    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 45.4k Views 4 Watching
      sdetweil @Richard238
      @richard238 can u show the ~/MagicMirror/config/config.js
        Richard238 @sdetweil
        config.js, minus private data.
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	address:"0.0.0.0",
        	ipWhitelist: [],
        	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
        	language: 'en',
        	timeFormat: 24,
        	units: 'metric',
        			module: 'alert',
        			module: "updatenotification",
        			position: "top_bar"
        			module: 'clock',
        			position: 'top_left'
        			module: 'calendar',
        			header: 'Calendar',
        			position: 'top_left',
                            maximumEntries: 6, // Total Maximum Entries
                            maximumNumberOfDays: 365,
                            displaySymbol: true,
                            defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                            displayRepeatingCountTitle: false,
                            defaultRepeatingCountTitle: "",
                            maxTitleLength: 30,
                            fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                            animationSpeed: 2000,
                            fade: true,
                            showEnd: false,
                            urgency: 0,
                            timeFormat: "absolute",
                            dateFormat: "ddd Do MMMM",
                            getRelative: 0,
                            fadePoint: 0.50, // Start on 1/4th of the list.
                            hidePrivate: false,
        						symbol: 'calendar-check-o ',
        						url: 'https:/nnnnnnnnnnnnnnnnnnnnn/basic.ics'
        			module: 'calendar',
        			header: 'Binday',
        			position: 'bottom_left',
                            maximumEntries: 4, // Total Maximum Entries
                            maxTitleLength: 30,
                            fade: true,
                            showEnd: false,
                            urgency: 0,
                            getRelative: 0,
                            hidePrivate: false,
        						symbol: 'trash-o ',
        						url: 'https:/nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn/basic.ics'
                        titleReplace: {
                        //	"'s birthday": "",
                        //	"Recycling": "Bins",
                            "Red Bin": "Red & Black Bins",
                            "Green Bin": "Green & Black Bins"
                        // Override start method.
                        start: function () {
                            Log.log("Starting module: " + this.name);
                            /* This code changed times to 24hr clock until April 17 system update.
                            ** Set locale.
                            **  if (config.language === 'en' && config.timeFormat == 24) {
                            **  config.language = 'en-gb';
                            ** moment.locale(config.language);
                            for (var c in this.config.calendars) {
                                var calendar = this.config.calendars[c];
                                calendar.url = calendar.url.replace("webcal://", "http://");
                                this.addCalendar(calendar.url, calendar.user, calendar.pass);
                            this.calendarData = {};
                            this.loaded = false;
        			module: 'compliments',
        			position: 'lower_third',
        			anytime: [
        				"A1",
                        "A2",
                        "A3"
        			morning: [
        				"M1",
        				"M2",
        				"M3"
        			afternoon: [
        				"N1",
        				"N2",
        				"N3"
        			evening: [
        				"E1",
        				"E2",
        				"E3"
        		updateInterval: 30000,
        		remoteFile: null,
        		fadeSpeed: 4000
        			/*config: {
        				remoteFile: 'compliments.json'
                    module: 'MMM-doomsDay',
                    position: 'top_center', // This can be any of the regions, best results in center regions
                    doomsDay: "2022-01-06 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                    /*            doomsDay: "2020-12-21 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date   */
                    toWhat: "today",
        			module: 'currentweather',
        			header: 'Current weather for: ',
        			position: 'top_right',
        				locationID: 'nnnn',  //ID from http://www.openweathermap.org
        				appid: 'nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn'
        			module: 'weatherforecast',
        			header: 'Weather Forecast',
        				locationID: 'nnnnnnn',  //ID from http://www.openweathermap.org
        				appid: 'aaannnnnnnnnn'
                    module: 'MMM-MysqlQuery',
                    position: 'bottom_right',
        			header: 'Greenhouse Status',
                        connection: {
                            host: "192.168.1.23",
                            port: 3306,
                            user: "nnnnnnnnnnnnnnnn",
                            password: "nnnnnnnnnnnnnnnn",
                            database: "garage"
        /*              query: `select Temp-2
                                from readings
                                order by ID desc
                                limit 1`,
        			query: "select Added, \
        			Temp, \
        						Pressure, \
        						Humidity \
        						from gh_readings \
        						order by ID \
        						desc limit 3",
            			intervalSeconds: 1 * 60,
                        emptyMessage: "No data!",
                        columns: [
                            { name: "Added",     title: "At", cssClass: "left", dateFormat: "time", dateLocale: "en-GB" },
                            { name: "Temp",     title: "Temp", cssClass: "left", suffix: "°C", nullValue: "???" },
                            { name: "Pressure",     title: "Pressure", cssClass: "left", suffix: " hPa", nullValue: "???" },
                            { name: "Humidity",     title: "Humidity", cssClass: "left", suffix: " %" },
        			module: 'newsfeed',
        			position: 'bottom_bar',
        				feeds: [
                                title: "BBC World",
                                url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                                title: "Al Jazeera",
                                url: "https://www.aljazeera.com/xml/rss/all.xml"
                                title: "Sky news",
                                url: "http://feeds.skynews.com/feeds/rss/world.xml"
        				showSourceTitle: true,
        				showPublishDate: true,
                        reloadInterval:  2 * 60 * 1000, // every 5 minutes
                        updateInterval: 2 * 5000
          @richard238 said in v2.18.0 update gave black screen, then nothing.:
          >                     ** Set locale.
