    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 47.7k Views 4 Watching
      Richard238 @sdetweil
      config.js, minus private data.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	address:"0.0.0.0",
      	ipWhitelist: [],
      	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
      	language: 'en',
      	timeFormat: 24,
      	units: 'metric',
      			module: 'alert',
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar',
      			header: 'Calendar',
      			position: 'top_left',
                          maximumEntries: 6, // Total Maximum Entries
                          maximumNumberOfDays: 365,
                          displaySymbol: true,
                          defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                          displayRepeatingCountTitle: false,
                          defaultRepeatingCountTitle: "",
                          maxTitleLength: 30,
                          fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                          animationSpeed: 2000,
                          fade: true,
                          showEnd: false,
                          urgency: 0,
                          timeFormat: "absolute",
                          dateFormat: "ddd Do MMMM",
                          getRelative: 0,
                          fadePoint: 0.50, // Start on 1/4th of the list.
                          hidePrivate: false,
      						symbol: 'calendar-check-o ',
      						url: 'https:/nnnnnnnnnnnnnnnnnnnnn/basic.ics'
      			module: 'calendar',
      			header: 'Binday',
      			position: 'bottom_left',
                          maximumEntries: 4, // Total Maximum Entries
                          maxTitleLength: 30,
                          fade: true,
                          showEnd: false,
                          urgency: 0,
                          getRelative: 0,
                          hidePrivate: false,
      						symbol: 'trash-o ',
      						url: 'https:/nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn/basic.ics'
                      titleReplace: {
                      //	"'s birthday": "",
                      //	"Recycling": "Bins",
                          "Red Bin": "Red & Black Bins",
                          "Green Bin": "Green & Black Bins"
                      // Override start method.
                      start: function () {
                          Log.log("Starting module: " + this.name);
                          /* This code changed times to 24hr clock until April 17 system update.
                          ** Set locale.
                          **  if (config.language === 'en' && config.timeFormat == 24) {
                          **  config.language = 'en-gb';
                          ** moment.locale(config.language);
                          for (var c in this.config.calendars) {
                              var calendar = this.config.calendars[c];
                              calendar.url = calendar.url.replace("webcal://", "http://");
                              this.addCalendar(calendar.url, calendar.user, calendar.pass);
                          this.calendarData = {};
                          this.loaded = false;
      			module: 'compliments',
      			position: 'lower_third',
      			anytime: [
      				"A1",
                      "A2",
                      "A3"
      			morning: [
      				"M1",
      				"M2",
      				"M3"
      			afternoon: [
      				"N1",
      				"N2",
      				"N3"
      			evening: [
      				"E1",
      				"E2",
      				"E3"
      		updateInterval: 30000,
      		remoteFile: null,
      		fadeSpeed: 4000
      			/*config: {
      				remoteFile: 'compliments.json'
                  module: 'MMM-doomsDay',
                  position: 'top_center', // This can be any of the regions, best results in center regions
                  doomsDay: "2022-01-06 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                  /*            doomsDay: "2020-12-21 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date   */
                  toWhat: "today",
      			module: 'currentweather',
      			header: 'Current weather for: ',
      			position: 'top_right',
      				locationID: 'nnnn',  //ID from http://www.openweathermap.org
      				appid: 'nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn'
      			module: 'weatherforecast',
      			header: 'Weather Forecast',
      				locationID: 'nnnnnnn',  //ID from http://www.openweathermap.org
      				appid: 'aaannnnnnnnnn'
                  module: 'MMM-MysqlQuery',
                  position: 'bottom_right',
      			header: 'Greenhouse Status',
                      connection: {
                          host: "192.168.1.23",
                          port: 3306,
                          user: "nnnnnnnnnnnnnnnn",
                          password: "nnnnnnnnnnnnnnnn",
                          database: "garage"
      /*              query: `select Temp-2
                              from readings
                              order by ID desc
                              limit 1`,
      			query: "select Added, \
      			Temp, \
      						Pressure, \
      						Humidity \
      						from gh_readings \
      						order by ID \
      						desc limit 3",
          			intervalSeconds: 1 * 60,
                      emptyMessage: "No data!",
                      columns: [
                          { name: "Added",     title: "At", cssClass: "left", dateFormat: "time", dateLocale: "en-GB" },
                          { name: "Temp",     title: "Temp", cssClass: "left", suffix: "°C", nullValue: "???" },
                          { name: "Pressure",     title: "Pressure", cssClass: "left", suffix: " hPa", nullValue: "???" },
                          { name: "Humidity",     title: "Humidity", cssClass: "left", suffix: " %" },
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
                              title: "BBC World",
                              url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                              title: "Al Jazeera",
                              url: "https://www.aljazeera.com/xml/rss/all.xml"
                              title: "Sky news",
                              url: "http://feeds.skynews.com/feeds/rss/world.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
                      reloadInterval:  2 * 60 * 1000, // every 5 minutes
                      updateInterval: 2 * 5000
        sdetweil @Richard238
        @richard238 said in v2.18.0 update gave black screen, then nothing.:
        >                     ** Set locale.
