    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 47.7k Views 4 Watching
      Richard238 @sdetweil
      Good morning Sam.
      Tried that late yesterday, and yes, it works.
      And this morning, I copied
      custom.css
      from
      /home/pi/MagicMirror.save/css
      to
      /home/pi/MagicMirror/css
      This too is working perfectly.
      Is there anything else to do, housekeeping maybe, or is that it now?
        sdetweil @Richard238
        @richard238 if everything is running ok then I think you are done, and can delete the
        MagicMirror.save folder
        R 1 Reply Last reply
          Ok, I’ll do that then.
          Do we know what the cause of all this was, was it something to do with a mismatch in versions of node and npm?
            @richard238 no idea what caused it.
            there clearly was an error somewhere in the upgrade process, maybe reported and missed, or unreported.
            but can u send me the MagicMirror.save/installers/upgrade.log
              That’s a huge file, what’s the best way to send it?
                @richard238 use zip to make it smaller
                do
                cd ~
                zip logfile.zip ~/MagicMirror.save/installers/upgrade.log
                # rename logfile.zip so it can be emailed
                mv logfile.zip logfile.txt
                then use email to send logfile.txt to me.
                same userid at gmail
                  bash: zip: command not found
                  Zipped it on Windows, renamed and emailed.
                  S 2 Replies Last reply
                    @richard238 thx…
                    looking back thru the topic, the
                    Module.createRequire is not a function is because of downlevel node.
                    the eslint library depends on node 14+ for that to work.
                    (from npm run config:check)
                      @richard238 if you haven’t deleted yet, can u try something
                      because you did
                      pi@magicmirror:~/MagicMirror $ npm init -y
                      in the mm folder, instead of the module folder, this overwrote the shipped package.json
                      so,
                      do
                      cd ~/MagicMirror.save
                      git checkout package.json
                      rm -rf node_modules
                      rm package.lock.json
                      npm install --only=prod
                      then stop good mm if running and then do , in the MagicMirror.save folder
                      npm start
                        That’s given a very basic, but working MM
                        pi@magicmirror:~ $ cd ~/MagicMirror.save
                        pi@magicmirror:~/MagicMirror.save $ git checkout package.json
                        pi@magicmirror:~/MagicMirror.save $ rm -rf node_modules
                        pi@magicmirror:~/MagicMirror.save $ rm package.lock.json
                        rm: cannot remove 'package.lock.json': No such file or directory
                        pi@magicmirror:~/MagicMirror.save $ npm install --only=prod
                        > magicmirror@2.18.0 install
                        > " && cd vendor && npm install --loglevel=error
                        up to date, audited 10 packages in 4s
                        found 0 vulnerabilities
                        > magicmirror@2.18.0 postinstall
                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                        > magicmirror@2.18.0 install-fonts
                        > echo "Installing fonts ...
                        > " && cd fonts && npm install --loglevel=error
                        up to date, audited 2 packages in 3s
                        > magicmirror@2.18.0 prepare
                        > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                        no husky installed.
                        added 266 packages, and audited 267 packages in 2m
                        19 packages are looking for funding
                          run `npm fund` for details
                        pi@magicmirror:~/MagicMirror.save $ npm start
                        > magicmirror@2.18.0 start
                        [07.01.2022 14:15.55.560] [LOG]   Starting MagicMirror: v2.18.0
                        [07.01.2022 14:15.55.585] [LOG]   Loading config ...
                        [07.01.2022 14:15.55.607] [LOG]   Loading module helpers ...
                        [07.01.2022 14:15.55.617] [LOG]   No helper found for module: alert.
                        [07.01.2022 14:15.55.675] [LOG]   Initializing new module helper ...
                        [07.01.2022 14:15.55.679] [LOG]   Module helper loaded: updatenotification
                        [07.01.2022 14:15.55.683] [LOG]   No helper found for module: clock.
                        [07.01.2022 14:15.56.139] [LOG]   Initializing new module helper ...
                        [07.01.2022 14:15.56.141] [LOG]   Module helper loaded: calendar
                        [07.01.2022 14:15.56.146] [LOG]   No helper found for module: compliments.
                        [07.01.2022 14:15.56.159] [LOG]   Initializing new module helper ...
                        [07.01.2022 14:15.56.161] [LOG]   Module helper loaded: currentweather
                        [07.01.2022 14:15.56.168] [LOG]   Initializing new module helper ...
                        [07.01.2022 14:15.56.170] [LOG]   Module helper loaded: weatherforecast
                        [07.01.2022 14:15.56.248] [LOG]   Initializing new module helper ...
                        [07.01.2022 14:15.56.250] [LOG]   Module helper loaded: newsfeed
                        [07.01.2022 14:15.56.253] [LOG]   All module helpers loaded.
                        [07.01.2022 14:15.56.571] [LOG]   Starting server on port 8080 ...
                        [07.01.2022 14:15.56.602] [LOG]   Server started ...
                        [07.01.2022 14:15.56.604] [LOG]   Connecting socket for: updatenotification
                        [07.01.2022 14:15.56.606] [LOG]   Starting module helper: updatenotification
                        [07.01.2022 14:15.56.607] [LOG]   Connecting socket for: calendar
                        [07.01.2022 14:15.56.609] [LOG]   Starting node helper for: calendar
                        [07.01.2022 14:15.56.610] [LOG]   Connecting socket for: currentweather
                        [07.01.2022 14:15.56.611] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                        [07.01.2022 14:15.56.614] [LOG]   Connecting socket for: weatherforecast
                        [07.01.2022 14:15.56.616] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                        [07.01.2022 14:15.56.617] [LOG]   Connecting socket for: newsfeed
                        [07.01.2022 14:15.56.620] [LOG]   Starting node helper for: newsfeed
                        [07.01.2022 14:15.56.622] [LOG]   Sockets connected & modules started ...
                        [07.01.2022 14:15.57.465] [LOG]   Launching application.
                        [12477:0107/141600.023451:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                        [12538:0107/141600.426774:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                        [07.01.2022 14:16.03.157] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                        [07.01.2022 14:16.03.201] [LOG]   Create new newsfetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                        [07.01.2022 14:16.03.219] [INFO]  Checking git for module: default
                        [07.01.2022 14:16.04.177] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                        [07.01.2022 14:16.04.552] [INFO]  Newsfeed-Fetcher: Broadcasting 57 items.
                          @richard238 we may have copied back the config.js.sample before we gave up
                            That’s working good too.
                            Do I keep MM, or MM.save?
                              @richard238 up to you… mm.save is what you had… upgraded…
                                renamed MM to MM.JAN22
                                renamed MM.save to MM
                                All good, thank you.
                                  @richard238 glad to hear it…
                                  i opened an issue in MagicMirror to document the original problem and the resolution.
                                  https://github.com/MichMich/MagicMirror/issues/2772
                                  and updated the black screen Troubleshooting topic to be clearer about that problem fix process, and how to recover
                                  • 4 / 4
