    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 44.0k Views 4 Watching
    • mumblebajM Offline
      @sdetweil :thumbs_up:
        Richard238 @mumblebaj
        What are “dev dependencies” to the uninitiated?
        S R 2 Replies Last reply Reply Quote 0
          sdetweil @Richard238
          @richard238 there are dependencies
          things needed to RUN
          and dev dependencies,
          things needed to DEVELOP for existing or new function
          things like syntax checkers, format checkers, test cases, … 99% of users don’t need that stuff on their disc
          in the package.json are two lists of dependencies
          “devDependencies”: {
          “dependencies”: {
          unless u specify only runtime (production) , you get both …
            Richard238 @Richard238
            Still no MM though. Status says online, but it’s not launching MM.
            I’ll reboot, because, why not…
            pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            [PM2] Process successfully started
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.6mb    │
              @richard238 no reboot…
              just pm2 stop 0
              pm2 flush
              pm2 start 0
              then pm2 logs --line=50
                Richard238 @sdetweil
                pi@magicmirror:~/MagicMirror $ pm2 stop 0
                [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                pi@magicmirror:~/MagicMirror $ pm2 flush
                [PM2] Flushing /home/pi/.pm2/pm2.log
                [PM2] Flushing:
                [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                [PM2] Logs flushed
                pi@magicmirror:~/MagicMirror $ pm2 start 0
                [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
                [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                /home/pi/.pm2/pm2.log last 50 lines:
                PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
                /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                0|MagicMir |
                0|MagicMir | > magicmirror@2.18.0 start
                0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                0|MagicMir |
                /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                0|MagicMir | App threw an error during load
                0|MagicMir | TypeError: Log.log is not a function
                0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
                0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
                0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
                0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
                0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
                0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                0|MagicMir | A JavaScript error occurred in the main process
                0|MagicMir | Uncaught Exception:
                0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                  @richard238 ok, do
                  rm -rf node_modules
                  rm package-lock.json
                  npm install --only=prod
                    pi@magicmirror:~/MagicMirror $ rm -rf node_modules
                    pi@magicmirror:~/MagicMirror $ rm package-lock.json
                    pi@magicmirror:~/MagicMirror $ npm install --only=prod
                    > magicmirror@2.18.0 install
                    > " && cd vendor && npm install --loglevel=error
                    up to date, audited 10 packages in 4s
                    found 0 vulnerabilities
                    > magicmirror@2.18.0 postinstall
                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                    > magicmirror@2.18.0 install-fonts
                    > echo "Installing fonts ...
                    > " && cd fonts && npm install --loglevel=error
                    up to date, audited 2 packages in 13s
                    > magicmirror@2.18.0 prepare
                    > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                    no husky installed.
                    added 267 packages, and audited 268 packages in 6m
                    19 packages are looking for funding
                      run `npm fund` for details
                      @richard238 and try to run mm again
                        Online, but no MM showing.
                        │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                          @richard238 and show log output again?
                          and output of
                          node -v
                          npm -v
                            PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
                            PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                            0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                            0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                            0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                            pi@magicmirror:~/MagicMirror $ node -v
                            v17.3.0
                            pi@magicmirror:~/MagicMirror $ npm -v
                            8.3.0
                              @richard238 can u show the ~/MagicMirror/config/config.js
                                config.js, minus private data.
                                /* Magic Mirror Config Sample
                                 * MIT Licensed.
                                var config = {
                                	port: 8080,
                                	address:"0.0.0.0",
                                	ipWhitelist: [],
                                	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                                	language: 'en',
                                	timeFormat: 24,
                                	units: 'metric',
                                			module: 'alert',
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: 'clock',
                                			position: 'top_left'
                                			module: 'calendar',
                                			header: 'Calendar',
                                			position: 'top_left',
                                                    maximumEntries: 6, // Total Maximum Entries
                                                    maximumNumberOfDays: 365,
                                                    displaySymbol: true,
                                                    defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                                    displayRepeatingCountTitle: false,
                                                    defaultRepeatingCountTitle: "",
                                                    maxTitleLength: 30,
                                                    fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                                    animationSpeed: 2000,
                                                    fade: true,
                                                    showEnd: false,
                                                    urgency: 0,
                                                    timeFormat: "absolute",
                                                    dateFormat: "ddd Do MMMM",
                                                    getRelative: 0,
                                                    fadePoint: 0.50, // Start on 1/4th of the list.
                                                    hidePrivate: false,
                                						symbol: 'calendar-check-o ',
                                						url: 'https:/nnnnnnnnnnnnnnnnnnnnn/basic.ics'
                                			module: 'calendar',
                                			header: 'Binday',
                                			position: 'bottom_left',
                                                    maximumEntries: 4, // Total Maximum Entries
                                                    maxTitleLength: 30,
                                                    fade: true,
                                                    showEnd: false,
                                                    urgency: 0,
                                                    getRelative: 0,
                                                    hidePrivate: false,
                                						symbol: 'trash-o ',
                                						url: 'https:/nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn/basic.ics'
                                                titleReplace: {
                                                //	"'s birthday": "",
                                                //	"Recycling": "Bins",
                                                    "Red Bin": "Red & Black Bins",
                                                    "Green Bin": "Green & Black Bins"
                                                // Override start method.