        what is that? I’m not aware of any code in config for calendar
        for grins, can you add // in front of the Log.log statement
        R 1 Reply Last reply
          No idea, thought it had always been there. I’m not much of a coder, as I’m sure you can tell.
          // added
          pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          [PM2] Process successfully started
          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
          │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
          pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
          [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
          /home/pi/.pm2/pm2.log last 50 lines:
          PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
          PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
          PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
          PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
          PM2        | 2022-01-06T15:51:52: PM2 log: Stopping app:MagicMirror id:0
          PM2        | 2022-01-06T15:51:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          PM2        | 2022-01-06T15:51:53: PM2 log: pid=18675 msg=process killed
          PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] online
          /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
          0|MagicMir |
          0|MagicMir | > magicmirror@2.18.0 start
          0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          0|MagicMir |
          0|MagicMir |
          0|MagicMir |
          0|MagicMir |
          0|MagicMir |
          /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
          0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
          0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
          0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
          0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
          0|MagicMir | A JavaScript error occurred in the main process
          0|MagicMir | Uncaught Exception:
          0|MagicMir | TypeError: Log.log is not a function
          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
          0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
          0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
          0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
          0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
          0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
          0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
          0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          0|MagicMir | App threw an error during load
          0|MagicMir | (node:32542) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
          0|MagicMir | [32574:0106/155207.031878:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          0|MagicMir | [32615:0106/155207.383004:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
          S 3 Replies Last reply
            @richard238 added it to me config.js and it doesn’t matter…
              @richard238 ok, lets start back somewhere
              save your config.js
              copy the sample back to config.js
              and start
              this should work …
                @richard238 i copied your config above to my system
                and it starts ok…
                my node/npm are
                node -v
                v16.1.0
                npm -v
                7.24.2
                so, lets try that , we will use the node version of node version manager (nvm) called n
                # install n globally
                npm i n -g
                # install node version 16.1.0
                n i 16.1.0
                # use the setup path from node version install
                PATH="$PATH"
                # verify node and npm versions
                node -v
                npm -v
                  run those from
                  or
                  pi@magicmirror:~ $
                  Or, does it not matter?
                  S 2 Replies Last reply
                    @richard238 does not matter
                    not MM specific
                      @richard238 did u try the initial config.js
                        No, took me a while to restore one back from archive, but it’s there now, ready to go.
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: 'en',
                        	timeFormat: 24,
                        	units: 'metric',
                        			module: 'alert',
                        			position: "top_bar"
                        			module: 'clock',
                        			module: 'calendar',
                        			header: 'US Holidays',
                        				locationID: '',  //ID from http://www.openweathermap.org
                        				appid: 'YOUR_OPENWEATHER_API_KEY'
                        				locationID: '5128581',  //ID from http://www.openweathermap.org
                        			module: 'newsfeed',
                        				feeds: [
                        						title: "New York Times",
                        My versions:
                        pi@magicmirror:~ $ node -v
                        v16.1.0
                        pi@magicmirror:~ $ npm -v
                        7.11.2
                        NPM is different to yours, but OK to try?
                          in the config folder is the config.js.sample file which is what I wanted you to use
                          just to eliminate other things,
                          but
                          npm start
                          may have to clean and nom install again as node version changed…
                            It’s still throwing the log.log error!
                            pi@magicmirror:~/MagicMirror $ npm start
                            (node:6752) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                            Uncaught Exception:
                            [6808:0106/162138.316545:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                            [6828:0106/162138.716857:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                              @richard238 ok, fun times…
                              so, do
                              cd ~
                              mv MagicMirror MagicMirror.save
                              git clone  https://github.com/MichMich/MagicMirror.git
                              cd MagicMirror
                              npm install --only=prod
                              cd config
                              cp config.js.sample config.js
                              cd ..
