    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 46.5k Views 4 Watching
      sdetweil @Richard238
      @richard238 added it to me config.js and it doesn’t matter…
        @richard238 ok, lets start back somewhere
        save your config.js
        copy the sample back to config.js
        and start
        this should work …
          @richard238 i copied your config above to my system
          and it starts ok…
          my node/npm are
          node -v
          v16.1.0
          npm -v
          7.24.2
          so, lets try that , we will use the node version of node version manager (nvm) called n
          # install n globally
          npm i n -g
          # install node version 16.1.0
          n i 16.1.0
          # use the setup path from node version install
          PATH="$PATH"
          # verify node and npm versions
          node -v
          npm -v
            Richard238 @sdetweil
            run those from
            pi@magicmirror:~/MagicMirror $
            or
            pi@magicmirror:~ $
            Or, does it not matter?
              @richard238 does not matter
              not MM specific
                @richard238 did u try the initial config.js
                  No, took me a while to restore one back from archive, but it’s there now, ready to go.
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: 'en',
                  	timeFormat: 24,
                  	units: 'metric',
                  			module: 'alert',
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: 'clock',
                  			position: 'top_left'
                  			module: 'calendar',
                  			header: 'US Holidays',
                  			position: 'top_left',
                  						symbol: 'calendar-check-o ',
                  			module: 'compliments',
                  			position: 'lower_third'
                  			module: 'currentweather',
                  			position: 'top_right',
                  				locationID: '',  //ID from http://www.openweathermap.org
                  				appid: 'YOUR_OPENWEATHER_API_KEY'
                  			module: 'weatherforecast',
                  			header: 'Weather Forecast',
                  				locationID: '5128581',  //ID from http://www.openweathermap.org
                  			module: 'newsfeed',
                  			position: 'bottom_bar',
                  				feeds: [
                  						title: "New York Times",
                  				showSourceTitle: true,
                  				showPublishDate: true
                  My versions:
                  pi@magicmirror:~ $ node -v
                  v16.1.0
                  pi@magicmirror:~ $ npm -v
                  7.11.2
                  NPM is different to yours, but OK to try?
                    @richard238 said in v2.18.0 update gave black screen, then nothing.:
                    in the config folder is the config.js.sample file which is what I wanted you to use
                    just to eliminate other things,
                    but
                    npm start
                    may have to clean and nom install again as node version changed…
                      It’s still throwing the log.log error!
                      pi@magicmirror:~/MagicMirror $ npm start
                      > magicmirror@2.18.0 start
                      App threw an error during load
                      TypeError: Log.log is not a function
                          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
                          at Module._compile (node:internal/modules/cjs/loader:1116:14)
                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                          at Module.load (node:internal/modules/cjs/loader:988:32)
                          at Module._load (node:internal/modules/cjs/loader:829:12)
                          at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                          at Module.require (node:internal/modules/cjs/loader:1012:19)
                          at require (node:internal/modules/cjs/helpers:94:18)
                          at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
                      (node:6752) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                      (Use `electron --trace-deprecation ...` to show where the warning was created)
                      A JavaScript error occurred in the main process
                      Uncaught Exception:
                      [6808:0106/162138.316545:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                      [6828:0106/162138.716857:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                        @richard238 ok, fun times…
                        so, do
                        cd ~
                        mv MagicMirror MagicMirror.save
                        git clone  https://github.com/MichMich/MagicMirror.git
                        cd MagicMirror
                        npm install --only=prod
                        cd config
                        cp config.js.sample config.js
                        cd ..
                        then npm start
                          Clean install - works perfectly! :)
                          pi@magicmirror:~/MagicMirror $ cd config
                          pi@magicmirror:~/MagicMirror/config $ cp config.js.sample config.js
                          pi@magicmirror:~/MagicMirror/config $ cd ..
                          [06.01.2022 16:30.01.197] [LOG]   Starting MagicMirror: v2.18.0
                          [06.01.2022 16:30.01.222] [LOG]   Loading config ...
                          [06.01.2022 16:30.01.238] [LOG]   Loading module helpers ...
                          [06.01.2022 16:30.01.243] [LOG]   No helper found for module: alert.
                          [06.01.2022 16:30.01.307] [LOG]   Initializing new module helper ...
                          [06.01.2022 16:30.01.311] [LOG]   Module helper loaded: updatenotification
                          [06.01.2022 16:30.01.315] [LOG]   No helper found for module: clock.
