!
                                npm ERR!
                                npm ERR!     /home/pi/.npm/_logs/2022-01-06T14_02_53_804Z-debug-0.log
                                  @richard238 run npm i mysql --force The stylint is a dev dependency.
                                  R S 2 Replies Last reply Reply Quote 0
                                    @mumblebaj
                                    Looking better…
                                    pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql --force
                                    npm WARN using --force Recommended protections disabled.
                                    npm WARN ERESOLVE overriding peer dependency
                                    npm WARN While resolving: grunt-stylelint@0.17.0
                                    npm WARN Found: stylelint@8.4.0
                                    npm WARN node_modules/stylelint
                                    npm WARN   dev stylelint@"^8.3.0" from the root project
                                    npm WARN
                                    npm WARN Could not resolve dependency:
                                    npm WARN peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
                                    npm WARN node_modules/grunt-stylelint
                                    npm WARN   dev grunt-stylelint@"latest" from the root project
                                    npm WARN
                                    npm WARN Conflicting peer dependency: stylelint@14.2.0
                                    npm WARN While resolving: stylelint-config-standard@24.0.0
                                    npm WARN
                                    npm WARN peer stylelint@"^14.0.0" from stylelint-config-standard@24.0.0
                                    npm WARN node_modules/stylelint-config-standard
                                    npm WARN   dev stylelint-config-standard@"latest" from the root project
                                    npm WARN
                                    npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                    npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                                    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                    added 606 packages, and audited 1043 packages in 3m
                                    49 packages are looking for funding
                                    29 vulnerabilities (1 low, 17 moderate, 11 high)
                                    To address issues that do not require attention, run:
                                      npm audit fix
                                    To address all issues (including breaking changes), run:
                                      npm audit fix --force
                                    Run `npm audit` for details.
                                      sdetweil @mumblebaj
                                      @mumblebaj why my install script does npm install --only=prod
                                      to remove the dev dependencies
                                        @sdetweil :thumbs_up:
                                          What are “dev dependencies” to the uninitiated?
                                          S R 2 Replies Last reply Reply Quote 0
                                            sdetweil @Richard238
                                            @richard238 there are dependencies
                                            things needed to RUN
                                            and dev dependencies,
                                            things needed to DEVELOP for existing or new function
                                            things like syntax checkers, format checkers, test cases, … 99% of users don’t need that stuff on their disc
                                            in the package.json are two lists of dependencies
                                            “devDependencies”: {
                                            “dependencies”: {
                                            unless u specify only runtime (production) , you get both …
                                            • 1 / 4
