    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 47.7k Views 4 Watching
      sdetweil @Richard238
      @richard238 no reboot…
      just pm2 stop 0
      pm2 flush
      pm2 start 0
      then pm2 logs --line=50
      R 1 Reply Last reply
        Richard238 @sdetweil
        pi@magicmirror:~/MagicMirror $ pm2 stop 0
        [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
        [PM2] [MagicMirror](0) ✓
        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
        │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
        pi@magicmirror:~/MagicMirror $ pm2 flush
        [PM2] Flushing /home/pi/.pm2/pm2.log
        [PM2] Flushing:
        [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
        [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
        [PM2] Logs flushed
        pi@magicmirror:~/MagicMirror $ pm2 start 0
        [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
        [PM2] Process successfully started
        │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
        pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
        [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
        /home/pi/.pm2/pm2.log last 50 lines:
        PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
        /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
        0|MagicMir |
        0|MagicMir | > magicmirror@2.18.0 start
        0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        0|MagicMir |
        /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
        0|MagicMir | App threw an error during load
        0|MagicMir | TypeError: Log.log is not a function
        0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
        0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
        0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
        0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
        0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
        0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
        0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
        0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
        0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
        0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
        0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
        0|MagicMir | A JavaScript error occurred in the main process
        0|MagicMir | Uncaught Exception:
        0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
        0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
          @richard238 ok, do
          rm -rf node_modules
          rm package-lock.json
          npm install --only=prod
            pi@magicmirror:~/MagicMirror $ rm -rf node_modules
            pi@magicmirror:~/MagicMirror $ rm package-lock.json
            pi@magicmirror:~/MagicMirror $ npm install --only=prod
            > magicmirror@2.18.0 install
            > " && cd vendor && npm install --loglevel=error
            up to date, audited 10 packages in 4s
            found 0 vulnerabilities
            > magicmirror@2.18.0 postinstall
            > npm run install-fonts && echo "MagicMirror installation finished successfully!
            > magicmirror@2.18.0 install-fonts
            > echo "Installing fonts ...
            > " && cd fonts && npm install --loglevel=error
            up to date, audited 2 packages in 13s
            > magicmirror@2.18.0 prepare
            > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
            no husky installed.
            added 267 packages, and audited 268 packages in 6m
            19 packages are looking for funding
              run `npm fund` for details
              @richard238 and try to run mm again
                Online, but no MM showing.
                pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
                [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                  @richard238 and show log output again?
                  and output of
                  node -v
                  npm -v
                    PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
                    PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                    PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
                    PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                    PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
                    0|MagicMir |
                    0|MagicMir |
                    0|MagicMir |
                    0|MagicMir |
                    0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                    0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                    0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                    0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                    pi@magicmirror:~/MagicMirror $ node -v
                    v17.3.0
                    pi@magicmirror:~/MagicMirror $ npm -v
                    8.3.0
                      @richard238 can u show the ~/MagicMirror/config/config.js
                        config.js, minus private data.
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	address:"0.0.0.0",
                        	ipWhitelist: [],
                        	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                        	language: 'en',
                        	timeFormat: 24,
                        	units: 'metric',
                        			module: 'alert',
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: 'clock',
                        			position: 'top_left'
                        			module: 'calendar',
                        			header: 'Calendar',
                        			position: 'top_left',
                                            maximumEntries: 6, // Total Maximum Entries
                                            maximumNumberOfDays: 365,
                                            displaySymbol: true,
                                            defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                            displayRepeatingCountTitle: false,
                                            defaultRepeatingCountTitle: "",
                                            maxTitleLength: 30,
                                            fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                            animationSpeed: 2000,
                                            fade: true,
                                            showEnd: false,
                                            urgency: 0,
                                            timeFormat: "absolute",
                                            dateFormat: "ddd Do MMMM",
                                            getRelative: 0,
                                            fadePoint: 0.50, // Start on 1/4th of the list.
                                            hidePrivate: false,
                        						symbol: 'calendar-check-o ',
                        						url: 'https:/nnnnnnnnnnnnnnnnnnnnn/basic.ics'
                        			module: 'calendar',
                        			header: 'Binday',
                        			position: 'bottom_left',
                                            maximumEntries: 4, // Total Maximum Entries
                                            maxTitleLength: 30,
                                            fade: true,
                                            showEnd: false,
                                            urgency: 0,
                                            getRelative: 0,
                                            hidePrivate: false,
                        						symbol: 'trash-o ',
                        						url: 'https:/nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn/basic.ics'
                                        titleReplace: {
                                        //	"'s birthday": "",
                                        //	"Recycling": "Bins",
                                            "Red Bin": "Red & Black Bins",
                                            "Green Bin": "Green & Black Bins"
                                        // Override start method.
                                        start: function () {
                                            Log.log("Starting module: " + this.name);
                                            /* This code changed times to 24hr clock until April 17 system update.
