    Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED"
    25 Posts 2 Posters 9.3k Views 2 Watching
      sdetweil @onis_uk
      @onis_uk how did u update?
      • O
        onis_uk @sdetweil
        @sdetweil SSH’ed to the MM folder then ran git pull && npm install…
        Did I screw up my install?
        • O
          onis_uk @onis_uk
          @onis_uk anyone…?
            sdetweil @onis_uk
            @onis_uk probably this
            • O
              onis_uk
              @sdetweil no it’s not that… I get a white browser screen that is saying it can’t connect to the page!
                sdetweil @onis_uk
                @onis_uk so, tell me more… what pi? sounds like pi 0?
                if using pm2, then
                pm2 stop all
                pm2 flush
                npm run config:check
                • O
                  onis_uk @sdetweil
                  @sdetweil said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
                  yes running in a Pi zero!
                  magicmirror@2.18.0 config:check /home/pi/MagicMirror
                  node js/check_config.js
                  /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359
                  const require$1 = Module.createRequire((typeof document === ‘undefined’ ? new (require(‘u’ + ‘rl’).URL)(‘file:’ + __filename).href : (document.currentScript && document.currentScript.src || new URL(‘eslintrc.cjs’, document.baseURI).href)));
                  TypeError: Module.createRequire is not a function
                  at Object. (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359:26)
                  at Module._compile (internal/modules/cjs/loader.js:816:30)
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:827:10)
                  at Module.load (internal/modules/cjs/loader.js:685:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:620:12)
                  at Module.require (internal/modules/cjs/loader.js:723:19)
                  at require (internal/modules/cjs/helpers.js:14:16)
                  at Object. (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5)
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! magicmirror@2.18.0 config:check: node js/check_config.js
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.18.0 config:check script.
                  npm ERR! /home/pi/.npm/_logs/2022-01-17T13_53_04_242Z-debug.log
                    sdetweil @onis_uk
                    @onis_uk said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
                    see https://github.com/MichMich/MagicMirror/issues/2772
                    O 2 Replies Last reply Reply Quote 0
                    • O
                      onis_uk @sdetweil
                      ok thanks! looks like I only had version 11.14 installed, just updating now
                      • O
                        onis_uk @sdetweil
                        @sdetweil I cant seem to update node beyond 11.15, any ideas why??
                        pi@raspberrypi:~ $ sudo n latest
                        installing : node-v11.15.0
                        mkdir : /usr/local/n/versions/node/11.15.0
                        fetch : https://nodejs.org/dist/v11.15.0/node-v11.15.0-linux-armv6l.tar.xz
                        installed : v11.15.0 (with npm 6.7.0)
                          sdetweil @onis_uk
                          @onis_uk armv6… hm… will have to work on this later today.
                          off to pick up grandson…
                          • O
                            onis_uk @sdetweil
                            @sdetweil ok many thanks!
                              sdetweil @onis_uk
                              @onis_uk look at this
                              https://blog.rodrigograca.com/how-to-install-latest-nodejs-on-raspberry-pi-0-w/
                              • O
                                onis_uk @sdetweil
                                @sdetweil Still just get a ton of errors, looks like I might just have to format and start again :anxious_face_with_sweat:
                                The fragility of MM is what kills it for me, one update and its all messed up, too many dependencies and fussy stuff going on, makes it so hard for the average user to deal with.
                                  sdetweil @onis_uk
                                  @onis_uk pi0 has been kicked to the side by the internet community, harder to find stuff still working on armv6l
                                  nothing to do with mm
                                    sdetweil @onis_uk
                                    @onis_uk the latest pi os also installs code that doesn’t work on pi0… chrome and firefox
                                    • O
                                      onis_uk @sdetweil
                                      @sdetweil I’ve had MM for well over 2 years now and its always been like this to be fair, every time I’ve updated its broken it…
                                        sdetweil @onis_uk
                                        @onis_uk yes, thats why I made the script for upgrade
                                        but this time is worse
                                        • O
                                          onis_uk @sdetweil
                                          @sdetweil Thank you for your help anyway!
                                            sdetweil @onis_uk
                                            @onis_uk I have just updated the install and upgrade scripts to handle all this pi0w broken stuff…
