    (solved)Calendar Dates - Problematic behaviour since 2.18
    calendar
    7 Posts 2 Posters 1.9k Views 2 Watching
    • O Offline
      OberfragGER @sdetweil
      @sdetweil Hi @sdetweil , thx for your reply.
      I mean, i added the dateFormat to every single calendar. But i doesnt work too.
            module: 'calendar',
            header: 'Kalender',
            position: 'top_left',
      		dateFormat: 'D.MMMM',
      		displayRepeatingCountTitle: true,
      		colored: true,
      		coloredSymbolOnly: true,
      			symbol: 'calendar',
                  url: 'https://www.officeholidays.com/ics-local-name/germany',
      			color: '#fdffe3'
      			symbol: 'trash-alt',
      			url: 'https://calendar.google.com/calendar/ical/XXXXXXXXX%40import.calendar.google.com/public/basic.ics',
      			color: '#DF0F32',
      			maximumEntries: 5
                  url: 'https://calendar.google.com/calendar/ical/oberfragger%40gmail.com/private-XXXXXXXXX/basic.ics',
      			symbol: 'calendar-check',
      			color: '#7cd2fc'
       			url: 'http://localhost:8080/mmm-googlebirthdaysprovider',
      			repeatingCountTitle: 'Geburtstag',
      			symbol: 'birthday-cake',
      			color: '#F5DA81'
                  symbol: 'flag-checkered',
                  url: 'http://localhost:8080/MMM-Formula1/schedule.ics',
      			color: '#b8e9fc'
      		customEvents: [
      			keyword: 'tsfeiertag',
      			color: '#fcb8d8',
      			symbol: 'gifts'
      			keyword: 'Könige',
      			color: '#fff2cc',
      			symbol: 'crown'
      			keyword: 'gelbe',
      			color: '#fff133',
      			symbol: 'recycle'
      			keyword: 'blaue',
      			color: '#335cff',
      			symbol: 'newspaper'
      			keyword: 'bäume',
      			color: '#06a929',
      			symbol: 'tree'
      			keyword: 'oster',
      			color: '#adf542',
      			symbol: 'egg'
      In 2.17 it looked so:
        sdetweil @OberfragGER
        @oberfragger looking thru the code, date format is only used if timeFormat is set to ‘absolute’ or ‘dateheaders’
        by default it is ‘relative’
        • O Offline
          @sdetweil I found the problem!
          Its about whole day events!
          Now you see both events are from the same (google) calendar.
          “Test - dayevent” is for the whole day.
          “Zahnarzt” is just for a timeslot.
          In the 2.18 releasenotes from @MichMich is mentioned, that “Fixed Calendar showEnd and Full Date overlay (#2629).” Maybe this or another change caused this issue.
          Did you know, where i can add this issue to 2.18??? Whith dateFormat: ‘D.MMMM’, both entries should look in the same format.
          This should moved to Troubleshooting (not modules/troubleshooting).
            @oberfragger use fullDayEventDateFormat
            • O Offline
              @sdetweil said in Calendar Dates - Problematic behaviour since 2.18:
              Thanks a lot, again @sdetweil .
              fullDayEventDateFormat: 'D.MMMM',
              did the job!