                              then npm start
                                Clean install - works perfectly! :)
                                pi@magicmirror:~/MagicMirror $ cd config
                                pi@magicmirror:~/MagicMirror/config $ cp config.js.sample config.js
                                pi@magicmirror:~/MagicMirror/config $ cd ..
                                [06.01.2022 16:30.01.197] [LOG]   Starting MagicMirror: v2.18.0
                                [06.01.2022 16:30.01.222] [LOG]   Loading config ...
                                [06.01.2022 16:30.01.238] [LOG]   Loading module helpers ...
                                [06.01.2022 16:30.01.243] [LOG]   No helper found for module: alert.
                                [06.01.2022 16:30.01.307] [LOG]   Initializing new module helper ...
                                [06.01.2022 16:30.01.311] [LOG]   Module helper loaded: updatenotification
                                [06.01.2022 16:30.01.315] [LOG]   No helper found for module: clock.
                                [06.01.2022 16:30.01.765] [LOG]   Initializing new module helper ...
                                [06.01.2022 16:30.01.768] [LOG]   Module helper loaded: calendar
                                [06.01.2022 16:30.01.771] [LOG]   No helper found for module: compliments.
                                [06.01.2022 16:30.01.773] [LOG]   No helper found for module: weather.
                                [06.01.2022 16:30.01.843] [LOG]   Initializing new module helper ...
                                [06.01.2022 16:30.01.845] [LOG]   Module helper loaded: newsfeed
                                [06.01.2022 16:30.01.848] [LOG]   All module helpers loaded.
                                [06.01.2022 16:30.02.152] [LOG]   Starting server on port 8080 ...
                                [06.01.2022 16:30.02.183] [LOG]   Server started ...
                                [06.01.2022 16:30.02.185] [LOG]   Connecting socket for: updatenotification
                                [06.01.2022 16:30.02.187] [LOG]   Starting module helper: updatenotification
                                [06.01.2022 16:30.02.189] [LOG]   Connecting socket for: calendar
                                [06.01.2022 16:30.02.190] [LOG]   Starting node helper for: calendar
                                [06.01.2022 16:30.02.191] [LOG]   Connecting socket for: newsfeed
                                [06.01.2022 16:30.02.192] [LOG]   Starting node helper for: newsfeed
                                [06.01.2022 16:30.02.193] [LOG]   Sockets connected & modules started ...
                                [06.01.2022 16:30.02.845] [LOG]   Launching application.
                                [8846:0106/163005.246382:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                [8886:0106/163005.631441:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                [06.01.2022 16:30.12.077] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                [06.01.2022 16:30.12.157] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                [06.01.2022 16:30.12.258] [INFO]  Checking git for module: default
                                [06.01.2022 16:30.13.590] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                                [06.01.2022 16:30.13.638] [INFO]  Newsfeed-Fetcher: Broadcasting 64 items.
                                  @richard238 ok!.. run this to get rid of the sandbox problem
                                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                                  then
                                  cd ~/MagicMirror/modules
                                  # save the new default modules folder
                                  mv default default.new
                                  cd ..
                                  # copy all the modules from old install (incl default) preserve ownership and dates, need sudo to copy git info
                                  sudo cp -r -p ~/MagicMirror.save/modules/* modules
                                  cd modules
                                  # remove the copied default modules
                                  rm -rf default
                                  # restore the saved default
                                  mv default.new default
                                  copy your full function config.js to MagicMirror/config
                                  and try it out
                                  npm start
                                    pi@magicmirror:~ $ cd ~/MagicMirror/modules
                                    pi@magicmirror:~/MagicMirror/modules $ mv default default.new
                                    pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/* modules
                                    cp: target 'modules' is not a directory
                                    Tried it without the space…
                                    pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/*modules
                                    cp: missing destination file operand after '/home/pi/MagicMirror.save/modules/*modules'
                                    Try 'cp --help' for more information.
                                      Richard238 @Richard238
                                      @richard238
                                      I have to leave shortly Sam.
                                      Thank you for all your help with this today, I’ll try again tomorrow.
                                      Richard.
                                        @richard238 ok
                                        you forgot the cd …
                                        cd ..
                                          Trying to rename config.js to sample,
                                          Error when getting information for file “/home/pi/MagicMirror/config/config.js”: No such file or directory
                                          Error renaming file /home/pi/MagicMirror/config/config.js: No such file or directory
                                          Yet I can see it, I can query it for permissions…
                                          Back tomorrow.
                                          Richard.
                                            you need to copy from save
                                            cd ~/MagicMirror.save/config
                                            cp -p config.js ~/Magicmirror/config
                                            • 3 / 4
