    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 44.1k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @Richard238
      @richard238 seems like styleint is giving issues, Can you just try and install mysql and see if that resolves your issue?
        Richard238 @mumblebaj
        @mumblebaj
        Install mysql - how and where?
        Apologies for the detail request, but having got this far, I don’t want to break anything else.
        Thank you.
          @richard238 In the MMM-MysqlQuery folder, npm i mysql
            @mumblebaj
            pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql
            npm ERR! code ERESOLVE
            npm ERR! ERESOLVE unable to resolve dependency tree
            npm ERR!
            npm ERR! While resolving: mmm-mysqlquery@1.0.0
            npm ERR! Found: stylelint@8.4.0
            npm ERR! node_modules/stylelint
            npm ERR!   dev stylelint@"^8.3.0" from the root project
            npm ERR!
            npm ERR! Could not resolve dependency:
            npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
            npm ERR! node_modules/grunt-stylelint
            npm ERR!   dev grunt-stylelint@"latest" from the root project
            npm ERR!
            npm ERR! Fix the upstream dependency conflict, or retry
            npm ERR! this command with --force, or --legacy-peer-deps
            npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
            npm ERR!
            npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
            npm ERR!     /home/pi/.npm/_logs/2022-01-06T14_02_53_804Z-debug-0.log
              @richard238 run npm i mysql --force The stylint is a dev dependency.
              R S 2 Replies Last reply Reply Quote 0
                @mumblebaj
                Looking better…
                pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql --force
                npm WARN using --force Recommended protections disabled.
                npm WARN ERESOLVE overriding peer dependency
                npm WARN While resolving: grunt-stylelint@0.17.0
                npm WARN Found: stylelint@8.4.0
                npm WARN node_modules/stylelint
                npm WARN   dev stylelint@"^8.3.0" from the root project
                npm WARN
                npm WARN Could not resolve dependency:
                npm WARN peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
                npm WARN node_modules/grunt-stylelint
                npm WARN   dev grunt-stylelint@"latest" from the root project
                npm WARN
                npm WARN Conflicting peer dependency: stylelint@14.2.0
                npm WARN While resolving: stylelint-config-standard@24.0.0
                npm WARN
                npm WARN peer stylelint@"^14.0.0" from stylelint-config-standard@24.0.0
                npm WARN node_modules/stylelint-config-standard
                npm WARN   dev stylelint-config-standard@"latest" from the root project
                npm WARN
                npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                added 606 packages, and audited 1043 packages in 3m
                49 packages are looking for funding
                  run `npm fund` for details
                29 vulnerabilities (1 low, 17 moderate, 11 high)
                To address issues that do not require attention, run:
                  npm audit fix
                To address all issues (including breaking changes), run:
                  npm audit fix --force
                Run `npm audit` for details.
                  sdetweil @mumblebaj
                  @mumblebaj why my install script does npm install --only=prod
                  to remove the dev dependencies
                    @sdetweil :thumbs_up:
                      What are “dev dependencies” to the uninitiated?
                      S R 2 Replies Last reply Reply Quote 0
                        sdetweil @Richard238
                        @richard238 there are dependencies
                        things needed to RUN
                        and dev dependencies,
                        things needed to DEVELOP for existing or new function
                        things like syntax checkers, format checkers, test cases, … 99% of users don’t need that stuff on their disc
                        in the package.json are two lists of dependencies
                        “devDependencies”: {
                        “dependencies”: {
                        unless u specify only runtime (production) , you get both …
                          Richard238 @Richard238
                          Still no MM though. Status says online, but it’s not launching MM.
                          I’ll reboot, because, why not…
                          pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                          [PM2] [MagicMirror](0) ✓
                          [PM2] Process successfully started
                          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                          │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.6mb    │
                            @richard238 no reboot…
                            just pm2 stop 0
                            pm2 flush
                            pm2 start 0
                            then pm2 logs --line=50
                              Richard238 @sdetweil
                              pi@magicmirror:~/MagicMirror $ pm2 stop 0
                              [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                              │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                              pi@magicmirror:~/MagicMirror $ pm2 flush
                              [PM2] Flushing /home/pi/.pm2/pm2.log
                              [PM2] Flushing:
                              [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                              [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                              [PM2] Logs flushed
                              pi@magicmirror:~/MagicMirror $ pm2 start 0
                              [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                              │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                              pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
                              [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                              /home/pi/.pm2/pm2.log last 50 lines:
                              PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
                              /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                              0|MagicMir |
                              0|MagicMir | > magicmirror@2.18.0 start
                              0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              0|MagicMir |
                              /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                              0|MagicMir | App threw an error during load
                              0|MagicMir | TypeError: Log.log is not a function
                              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
                              0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                              0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                              0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
                              0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
                              0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                              0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                              0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
                              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
                              0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                              0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                              0|MagicMir | A JavaScript error occurred in the main process
                              0|MagicMir | Uncaught Exception:
                              0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                              0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                @richard238 ok, do
                                rm -rf node_modules
                                rm package-lock.json
                                  pi@magicmirror:~/MagicMirror $ rm -rf node_modules
                                  pi@magicmirror:~/MagicMirror $ rm package-lock.json
                                  pi@magicmirror:~/MagicMirror $ npm install --only=prod
                                  > magicmirror@2.18.0 install
                                  > " && cd vendor && npm install --loglevel=error
                                  up to date, audited 10 packages in 4s
                                  found 0 vulnerabilities
                                  > magicmirror@2.18.0 postinstall
                                  > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                  > magicmirror@2.18.0 install-fonts
                                  > echo "Installing fonts ...
                                  > " && cd fonts && npm install --loglevel=error
                                  up to date, audited 2 packages in 13s
                                  > magicmirror@2.18.0 prepare
                                  > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                                  no husky installed.
                                  added 267 packages, and audited 268 packages in 6m
                                  19 packages are looking for funding
                                    @richard238 and try to run mm again
                                      Online, but no MM showing.
                                      │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                                        @richard238 and show log output again?
                                        and output of
                                        node -v
                                        npm -v
                                          PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
                                          PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                          PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
                                          PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                          PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir |
                                          0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                          0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                                          0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                          0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                          pi@magicmirror:~/MagicMirror $ node -v
                                          v17.3.0
                                          pi@magicmirror:~/MagicMirror $ npm -v
                                          8.3.0
                                            @richard238 can u show the ~/MagicMirror/config/config.js
                                            • 2 / 4
