UNSOLVED Black Screen --> Update to v2.18.0
Hi All,
Today i tried to update. The second time. Again it fails. Might be my bad!.
Now i’m left again with a black screen and one big error…I can start all over again but maybe this might be fixable.
The error that’s given me is:[15.01.2022 19:56.05.617] [LOG] Starting MagicMirror: v2.18.0 [15.01.2022 19:56.05.640] [LOG] Loading config ... [15.01.2022 19:56.05.654] [LOG] Loading module helpers ... [15.01.2022 19:56.05.662] [LOG] No helper found for module: alert. [15.01.2022 19:56.05.681] [LOG] Initializing new module helper ... [15.01.2022 19:56.05.684] [LOG] Module helper loaded: MMM-NewPIR [15.01.2022 19:56.05.688] [LOG] No helper found for module: clock. [15.01.2022 19:56.06.102] [LOG] Initializing new module helper ... [15.01.2022 19:56.06.107] [LOG] Module helper loaded: calendar [15.01.2022 19:56.06.110] [LOG] No helper found for module: weather. [15.01.2022 19:56.06.245] [LOG] Initializing new module helper ... [15.01.2022 19:56.06.247] [LOG] Module helper loaded: MMM-Bring [15.01.2022 19:56.06.407] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform. [15.01.2022 19:56.06.410] [LOG] Loading module helpers ... [15.01.2022 19:56.06.412] [LOG] No helper found for module: alert. [15.01.2022 19:56.06.414] [LOG] Initializing new module helper ... [15.01.2022 19:56.06.415] [LOG] Module helper loaded: MMM-NewPIR [15.01.2022 19:56.06.417] [LOG] No helper found for module: clock. [15.01.2022 19:56.06.421] [LOG] Initializing new module helper ... [15.01.2022 19:56.06.423] [LOG] Module helper loaded: calendar [15.01.2022 19:56.06.427] [LOG] No helper found for module: weather. [15.01.2022 19:56.06.430] [LOG] Initializing new module helper ... [15.01.2022 19:56.06.433] [LOG] Module helper loaded: MMM-Bring [15.01.2022 19:56.06.446] [ERROR] App threw an error during load [15.01.2022 19:56.06.449] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform. at Object.hasVendoredLibvips (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/libvips.js:82:13) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/constructor.js:7:22) at Module._compile (node:internal/modules/cjs/loader:1116:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) at Module.load (node:internal/modules/cjs/loader:988:32) at Module._load (node:internal/modules/cjs/loader:829:12) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Module.require (node:internal/modules/cjs/loader:1012:19) at require (node:internal/modules/cjs/helpers:94:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/index.js:3:15) [15.01.2022 19:56.06.452] [ERROR] Whoops! There was an uncaught exception... [15.01.2022 19:56.06.463] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform. at Object.hasVendoredLibvips (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/libvips.js:82:13) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/constructor.js:7:22) at Module._compile (node:internal/modules/cjs/loader:1116:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) at Module.load (node:internal/modules/cjs/loader:988:32) at Module._load (node:internal/modules/cjs/loader:829:12) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Module.require (node:internal/modules/cjs/loader:1012:19) at require (node:internal/modules/cjs/helpers:94:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/index.js:3:15) [15.01.2022 19:56.06.470] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [15.01.2022 19:56.06.472] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [15.01.2022 19:56.07.163] [LOG] Launching application. [1039:0115/195608.230200:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization [1064:0115/195608.591784:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
@mdlefevere the sharp library used by this module is broken.
Is there a way to fix this, or is the module “broken”?
Do you know of a way to git clone a specific version of MagicMirror. It’s easier to roll-back i quess and wait for it to be fixed -
@mdlefevere said in Black Screen --> Update to v2.18.0:
Do you know of a way to git clone a specific version of MagicMirror. It’s easier to roll-back i quess and wait for it to be fixedu have to clone using the tag id
Saw that ;). But there are 100 people all telling a different command :). You know the correct one for v2.17.1? -
My bad. Got it. It was there all the time, but the folder was just not showing
