    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 46.5k Views 4 Watching
    • mumblebajM
      mumblebaj Module Developer @Richard238
      @richard238 run npm i mysql --force The stylint is a dev dependency.
      R S 2 Replies Last reply Reply Quote 0
        Richard238 @mumblebaj
        @mumblebaj
        Looking better…
        pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql --force
        npm WARN using --force Recommended protections disabled.
        npm WARN ERESOLVE overriding peer dependency
        npm WARN While resolving: grunt-stylelint@0.17.0
        npm WARN Found: stylelint@8.4.0
        npm WARN node_modules/stylelint
        npm WARN   dev stylelint@"^8.3.0" from the root project
        npm WARN
        npm WARN Could not resolve dependency:
        npm WARN peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
        npm WARN node_modules/grunt-stylelint
        npm WARN   dev grunt-stylelint@"latest" from the root project
        npm WARN
        npm WARN Conflicting peer dependency: stylelint@14.2.0
        npm WARN While resolving: stylelint-config-standard@24.0.0
        npm WARN
        npm WARN peer stylelint@"^14.0.0" from stylelint-config-standard@24.0.0
        npm WARN node_modules/stylelint-config-standard
        npm WARN   dev stylelint-config-standard@"latest" from the root project
        npm WARN
        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
        npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        added 606 packages, and audited 1043 packages in 3m
        49 packages are looking for funding
          run `npm fund` for details
        29 vulnerabilities (1 low, 17 moderate, 11 high)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues (including breaking changes), run:
          npm audit fix --force
        Run `npm audit` for details.
          sdetweil @mumblebaj
          @mumblebaj why my install script does npm install --only=prod
          to remove the dev dependencies
          • mumblebajM
            @sdetweil :thumbs_up:
              What are “dev dependencies” to the uninitiated?
              S R 2 Replies Last reply Reply Quote 0
                sdetweil @Richard238
                @richard238 there are dependencies
                things needed to RUN
                and dev dependencies,
                things needed to DEVELOP for existing or new function
                things like syntax checkers, format checkers, test cases, … 99% of users don’t need that stuff on their disc
                in the package.json are two lists of dependencies
                “devDependencies”: {
                “dependencies”: {
                unless u specify only runtime (production) , you get both …
                  Richard238 @Richard238
                  Still no MM though. Status says online, but it’s not launching MM.
                  I’ll reboot, because, why not…
                  pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
                  [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                  [PM2] [MagicMirror](0) ✓
                  [PM2] Process successfully started
                  │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                  │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.6mb    │
                    @richard238 no reboot…
                    just pm2 stop 0
                    pm2 flush
                    pm2 start 0
                    then pm2 logs --line=50
                      Richard238 @sdetweil
                      pi@magicmirror:~/MagicMirror $ pm2 stop 0
                      [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                      │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                      pi@magicmirror:~/MagicMirror $ pm2 flush
                      [PM2] Flushing /home/pi/.pm2/pm2.log
                      [PM2] Flushing:
                      [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                      [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                      [PM2] Logs flushed
                      pi@magicmirror:~/MagicMirror $ pm2 start 0
                      [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                      │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                      pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
                      [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                      /home/pi/.pm2/pm2.log last 50 lines:
                      PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
                      /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                      0|MagicMir |
                      0|MagicMir | > magicmirror@2.18.0 start
                      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      0|MagicMir |
                      /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                      0|MagicMir | App threw an error during load
                      0|MagicMir | TypeError: Log.log is not a function
                      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
                      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                      0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                      0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
                      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
                      0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                      0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
                      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
                      0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                      0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                      0|MagicMir | A JavaScript error occurred in the main process
                      0|MagicMir | Uncaught Exception:
                      0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                      0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                        @richard238 ok, do
                        rm -rf node_modules
                        rm package-lock.json
                          pi@magicmirror:~/MagicMirror $ rm -rf node_modules
                          pi@magicmirror:~/MagicMirror $ rm package-lock.json
                          pi@magicmirror:~/MagicMirror $ npm install --only=prod
                          > magicmirror@2.18.0 install
                          > " && cd vendor && npm install --loglevel=error
                          up to date, audited 10 packages in 4s
                          found 0 vulnerabilities
                          > magicmirror@2.18.0 postinstall
                          > npm run install-fonts && echo "MagicMirror installation finished successfully!
