    Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED"
    25 Posts 2 Posters 9.1k Views 2 Watching
      sdetweil @onis_uk
      @onis_uk said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
      const require$1 = Module.createRequire((typeof document === ‘undefined’ ? new (require(‘u’ + ‘rl’).URL)(‘file:’ + __filename).href : (document.currentScript &&
      see https://github.com/MichMich/MagicMirror/issues/2772
      O 2 Replies Last reply Reply Quote 0
      • O Offline
        onis_uk @sdetweil
        @sdetweil said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
        ok thanks! looks like I only had version 11.14 installed, just updating now
        • O Offline
          onis_uk @sdetweil
          @sdetweil I cant seem to update node beyond 11.15, any ideas why??
          pi@raspberrypi:~ $ sudo n latest
          installing : node-v11.15.0
          mkdir : /usr/local/n/versions/node/11.15.0
          fetch : https://nodejs.org/dist/v11.15.0/node-v11.15.0-linux-armv6l.tar.xz
          installed : v11.15.0 (with npm 6.7.0)
            sdetweil @onis_uk
            @onis_uk armv6… hm… will have to work on this later today.
            off to pick up grandson…
            • O Offline
              onis_uk @sdetweil
              @sdetweil ok many thanks!
                sdetweil @onis_uk
                @onis_uk look at this
                https://blog.rodrigograca.com/how-to-install-latest-nodejs-on-raspberry-pi-0-w/
                • O Offline
                  onis_uk @sdetweil
                  @sdetweil Still just get a ton of errors, looks like I might just have to format and start again :anxious_face_with_sweat:
                  The fragility of MM is what kills it for me, one update and its all messed up, too many dependencies and fussy stuff going on, makes it so hard for the average user to deal with.
                    sdetweil @onis_uk
                    @onis_uk pi0 has been kicked to the side by the internet community, harder to find stuff still working on armv6l
                    nothing to do with mm
                      sdetweil @onis_uk
                      @onis_uk the latest pi os also installs code that doesn’t work on pi0… chrome and firefox
                      • O Offline
                        onis_uk @sdetweil
                        @sdetweil I’ve had MM for well over 2 years now and its always been like this to be fair, every time I’ve updated its broken it…
                          sdetweil @onis_uk
                          @onis_uk yes, thats why I made the script for upgrade
                          but this time is worse
                          • O Offline
                            onis_uk @sdetweil
                            @sdetweil Thank you for your help anyway!
                              sdetweil @onis_uk
                              @onis_uk I have just updated the install and upgrade scripts to handle all this pi0w broken stuff…
                              • O Offline
                                onis_uk @sdetweil
                                @sdetweil AH ok thanks, i’ll give it another try then!
                                • O Offline
                                  onis_uk @sdetweil
                                  @sdetweil Still got able to install 16…
                                  pi@raspberrypi:~/MagicMirror $ sudo n 16
                                  Error: no version found for ‘16’
                                    sdetweil @onis_uk
                                    @onis_uk no… just run the upgrade script or install script, they will handle it
                                    see
                                    • O Offline
                                      onis_uk
                                      @sdetweil done and done sir! many thanks
                                      pi@raspberrypi:~/MagicMirror $ node -v
                                      v16.9.1
