    MagicMirror stays black after adding Face-Reco-MMM
    11 Posts 3 Posters 3.2k Views 3 Watching
      Crimel
      Hi All
      I’m trying to build my first Mirror with Face-Reco Module from Nischi.
      I followed the Guideline 1:1 but after adding the Module to config.js, the Mirror stays only black. Even when I mapped all Modules to “show always”
      When i use the Tools which are provided, my PiCam recognizes our faces without any problem.
      I’m working with a Raspberry 3, Model B+, OS is Buster.
      When i run npm run config:check I get 0 errors which doesn’t help me for troubleshooting.
      When I remove the Module, the Mirror is working again without any issues.
      I have tried to get logs thru pm2 log MagicMirror but this also don’t work.
      This is the Module which I use
      https://github.com/nischi/MMM-Face-Reco-DNN
      Somebody any input for me? :)
      Cheers
      Chris
        sdetweil @Crimel
        @crimel its
        pm2 logs name --lines=???
        name is MagicMirror
        ??? is a number, 15 is the default if not specified
          Crimel @sdetweil
          @sdetweil Thank you for your rapid response!
          Unfortunately I get the same output:
          [TAILING] Tailing last 15 lines for [MagicMirror–lines=15] process (change the value with --lines option)
          I have this since 1 hour displayed in my terminal
            sdetweil @Crimel
            @crimel ok
            pm2 logs --lines=50
              Crimel @sdetweil
              @sdetweil said in MagicMirror stays black after adding Face-Reco-MMM:
              pm2 logs --lines=50
              With it I get an output :)
              PM2 | App [mm:0] starting in -fork mode-
              PM2 | App [mm:0] online
              0|mm | > magicmirror@2.18.0 start
              0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              0|mm | [14.01.2022 14:26.53.892] [LOG]
              0|mm | Starting MagicMirror: v2.18.0
              0|mm | [14.01.2022 14:26.53.919] [LOG]
              0|mm | Loading config …
              0|mm | [14.01.2022 14:26.53.943] [LOG]
              0|mm | Loading module helpers …
              0|mm | [14.01.2022 14:26.54.977] [LOG]
              0|mm | Initializing new module helper …
              0|mm | [14.01.2022 14:26.54.981] [LOG] Check MagicMirror version for node helper ‘MMM-CoinMarketCap’ - Minimum version: 2.2.1 - Current version: 2.18.0
              0|mm | [14.01.2022 14:26.54.988] [LOG] Version is ok!
              0|mm | [14.01.2022 14:26.54.992] [LOG]
              0|mm | Module helper loaded: MMM-CoinMarketCap
              0|mm | [14.01.2022 14:26.54.999] [LOG] No helper found for module: MMM-SwissStationboard.
              0|mm | [14.01.2022 14:26.55.004] [LOG]
              0|mm | No helper found for module: clock.
              0|mm | [14.01.2022 14:26.55.451] [LOG]
              0|mm | [14.01.2022 14:26.55.454] [LOG]
              0|mm | Module helper loaded: calendar
              0|mm | [14.01.2022 14:26.55.457] [LOG]
              0|mm | No helper found for module: compliments.
              0|mm | [14.01.2022 14:26.55.460] [LOG] No helper found for module: weather.
              0|mm | [14.01.2022 14:26.55.534] [LOG]
              0|mm | [14.01.2022 14:26.55.535] [LOG] Module helper loaded: newsfeed
              0|mm | [14.01.2022 14:26.55.595] [LOG]
              0|mm | [14.01.2022 14:26.55.596] [LOG] Module helper loaded: MMM-Face-Reco-DNN
              0|mm | [14.01.2022 14:26.55.598] [LOG] All module helpers loaded.
              0|mm | [14.01.2022 14:26.55.863] [LOG]
              0|mm | Starting server on port 8080 …
              0|mm | [14.01.2022 14:26.55.900] [LOG]
              0|mm | Server started …
              0|mm | [14.01.2022 14:26.55.903] [LOG] Connecting socket for: MMM-CoinMarketCap
              0|mm | [14.01.2022 14:26.55.905] [LOG]
              0|mm | MMM-CoinMarketCap: module loaded! Path: /home/pi/MagicMirror/modules/MMM-CoinMarketCap
              0|mm | [14.01.2022 14:26.55.907] [LOG]
              0|mm | MMM-CoinMarketCap: Path “/logos” configured successfully.
              0|mm | [14.01.2022 14:26.55.909] [LOG] Connecting socket for: calendar
              0|mm | [14.01.2022 14:26.55.911] [LOG] Starting node helper for: calendar
              0|mm | [14.01.2022 14:26.55.913] [LOG] Connecting socket for: newsfeed
              0|mm | [14.01.2022 14:26.55.915] [LOG] Starting node helper for: newsfeed
              0|mm | [14.01.2022 14:26.55.917] [LOG] Connecting socket for: MMM-Face-Reco-DNN
              0|mm | [14.01.2022 14:26.55.946] [LOG]
              0|mm | Starting module helper: MMM-Face-Reco-DNN
              0|mm | [14.01.2022 14:26.55.947] [LOG] Sockets connected & modules started …
              0|mm | [14.01.2022 14:26.56.508] [LOG]
              0|mm | Launching application.
              0|mm | [5602:0114/142657.402179:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
              0|mm | [5640:0114/142657.695321:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                sdetweil @Crimel
                @crimel edit package.json and add
                –disable-gpu
                to the start clause
                on my phone so hard to type it all
                “start”:“… node_modules… --disable-gpu js/electron.js”
                … means stuff that is there already keep
                  Crimel @sdetweil
                  @sdetweil Thank you!
                  Do you mean package.json ? I dont find a file called pancake.json :/
                  mumblebajM S 2 Replies Last reply Reply Quote 0
                  • mumblebajM Offline
                    mumblebaj Module Developer @Crimel
                    @crimel Yes, should be package.json. Must have been an autocorrect. :)
                      sdetweil @Crimel
                      @crimel yes, typo, fixed
                        Crimel @sdetweil
                        @sdetweil @mumblebaj
                        Awesome support!
                        I just added it to the package.json
                        “scripts”: {
                        “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron --disable-gpu js/electron.js”,
                        “start:dev”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js dev”,
                        and have one error left
                        0|mm | [11202:0114/154643.064204:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                        Funny thing is that i have the same error on another config.json without Face-Reco and the mirror is working there.
                          sdetweil @Crimel
                          @crimel run the fixsandbox script from here
