    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 46.5k Views 4 Watching
      Richard238 @mumblebaj
      @mumblebaj
      Great ok, thank you.
      What’s the best way to do those two updates, please?
      • mumblebajM
        mumblebaj Module Developer @Richard238
        @richard238 Just google update npm and update node. Once those are updated then you can do the rest. Uninstall mysql and run npm install in the MMM-MysqlQuery folder. Hopefully that will resolve the issues.
          @mumblebaj
          Ok, step one completed and looking much more up-to-date:
          pi@magicmirror:~ $ npm -v
          8.3.0
          pi@magicmirror:~ $ node -v
          v17.3.0
            Richard238 @Richard238
            @richard238
            And step two:
            pi@magicmirror:~/MagicMirror $ npm uninstall mysql
            up to date, audited 758 packages in 10s
            66 packages are looking for funding
              run `npm fund` for details
            found 0 vulnerabilities
            pi@magicmirror:~/MagicMirror $ cd modules/MMM-MysqlQuery
            pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm install
            npm ERR! code ERESOLVE
            npm ERR! ERESOLVE unable to resolve dependency tree
            npm ERR!
            npm ERR! While resolving: mmm-mysqlquery@1.0.0
            npm ERR! Found: stylelint@8.4.0
            npm ERR! node_modules/stylelint
            npm ERR!   dev stylelint@"^8.3.0" from the root project
            npm ERR!
            npm ERR! Could not resolve dependency:
            npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
            npm ERR! node_modules/grunt-stylelint
            npm ERR!   dev grunt-stylelint@"latest" from the root project
            npm ERR!
            npm ERR! Fix the upstream dependency conflict, or retry
            npm ERR! this command with --force, or --legacy-peer-deps
            npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
            npm ERR!
            npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
            npm ERR!     /home/pi/.npm/_logs/2022-01-06T12_51_27_088Z-debug-0.log
            • mumblebajM
              @richard238 can you check if package-lock.json exist. if it does delete it rm package-lock.json then try again. Also, did you do the uninstall in the MagicMirror folder first?
                @mumblebaj
                Yes, I did.
                pi@magicmirror:~ $ sudo rm package-lock.json
                pi@magicmirror:~ $ cd ~/MagicMirror
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!     /home/pi/.npm/_logs/2022-01-06T13_37_32_112Z-debug-0.log
                • mumblebajM
                  @richard238 seems like styleint is giving issues, Can you just try and install mysql and see if that resolves your issue?
                    @mumblebaj
                    Install mysql - how and where?
                    Apologies for the detail request, but having got this far, I don’t want to break anything else.
                    Thank you.
                    • mumblebajM
                      @richard238 In the MMM-MysqlQuery folder, npm i mysql
                        @mumblebaj
                        pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!     /home/pi/.npm/_logs/2022-01-06T14_02_53_804Z-debug-0.log
                        • mumblebajM
                          @richard238 run npm i mysql --force The stylint is a dev dependency.
                          R S 2 Replies Last reply Reply Quote 0
                            @mumblebaj
                            Looking better…
                            pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql --force
                            npm WARN using --force Recommended protections disabled.
                            npm WARN ERESOLVE overriding peer dependency
                            npm WARN While resolving: grunt-stylelint@0.17.0
                            npm WARN Found: stylelint@8.4.0
                            npm WARN node_modules/stylelint
                            npm WARN   dev stylelint@"^8.3.0" from the root project
                            npm WARN
                            npm WARN Could not resolve dependency:
                            npm WARN peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
                            npm WARN node_modules/grunt-stylelint
                            npm WARN   dev grunt-stylelint@"latest" from the root project
                            npm WARN
                            npm WARN Conflicting peer dependency: stylelint@14.2.0
                            npm WARN While resolving: stylelint-config-standard@24.0.0
                            npm WARN
                            npm WARN peer stylelint@"^14.0.0" from stylelint-config-standard@24.0.0
                            npm WARN node_modules/stylelint-config-standard
                            npm WARN   dev stylelint-config-standard@"latest" from the root project
                            npm WARN
                            npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                            npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                            npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            added 606 packages, and audited 1043 packages in 3m
                            49 packages are looking for funding
                            29 vulnerabilities (1 low, 17 moderate, 11 high)
                            To address issues that do not require attention, run:
                              npm audit fix
                            To address all issues (including breaking changes), run:
                              npm audit fix --force
                            Run `npm audit` for details.
                              sdetweil @mumblebaj
                              @mumblebaj why my install script does npm install --only=prod
                              to remove the dev dependencies
                              • mumblebajM
                                @sdetweil :thumbs_up:
                                  What are “dev dependencies” to the uninitiated?
                                  S R 2 Replies Last reply Reply Quote 0
                                    sdetweil @Richard238
                                    @richard238 there are dependencies
                                    things needed to RUN
                                    and dev dependencies,
                                    things needed to DEVELOP for existing or new function
                                    things like syntax checkers, format checkers, test cases, … 99% of users don’t need that stuff on their disc
                                    in the package.json are two lists of dependencies
                                    “devDependencies”: {
                                    “dependencies”: {
                                    unless u specify only runtime (production) , you get both …
                                      Still no MM though. Status says online, but it’s not launching MM.
                                      I’ll reboot, because, why not…
                                      pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
                                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                                      [PM2] [MagicMirror](0) ✓
                                      [PM2] Process successfully started
                                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                      │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.6mb    │
                                        @richard238 no reboot…
                                        just pm2 stop 0
                                        pm2 flush
                                        pm2 start 0
                                        then pm2 logs --line=50
                                          Richard238 @sdetweil
                                          pi@magicmirror:~/MagicMirror $ pm2 stop 0
                                          [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                                          │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                          pi@magicmirror:~/MagicMirror $ pm2 flush
                                          [PM2] Flushing /home/pi/.pm2/pm2.log
                                          [PM2] Flushing:
                                          [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                                          [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                                          [PM2] Logs flushed
                                          pi@magicmirror:~/MagicMirror $ pm2 start 0
                                          [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                                          │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                                          pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
                                          [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                                          /home/pi/.pm2/pm2.log last 50 lines:
                                          PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
                                          /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                                          0|MagicMir |
                                          0|MagicMir | > magicmirror@2.18.0 start
                                          0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                          0|MagicMir |
                                          /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                                          0|MagicMir | App threw an error during load
                                          0|MagicMir | TypeError: Log.log is not a function
                                          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
                                          0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                                          0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                                          0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
                                          0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
                                          0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                                          0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                                          0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
                                          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
                                          0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                                          0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                                          0|MagicMir | A JavaScript error occurred in the main process
                                          0|MagicMir | Uncaught Exception:
                                          0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                          0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                            @richard238 ok, do
                                            rm -rf node_modules
                                            • 2 / 4