                                            ** Set locale.
                                            **  if (config.language === 'en' && config.timeFormat == 24) {
                                            **  config.language = 'en-gb';
                                            ** moment.locale(config.language);
                                            for (var c in this.config.calendars) {
                                                var calendar = this.config.calendars[c];
                                                calendar.url = calendar.url.replace("webcal://", "http://");
                                                this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                            this.calendarData = {};
                                            this.loaded = false;
                        			module: 'compliments',
                        			position: 'lower_third',
                        			anytime: [
                        				"A1",
                                        "A2",
                                        "A3"
                        			morning: [
                        				"M1",
                        				"M2",
                        				"M3"
                        			afternoon: [
                        				"N1",
                        				"N2",
                        				"N3"
                        			evening: [
                        				"E1",
                        				"E2",
                        				"E3"
                        		updateInterval: 30000,
                        		remoteFile: null,
                        		fadeSpeed: 4000
                        			/*config: {
                        				remoteFile: 'compliments.json'
                                    module: 'MMM-doomsDay',
                                    position: 'top_center', // This can be any of the regions, best results in center regions
                                    doomsDay: "2022-01-06 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                    /*            doomsDay: "2020-12-21 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date   */
                                    toWhat: "today",
                        			module: 'currentweather',
                        			header: 'Current weather for: ',
                        			position: 'top_right',
                        				locationID: 'nnnn',  //ID from http://www.openweathermap.org
                        				appid: 'nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn'
                        			module: 'weatherforecast',
                        			header: 'Weather Forecast',
                        				locationID: 'nnnnnnn',  //ID from http://www.openweathermap.org
                        				appid: 'aaannnnnnnnnn'
                                    module: 'MMM-MysqlQuery',
                                    position: 'bottom_right',
                        			header: 'Greenhouse Status',
                                        connection: {
                                            host: "192.168.1.23",
                                            port: 3306,
                                            user: "nnnnnnnnnnnnnnnn",
                                            password: "nnnnnnnnnnnnnnnn",
                                            database: "garage"
                        /*              query: `select Temp-2
                                                from readings
                                                order by ID desc
                                                limit 1`,
                        			query: "select Added, \
                        			Temp, \
                        						Pressure, \
                        						Humidity \
                        						from gh_readings \
                        						order by ID \
                        						desc limit 3",
                            			intervalSeconds: 1 * 60,
                                        emptyMessage: "No data!",
                                        columns: [
                                            { name: "Added",     title: "At", cssClass: "left", dateFormat: "time", dateLocale: "en-GB" },
                                            { name: "Temp",     title: "Temp", cssClass: "left", suffix: "°C", nullValue: "???" },
                                            { name: "Pressure",     title: "Pressure", cssClass: "left", suffix: " hPa", nullValue: "???" },
                                            { name: "Humidity",     title: "Humidity", cssClass: "left", suffix: " %" },
                        			module: 'newsfeed',
                        			position: 'bottom_bar',
                        				feeds: [
                                                title: "BBC World",
                                                url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                                                title: "Al Jazeera",
                                                url: "https://www.aljazeera.com/xml/rss/all.xml"
                                                title: "Sky news",
                                                url: "http://feeds.skynews.com/feeds/rss/world.xml"
                        				showSourceTitle: true,
                        				showPublishDate: true,
                                        reloadInterval:  2 * 60 * 1000, // every 5 minutes
                                        updateInterval: 2 * 5000
                          @richard238 said in v2.18.0 update gave black screen, then nothing.:
                          >                     ** Set locale.
                          what is that? I’m not aware of any code in config for calendar
                          for grins, can you add // in front of the Log.log statement
                            No idea, thought it had always been there. I’m not much of a coder, as I’m sure you can tell.
                            // added
                            PM2        | 2022-01-06T15:51:52: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2022-01-06T15:51:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2022-01-06T15:51:53: PM2 log: pid=18675 msg=process killed
                            PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] online
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir | (node:32542) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                            0|MagicMir | [32574:0106/155207.031878:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                            0|MagicMir | [32615:0106/155207.383004:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                            S 3 Replies Last reply
                              @richard238 added it to me config.js and it doesn’t matter…
                                @richard238 ok, lets start back somewhere
                                save your config.js
                                copy the sample back to config.js
                                and start
                                this should work …
                                  @richard238 i copied your config above to my system
                                  and it starts ok…
                                  my node/npm are
                                  node -v
                                  v16.1.0
                                  npm -v
                                  7.24.2
                                  so, lets try that , we will use the node version of node version manager (nvm) called n
                                  # install n globally
                                  npm i n -g
                                  # install node version 16.1.0
                                  n i 16.1.0
                                  # use the setup path from node version install
                                  PATH="$PATH"
                                  # verify node and npm versions
                                  node -v
                                  npm -v
                                    run those from
                                    or
                                    pi@magicmirror:~ $
                                    Or, does it not matter?
                                    S 2 Replies Last reply
                                      @richard238 does not matter
                                      not MM specific
                                        @richard238 did u try the initial config.js
                                          No, took me a while to restore one back from archive, but it’s there now, ready to go.
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: 'en',
                                          	timeFormat: 24,
                                          	units: 'metric',
                                          			module: 'alert',
                                          			position: "top_bar"
                                          			module: 'clock',
                                          			module: 'calendar',
                                          			header: 'US Holidays',
                                          				locationID: '',  //ID from http://www.openweathermap.org
                                          				appid: 'YOUR_OPENWEATHER_API_KEY'
                                          				locationID: '5128581',  //ID from http://www.openweathermap.org
                                          			module: 'newsfeed',
                                          				feeds: [
                                          						title: "New York Times",
                                          My versions:
                                          pi@magicmirror:~ $ node -v
                                          v16.1.0
                                          pi@magicmirror:~ $ npm -v
                                          7.11.2
                                          NPM is different to yours, but OK to try?
                                            in the config folder is the config.js.sample file which is what I wanted you to use
                                            just to eliminate other things,
                                            but
                                            npm start
                                            may have to clean and nom install again as node version changed…
                                            • 2 / 4