          what is that? I’m not aware of any code in config for calendar
          for grins, can you add // in front of the Log.log statement
            No idea, thought it had always been there. I’m not much of a coder, as I’m sure you can tell.
            // added
            pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            [PM2] Process successfully started
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
            pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
            [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
            /home/pi/.pm2/pm2.log last 50 lines:
            PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
            PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
            PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
            PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
            PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
            PM2        | 2022-01-06T15:51:52: PM2 log: Stopping app:MagicMirror id:0
            PM2        | 2022-01-06T15:51:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
            PM2        | 2022-01-06T15:51:53: PM2 log: pid=18675 msg=process killed
            PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] online
            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
            0|MagicMir |
            0|MagicMir | > magicmirror@2.18.0 start
            0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            0|MagicMir |
            0|MagicMir |
            0|MagicMir |
            0|MagicMir |
            0|MagicMir |
            /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
            0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
            0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
            0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
            0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
            0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
            0|MagicMir | A JavaScript error occurred in the main process
            0|MagicMir | Uncaught Exception:
            0|MagicMir | TypeError: Log.log is not a function
            0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
            0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
            0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
            0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
            0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
            0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
            0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
            0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
            0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
            0|MagicMir | App threw an error during load
            0|MagicMir | (node:32542) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
            0|MagicMir | [32574:0106/155207.031878:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
            0|MagicMir | [32615:0106/155207.383004:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
            S 3 Replies Last reply Reply Quote 0
              @richard238 added it to me config.js and it doesn’t matter…
                @richard238 ok, lets start back somewhere
                save your config.js
                copy the sample back to config.js
                and start
                this should work …
                  @richard238 i copied your config above to my system
                  and it starts ok…
                  my node/npm are
                  node -v
                  v16.1.0
                  npm -v
                  7.24.2
                  so, lets try that , we will use the node version of node version manager (nvm) called n
                  # install n globally
                  npm i n -g
                  # install node version 16.1.0
                  n i 16.1.0
                  # use the setup path from node version install
                  PATH="$PATH"
                  # verify node and npm versions
                  node -v
                  npm -v
                    run those from
                    or
                    pi@magicmirror:~ $
                    Or, does it not matter?
                      @richard238 does not matter
                      not MM specific
                        @richard238 did u try the initial config.js
                          No, took me a while to restore one back from archive, but it’s there now, ready to go.
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	language: 'en',
                          	timeFormat: 24,
                          	units: 'metric',
                          			module: 'alert',
                          			position: "top_bar"
                          			module: 'clock',
                          			module: 'calendar',
                          			header: 'US Holidays',
                          				locationID: '',  //ID from http://www.openweathermap.org
                          				appid: 'YOUR_OPENWEATHER_API_KEY'
                          				locationID: '5128581',  //ID from http://www.openweathermap.org
                          			module: 'newsfeed',
                          				feeds: [
                          						title: "New York Times",
                          My versions:
                          pi@magicmirror:~ $ node -v
                          v16.1.0
                          pi@magicmirror:~ $ npm -v
                          7.11.2
                          NPM is different to yours, but OK to try?
                            in the config folder is the config.js.sample file which is what I wanted you to use
                            just to eliminate other things,
                            but
                            npm start
                            may have to clean and nom install again as node version changed…
                              It’s still throwing the log.log error!
                              pi@magicmirror:~/MagicMirror $ npm start
                              (node:6752) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                              Uncaught Exception:
                              [6808:0106/162138.316545:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                              [6828:0106/162138.716857:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                @richard238 ok, fun times…
                                so, do
                                cd ~
                                mv MagicMirror MagicMirror.save
                                git clone  https://github.com/MichMich/MagicMirror.git
                                cd MagicMirror
                                npm install --only=prod
                                cd config
                                cp config.js.sample config.js
                                cd ..