                          [06.01.2022 16:30.01.765] [LOG]   Initializing new module helper ...
                          [06.01.2022 16:30.01.768] [LOG]   Module helper loaded: calendar
                          [06.01.2022 16:30.01.771] [LOG]   No helper found for module: compliments.
                          [06.01.2022 16:30.01.773] [LOG]   No helper found for module: weather.
                          [06.01.2022 16:30.01.843] [LOG]   Initializing new module helper ...
                          [06.01.2022 16:30.01.845] [LOG]   Module helper loaded: newsfeed
                          [06.01.2022 16:30.01.848] [LOG]   All module helpers loaded.
                          [06.01.2022 16:30.02.152] [LOG]   Starting server on port 8080 ...
                          [06.01.2022 16:30.02.183] [LOG]   Server started ...
                          [06.01.2022 16:30.02.185] [LOG]   Connecting socket for: updatenotification
                          [06.01.2022 16:30.02.187] [LOG]   Starting module helper: updatenotification
                          [06.01.2022 16:30.02.189] [LOG]   Connecting socket for: calendar
                          [06.01.2022 16:30.02.190] [LOG]   Starting node helper for: calendar
                          [06.01.2022 16:30.02.191] [LOG]   Connecting socket for: newsfeed
                          [06.01.2022 16:30.02.192] [LOG]   Starting node helper for: newsfeed
                          [06.01.2022 16:30.02.193] [LOG]   Sockets connected & modules started ...
                          [06.01.2022 16:30.02.845] [LOG]   Launching application.
                          [8846:0106/163005.246382:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                          [8886:0106/163005.631441:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                          [06.01.2022 16:30.12.077] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                          [06.01.2022 16:30.12.157] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                          [06.01.2022 16:30.12.258] [INFO]  Checking git for module: default
                          [06.01.2022 16:30.13.590] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                          [06.01.2022 16:30.13.638] [INFO]  Newsfeed-Fetcher: Broadcasting 64 items.
                            @richard238 ok!.. run this to get rid of the sandbox problem
                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                            then
                            cd ~/MagicMirror/modules
                            # save the new default modules folder
                            mv default default.new
                            cd ..
                            # copy all the modules from old install (incl default) preserve ownership and dates, need sudo to copy git info
                            sudo cp -r -p ~/MagicMirror.save/modules/* modules
                            cd modules
                            # remove the copied default modules
                            rm -rf default
                            # restore the saved default
                            mv default.new default
                            copy your full function config.js to MagicMirror/config
                            and try it out
                            npm start
                              pi@magicmirror:~ $ cd ~/MagicMirror/modules
                              pi@magicmirror:~/MagicMirror/modules $ mv default default.new
                              pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/* modules
                              cp: target 'modules' is not a directory
                              Tried it without the space…
                              pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/*modules
                              cp: missing destination file operand after '/home/pi/MagicMirror.save/modules/*modules'
                              Try 'cp --help' for more information.
                                Richard238 @Richard238
                                @richard238
                                I have to leave shortly Sam.
                                Thank you for all your help with this today, I’ll try again tomorrow.
                                Richard.
                                  @richard238 ok
                                  you forgot the cd …
                                  cd ..
                                    Trying to rename config.js to sample,
                                    Error when getting information for file “/home/pi/MagicMirror/config/config.js”: No such file or directory
                                    Error renaming file /home/pi/MagicMirror/config/config.js: No such file or directory
                                    Yet I can see it, I can query it for permissions…
                                    Back tomorrow.
                                    Richard.
                                      you need to copy from save
                                      cd ~/MagicMirror.save/config
                                      cp -p config.js ~/Magicmirror/config
                                        Good morning Sam.
                                        Tried that late yesterday, and yes, it works.
                                        And this morning, I copied
                                        custom.css
                                        from
                                        /home/pi/MagicMirror.save/css
                                        to
                                        /home/pi/MagicMirror/css
                                        This too is working perfectly.
                                        Is there anything else to do, housekeeping maybe, or is that it now?
                                          @richard238 if everything is running ok then I think you are done, and can delete the
                                          MagicMirror.save folder
                                            Ok, I’ll do that then.
                                            Do we know what the cause of all this was, was it something to do with a mismatch in versions of node and npm?
                                            • 3 / 4
