    Black Screen --> Update to v2.18.0
    8 Posts 2 Posters 1.7k Views 2 Watching
      MDLefevere
      Hi All,
      Today i tried to update. The second time. Again it fails. Might be my bad!.
      Now i’m left again with a black screen and one big error…
      I can start all over again but maybe this might be fixable.
      The error that’s given me is:
      [15.01.2022 19:56.05.617] [LOG]   Starting MagicMirror: v2.18.0
      [15.01.2022 19:56.05.640] [LOG]   Loading config ...
      [15.01.2022 19:56.05.654] [LOG]   Loading module helpers ...
      [15.01.2022 19:56.05.662] [LOG]   No helper found for module: alert.
      [15.01.2022 19:56.05.681] [LOG]   Initializing new module helper ...
      [15.01.2022 19:56.05.684] [LOG]   Module helper loaded: MMM-NewPIR
      [15.01.2022 19:56.05.688] [LOG]   No helper found for module: clock.
      [15.01.2022 19:56.06.102] [LOG]   Initializing new module helper ...
      [15.01.2022 19:56.06.107] [LOG]   Module helper loaded: calendar
      [15.01.2022 19:56.06.110] [LOG]   No helper found for module: weather.
      [15.01.2022 19:56.06.245] [LOG]   Initializing new module helper ...
      [15.01.2022 19:56.06.247] [LOG]   Module helper loaded: MMM-Bring
      [15.01.2022 19:56.06.407] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
      [15.01.2022 19:56.06.410] [LOG]   Loading module helpers ...
      [15.01.2022 19:56.06.412] [LOG]   No helper found for module: alert.
      [15.01.2022 19:56.06.414] [LOG]   Initializing new module helper ...
      [15.01.2022 19:56.06.415] [LOG]   Module helper loaded: MMM-NewPIR
      [15.01.2022 19:56.06.417] [LOG]   No helper found for module: clock.
      [15.01.2022 19:56.06.421] [LOG]   Initializing new module helper ...
      [15.01.2022 19:56.06.423] [LOG]   Module helper loaded: calendar
      [15.01.2022 19:56.06.427] [LOG]   No helper found for module: weather.
      [15.01.2022 19:56.06.430] [LOG]   Initializing new module helper ...
      [15.01.2022 19:56.06.433] [LOG]   Module helper loaded: MMM-Bring
      [15.01.2022 19:56.06.446] [ERROR] App threw an error during load
      [15.01.2022 19:56.06.449] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
          at Object.hasVendoredLibvips (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/libvips.js:82:13)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/constructor.js:7:22)
          at Module._compile (node:internal/modules/cjs/loader:1116:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
          at Module.load (node:internal/modules/cjs/loader:988:32)
          at Module._load (node:internal/modules/cjs/loader:829:12)
          at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
          at Module.require (node:internal/modules/cjs/loader:1012:19)
          at require (node:internal/modules/cjs/helpers:94:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/index.js:3:15)
      [15.01.2022 19:56.06.452] [ERROR] Whoops! There was an uncaught exception...
      [15.01.2022 19:56.06.463] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
      [15.01.2022 19:56.06.470] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [15.01.2022 19:56.06.472] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [15.01.2022 19:56.07.163] [LOG]   Launching application.
      [1039:0115/195608.230200:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      [1064:0115/195608.591784:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
        sdetweil @MDLefevere
        @mdlefevere the sharp library used by this module is broken.
          MDLefevere @sdetweil
          Is there a way to fix this, or is the module “broken”?
            @mdlefevere I do not know
            see this,
            https://forum.magicmirror.builders/topic/16014/mmm-backgroundslideshow-linux-armv7-binaries-cannot-be-used-on-the-linux-armvdefault-platform/11?_=1642274871254
              Do you know of a way to git clone a specific version of MagicMirror. It’s easier to roll-back i quess and wait for it to be fixed :)
                @mdlefevere said in Black Screen --> Update to v2.18.0:
                u have to clone using the tag id
                  Saw that ;). But there are 100 people all telling a different command :). You know the correct one for v2.17.1?
                    My bad. Got it. It was there all the time, but the folder was just not showing :)