                                then npm start
                                  Clean install - works perfectly! :)
                                  pi@magicmirror:~/MagicMirror $ cd config
                                  pi@magicmirror:~/MagicMirror/config $ cp config.js.sample config.js
                                  pi@magicmirror:~/MagicMirror/config $ cd ..
                                  [06.01.2022 16:30.01.197] [LOG]   Starting MagicMirror: v2.18.0
                                  [06.01.2022 16:30.01.222] [LOG]   Loading config ...
                                  [06.01.2022 16:30.01.238] [LOG]   Loading module helpers ...
                                  [06.01.2022 16:30.01.243] [LOG]   No helper found for module: alert.
                                  [06.01.2022 16:30.01.307] [LOG]   Initializing new module helper ...
                                  [06.01.2022 16:30.01.311] [LOG]   Module helper loaded: updatenotification
                                  [06.01.2022 16:30.01.315] [LOG]   No helper found for module: clock.
                                  [06.01.2022 16:30.01.765] [LOG]   Initializing new module helper ...
                                  [06.01.2022 16:30.01.768] [LOG]   Module helper loaded: calendar
                                  [06.01.2022 16:30.01.771] [LOG]   No helper found for module: compliments.
                                  [06.01.2022 16:30.01.773] [LOG]   No helper found for module: weather.
                                  [06.01.2022 16:30.01.843] [LOG]   Initializing new module helper ...
                                  [06.01.2022 16:30.01.845] [LOG]   Module helper loaded: newsfeed
                                  [06.01.2022 16:30.01.848] [LOG]   All module helpers loaded.
                                  [06.01.2022 16:30.02.152] [LOG]   Starting server on port 8080 ...
                                  [06.01.2022 16:30.02.183] [LOG]   Server started ...
                                  [06.01.2022 16:30.02.185] [LOG]   Connecting socket for: updatenotification
                                  [06.01.2022 16:30.02.187] [LOG]   Starting module helper: updatenotification
                                  [06.01.2022 16:30.02.189] [LOG]   Connecting socket for: calendar
                                  [06.01.2022 16:30.02.190] [LOG]   Starting node helper for: calendar
                                  [06.01.2022 16:30.02.191] [LOG]   Connecting socket for: newsfeed
                                  [06.01.2022 16:30.02.192] [LOG]   Starting node helper for: newsfeed
                                  [06.01.2022 16:30.02.193] [LOG]   Sockets connected & modules started ...
                                  [06.01.2022 16:30.02.845] [LOG]   Launching application.
                                  [8846:0106/163005.246382:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                  [8886:0106/163005.631441:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                  [06.01.2022 16:30.12.077] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                  [06.01.2022 16:30.12.157] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                  [06.01.2022 16:30.12.258] [INFO]  Checking git for module: default
                                  [06.01.2022 16:30.13.590] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                                  [06.01.2022 16:30.13.638] [INFO]  Newsfeed-Fetcher: Broadcasting 64 items.
                                    @richard238 ok!.. run this to get rid of the sandbox problem
                                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                                    then
                                    cd ~/MagicMirror/modules
                                    # save the new default modules folder
                                    mv default default.new
                                    cd ..
                                    # copy all the modules from old install (incl default) preserve ownership and dates, need sudo to copy git info
                                    sudo cp -r -p ~/MagicMirror.save/modules/* modules
                                    cd modules
                                    # remove the copied default modules
                                    rm -rf default
                                    # restore the saved default
                                    mv default.new default
                                    copy your full function config.js to MagicMirror/config
                                    and try it out
                                    npm start
                                      pi@magicmirror:~ $ cd ~/MagicMirror/modules
                                      pi@magicmirror:~/MagicMirror/modules $ mv default default.new
                                      pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/* modules
                                      cp: target 'modules' is not a directory
                                      Tried it without the space…
                                      pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/*modules
                                      cp: missing destination file operand after '/home/pi/MagicMirror.save/modules/*modules'
                                      Try 'cp --help' for more information.
                                        Richard238 @Richard238
                                        @richard238
                                        I have to leave shortly Sam.
                                        Thank you for all your help with this today, I’ll try again tomorrow.
                                        Richard.
                                          @richard238 ok
                                          you forgot the cd …
                                          cd ..
                                            Trying to rename config.js to sample,
                                            Error when getting information for file “/home/pi/MagicMirror/config/config.js”: No such file or directory
                                            Error renaming file /home/pi/MagicMirror/config/config.js: No such file or directory
                                            Yet I can see it, I can query it for permissions…
                                            Back tomorrow.
                                            Richard.
                                            • 3 / 4