                                                start: function () {
                                                    Log.log("Starting module: " + this.name);
                                                    /* This code changed times to 24hr clock until April 17 system update.
                                                    ** Set locale.
                                                    **  if (config.language === 'en' && config.timeFormat == 24) {
                                                    **  config.language = 'en-gb';
                                                    ** moment.locale(config.language);
                                                    for (var c in this.config.calendars) {
                                                        var calendar = this.config.calendars[c];
                                                        calendar.url = calendar.url.replace("webcal://", "http://");
                                                        this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                                    this.calendarData = {};
                                                    this.loaded = false;
                                			module: 'compliments',
                                			position: 'lower_third',
                                			anytime: [
                                				"A1",
                                                "A2",
                                                "A3"
                                			morning: [
                                				"M1",
                                				"M2",
                                				"M3"
                                			afternoon: [
                                				"N1",
                                				"N2",
                                				"N3"
                                			evening: [
                                				"E1",
                                				"E2",
                                				"E3"
                                		updateInterval: 30000,
                                		remoteFile: null,
                                		fadeSpeed: 4000
                                			/*config: {
                                				remoteFile: 'compliments.json'
                                            module: 'MMM-doomsDay',
                                            position: 'top_center', // This can be any of the regions, best results in center regions
                                            doomsDay: "2022-01-06 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                            /*            doomsDay: "2020-12-21 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date   */
                                            toWhat: "today",
                                			module: 'currentweather',
                                			header: 'Current weather for: ',
                                			position: 'top_right',
                                				locationID: 'nnnn',  //ID from http://www.openweathermap.org
                                				appid: 'nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn'
                                			module: 'weatherforecast',
                                			header: 'Weather Forecast',
                                				locationID: 'nnnnnnn',  //ID from http://www.openweathermap.org
                                				appid: 'aaannnnnnnnnn'
                                            module: 'MMM-MysqlQuery',
                                            position: 'bottom_right',
                                			header: 'Greenhouse Status',
                                                connection: {
                                                    host: "192.168.1.23",
                                                    port: 3306,
                                                    user: "nnnnnnnnnnnnnnnn",
                                                    password: "nnnnnnnnnnnnnnnn",
                                                    database: "garage"
                                /*              query: `select Temp-2
                                                        from readings
                                                        order by ID desc
                                                        limit 1`,
                                			query: "select Added, \
                                			Temp, \
                                						Pressure, \
                                						Humidity \
                                						from gh_readings \
                                						order by ID \
                                						desc limit 3",
                                    			intervalSeconds: 1 * 60,
                                                emptyMessage: "No data!",
                                                columns: [
                                                    { name: "Added",     title: "At", cssClass: "left", dateFormat: "time", dateLocale: "en-GB" },
                                                    { name: "Temp",     title: "Temp", cssClass: "left", suffix: "°C", nullValue: "???" },
                                                    { name: "Pressure",     title: "Pressure", cssClass: "left", suffix: " hPa", nullValue: "???" },
                                                    { name: "Humidity",     title: "Humidity", cssClass: "left", suffix: " %" },
                                			module: 'newsfeed',
                                			position: 'bottom_bar',
                                				feeds: [
                                                        title: "BBC World",
                                                        url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                                                        title: "Al Jazeera",
                                                        url: "https://www.aljazeera.com/xml/rss/all.xml"
                                                        title: "Sky news",
                                                        url: "http://feeds.skynews.com/feeds/rss/world.xml"
                                				showSourceTitle: true,
                                				showPublishDate: true,
                                                reloadInterval:  2 * 60 * 1000, // every 5 minutes
                                                updateInterval: 2 * 5000
                                  @richard238 said in v2.18.0 update gave black screen, then nothing.:
                                  >                     ** Set locale.
                                  what is that? I’m not aware of any code in config for calendar
                                  for grins, can you add // in front of the Log.log statement
                                    No idea, thought it had always been there. I’m not much of a coder, as I’m sure you can tell.
                                    // added
                                    PM2        | 2022-01-06T15:51:52: PM2 log: Stopping app:MagicMirror id:0
                                    PM2        | 2022-01-06T15:51:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                    PM2        | 2022-01-06T15:51:53: PM2 log: pid=18675 msg=process killed
                                    PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                    PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] online
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir | (node:32542) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                                    0|MagicMir | [32574:0106/155207.031878:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                    0|MagicMir | [32615:0106/155207.383004:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                    S 3 Replies Last reply Reply Quote 0
                                      @richard238 added it to me config.js and it doesn’t matter…
                                        @richard238 ok, lets start back somewhere
                                        save your config.js
                                        copy the sample back to config.js
                                        and start
                                        this should work …
                                          @richard238 i copied your config above to my system
                                          and it starts ok…
                                          my node/npm are
                                          node -v
                                          v16.1.0
                                          npm -v
                                          7.24.2
                                          so, lets try that , we will use the node version of node version manager (nvm) called n
                                          # install n globally
                                          npm i n -g
                                          # install node version 16.1.0
                                          n i 16.1.0
                                          # use the setup path from node version install
                                          PATH="$PATH"
                                          # verify node and npm versions
                                          node -v
                                          npm -v
                                            run those from
                                            or
                                            pi@magicmirror:~ $
                                            Or, does it not matter?
                                            • 2 / 4