                          > magicmirror@2.18.0 install-fonts
                          > echo "Installing fonts ...
                          > " && cd fonts && npm install --loglevel=error
                          up to date, audited 2 packages in 13s
                          > magicmirror@2.18.0 prepare
                          > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                          no husky installed.
                          added 267 packages, and audited 268 packages in 6m
                          19 packages are looking for funding
                            @richard238 and try to run mm again
                              Online, but no MM showing.
                              │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                                @richard238 and show log output again?
                                and output of
                                node -v
                                npm -v
                                  PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
                                  PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                  PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
                                  PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                  PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
                                  0|MagicMir |
                                  0|MagicMir |
                                  0|MagicMir |
                                  0|MagicMir |
                                  0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                  0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                                  0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                  0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                  pi@magicmirror:~/MagicMirror $ node -v
                                  v17.3.0
                                  pi@magicmirror:~/MagicMirror $ npm -v
                                  8.3.0
                                    @richard238 can u show the ~/MagicMirror/config/config.js
                                      config.js, minus private data.
                                      /* Magic Mirror Config Sample
                                       * MIT Licensed.
                                      var config = {
                                      	port: 8080,
                                      	address:"0.0.0.0",
                                      	ipWhitelist: [],
                                      	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                                      	language: 'en',
                                      	timeFormat: 24,
                                      	units: 'metric',
                                      			module: 'alert',
                                      			module: "updatenotification",
                                      			position: "top_bar"
                                      			module: 'clock',
                                      			position: 'top_left'
                                      			module: 'calendar',
                                      			header: 'Calendar',
                                      			position: 'top_left',
                                                          maximumEntries: 6, // Total Maximum Entries
                                                          maximumNumberOfDays: 365,
                                                          displaySymbol: true,
                                                          defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                                          displayRepeatingCountTitle: false,
                                                          defaultRepeatingCountTitle: "",
                                                          maxTitleLength: 30,
                                                          fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                                          animationSpeed: 2000,
                                                          fade: true,
                                                          showEnd: false,
                                                          urgency: 0,
                                                          timeFormat: "absolute",
                                                          dateFormat: "ddd Do MMMM",
                                                          getRelative: 0,
                                                          fadePoint: 0.50, // Start on 1/4th of the list.
                                                          hidePrivate: false,
                                      						symbol: 'calendar-check-o ',
                                      						url: 'https:/nnnnnnnnnnnnnnnnnnnnn/basic.ics'
                                      			module: 'calendar',
                                      			header: 'Binday',
                                      			position: 'bottom_left',
                                                          maximumEntries: 4, // Total Maximum Entries
                                                          maxTitleLength: 30,
                                                          fade: true,
                                                          showEnd: false,
                                                          urgency: 0,
                                                          getRelative: 0,
                                                          hidePrivate: false,
                                      						symbol: 'trash-o ',
                                      						url: 'https:/nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn/basic.ics'
                                                      titleReplace: {
                                                      //	"'s birthday": "",
                                                      //	"Recycling": "Bins",
                                                          "Red Bin": "Red & Black Bins",
                                                          "Green Bin": "Green & Black Bins"
                                                      // Override start method.
                                                      start: function () {
                                                          Log.log("Starting module: " + this.name);
                                                          /* This code changed times to 24hr clock until April 17 system update.
