    Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED"
    25 Posts 2 Posters 9.0k Views 2 Watching
      sdetweil @onis_uk
      @onis_uk so, tell me more… what pi? sounds like pi 0?
      if using pm2, then
      pm2 stop all
      pm2 flush
      npm run config:check
      • O Offline
        onis_uk @sdetweil
        @sdetweil said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
        yes running in a Pi zero!
        magicmirror@2.18.0 config:check /home/pi/MagicMirror
        node js/check_config.js
        /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359
        const require$1 = Module.createRequire((typeof document === ‘undefined’ ? new (require(‘u’ + ‘rl’).URL)(‘file:’ + __filename).href : (document.currentScript && document.currentScript.src || new URL(‘eslintrc.cjs’, document.baseURI).href)));
        TypeError: Module.createRequire is not a function
        at Object. (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359:26)
        at Module._compile (internal/modules/cjs/loader.js:816:30)
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:827:10)
        at Module.load (internal/modules/cjs/loader.js:685:32)
        at Function.Module._load (internal/modules/cjs/loader.js:620:12)
        at Module.require (internal/modules/cjs/loader.js:723:19)
        at require (internal/modules/cjs/helpers.js:14:16)
        at Object. (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.18.0 config:check: node js/check_config.js
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.18.0 config:check script.
        npm ERR! /home/pi/.npm/_logs/2022-01-17T13_53_04_242Z-debug.log
          sdetweil @onis_uk
          @onis_uk said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
          see https://github.com/MichMich/MagicMirror/issues/2772
          O 2 Replies Last reply Reply Quote 0
          • O Offline
            onis_uk @sdetweil
            ok thanks! looks like I only had version 11.14 installed, just updating now
            • O Offline
              onis_uk @sdetweil
              @sdetweil I cant seem to update node beyond 11.15, any ideas why??
              pi@raspberrypi:~ $ sudo n latest
              installing : node-v11.15.0
              mkdir : /usr/local/n/versions/node/11.15.0
              fetch : https://nodejs.org/dist/v11.15.0/node-v11.15.0-linux-armv6l.tar.xz
              installed : v11.15.0 (with npm 6.7.0)
                sdetweil @onis_uk
                @onis_uk armv6… hm… will have to work on this later today.
                off to pick up grandson…
                • O Offline
                  onis_uk @sdetweil
                  @sdetweil ok many thanks!
                    sdetweil @onis_uk
                    @onis_uk look at this
                    https://blog.rodrigograca.com/how-to-install-latest-nodejs-on-raspberry-pi-0-w/
                    • O Offline
                      onis_uk @sdetweil
                      @sdetweil Still just get a ton of errors, looks like I might just have to format and start again :anxious_face_with_sweat:
                      The fragility of MM is what kills it for me, one update and its all messed up, too many dependencies and fussy stuff going on, makes it so hard for the average user to deal with.
                        sdetweil @onis_uk
                        @onis_uk pi0 has been kicked to the side by the internet community, harder to find stuff still working on armv6l
                        nothing to do with mm
                          sdetweil @onis_uk
                          @onis_uk the latest pi os also installs code that doesn’t work on pi0… chrome and firefox
                          • O Offline
                            onis_uk @sdetweil
                            @sdetweil I’ve had MM for well over 2 years now and its always been like this to be fair, every time I’ve updated its broken it…
                              sdetweil @onis_uk
                              @onis_uk yes, thats why I made the script for upgrade
                              but this time is worse
                              • O Offline
                                onis_uk @sdetweil
                                @sdetweil Thank you for your help anyway!
                                  sdetweil @onis_uk
                                  @onis_uk I have just updated the install and upgrade scripts to handle all this pi0w broken stuff…
                                  • O Offline
                                    onis_uk @sdetweil
                                    @sdetweil AH ok thanks, i’ll give it another try then!
                                    • O Offline
                                      onis_uk @sdetweil
                                      @sdetweil Still got able to install 16…
                                      pi@raspberrypi:~/MagicMirror $ sudo n 16
                                      Error: no version found for ‘16’
                                        sdetweil @onis_uk
                                        @onis_uk no… just run the upgrade script or install script, they will handle it
                                        see
                                        • O Offline
                                          onis_uk
                                          @sdetweil done and done sir! many thanks
                                          pi@raspberrypi:~/MagicMirror $ node -v
                                          v16.9.1