                                                          ** Set locale.
                                                          **  if (config.language === 'en' && config.timeFormat == 24) {
                                                          **  config.language = 'en-gb';
                                                          ** moment.locale(config.language);
                                                          for (var c in this.config.calendars) {
                                                              var calendar = this.config.calendars[c];
                                                              calendar.url = calendar.url.replace("webcal://", "http://");
                                                              this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                                          this.calendarData = {};
                                                          this.loaded = false;
                                      			module: 'compliments',
                                      			position: 'lower_third',
                                      			anytime: [
                                      				"A1",
                                                      "A2",
                                                      "A3"
                                      			morning: [
                                      				"M1",
                                      				"M2",
                                      				"M3"
                                      			afternoon: [
                                      				"N1",
                                      				"N2",
                                      				"N3"
                                      			evening: [
                                      				"E1",
                                      				"E2",
                                      				"E3"
                                      		updateInterval: 30000,
                                      		remoteFile: null,
                                      		fadeSpeed: 4000
                                      			/*config: {
                                      				remoteFile: 'compliments.json'
                                                  module: 'MMM-doomsDay',
                                                  position: 'top_center', // This can be any of the regions, best results in center regions
                                                  doomsDay: "2022-01-06 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                                  /*            doomsDay: "2020-12-21 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date   */
                                                  toWhat: "today",
                                      			module: 'currentweather',
                                      			header: 'Current weather for: ',
                                      			position: 'top_right',
                                      				locationID: 'nnnn',  //ID from http://www.openweathermap.org
                                      				appid: 'nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn'
                                      			module: 'weatherforecast',
                                      			header: 'Weather Forecast',
                                      				locationID: 'nnnnnnn',  //ID from http://www.openweathermap.org
                                      				appid: 'aaannnnnnnnnn'
                                                  module: 'MMM-MysqlQuery',
                                                  position: 'bottom_right',
                                      			header: 'Greenhouse Status',
                                                      connection: {
                                                          host: "192.168.1.23",
                                                          port: 3306,
                                                          user: "nnnnnnnnnnnnnnnn",
                                                          password: "nnnnnnnnnnnnnnnn",
                                                          database: "garage"
                                      /*              query: `select Temp-2
                                                              from readings
                                                              order by ID desc
                                                              limit 1`,
                                      			query: "select Added, \
                                      			Temp, \
                                      						Pressure, \
                                      						Humidity \
                                      						from gh_readings \
                                      						order by ID \
                                      						desc limit 3",
                                          			intervalSeconds: 1 * 60,
                                                      emptyMessage: "No data!",
                                                      columns: [
                                                          { name: "Added",     title: "At", cssClass: "left", dateFormat: "time", dateLocale: "en-GB" },
                                                          { name: "Temp",     title: "Temp", cssClass: "left", suffix: "°C", nullValue: "???" },
                                                          { name: "Pressure",     title: "Pressure", cssClass: "left", suffix: " hPa", nullValue: "???" },
                                                          { name: "Humidity",     title: "Humidity", cssClass: "left", suffix: " %" },
                                      			module: 'newsfeed',
                                      			position: 'bottom_bar',
                                      				feeds: [
                                                              title: "BBC World",
                                                              url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                                                              title: "Al Jazeera",
                                                              url: "https://www.aljazeera.com/xml/rss/all.xml"
                                                              title: "Sky news",
                                                              url: "http://feeds.skynews.com/feeds/rss/world.xml"
                                      				showSourceTitle: true,
                                      				showPublishDate: true,
                                                      reloadInterval:  2 * 60 * 1000, // every 5 minutes
                                                      updateInterval: 2 * 5000
                                        @richard238 said in v2.18.0 update gave black screen, then nothing.:
                                        >                     ** Set locale.
                                        what is that? I’m not aware of any code in config for calendar
                                        for grins, can you add // in front of the Log.log statement
                                          No idea, thought it had always been there. I’m not much of a coder, as I’m sure you can tell.
                                          // added
                                          PM2        | 2022-01-06T15:51:52: PM2 log: Stopping app:MagicMirror id:0
                                          PM2        | 2022-01-06T15:51:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                          PM2        | 2022-01-06T15:51:53: PM2 log: pid=18675 msg=process killed
                                          PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] online
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir | (node:32542) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                                          0|MagicMir | [32574:0106/155207.031878:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                          0|MagicMir | [32615:0106/155207.383004:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                          S 3 Replies Last reply Reply Quote 0
                                            @richard238 added it to me config.js and it doesn’t matter…
                                            • 2 / 4
