    Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED"
    25 Posts 2 Posters 7.8k Views 2 Watching
    • O Offline
      onis_uk @sdetweil
      @sdetweil SSH’ed to the MM folder then ran git pull && npm install…
      Did I screw up my install?
      • O Offline
        onis_uk @onis_uk
        @onis_uk anyone…?
          sdetweil @onis_uk
          @onis_uk probably this
          • O Offline
            onis_uk
            @sdetweil no it’s not that… I get a white browser screen that is saying it can’t connect to the page!
              sdetweil @onis_uk
              @onis_uk so, tell me more… what pi? sounds like pi 0?
              if using pm2, then
              pm2 stop all
              pm2 flush
              npm run config:check
              • O Offline
                onis_uk @sdetweil
                @sdetweil said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
                yes running in a Pi zero!
                magicmirror@2.18.0 config:check /home/pi/MagicMirror
                node js/check_config.js
                /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359
                const require$1 = Module.createRequire((typeof document === ‘undefined’ ? new (require(‘u’ + ‘rl’).URL)(‘file:’ + __filename).href : (document.currentScript && document.currentScript.src || new URL(‘eslintrc.cjs’, document.baseURI).href)));
                TypeError: Module.createRequire is not a function
                at Object. (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359:26)
                at Module._compile (internal/modules/cjs/loader.js:816:30)
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:827:10)
                at Module.load (internal/modules/cjs/loader.js:685:32)
                at Function.Module._load (internal/modules/cjs/loader.js:620:12)
                at Module.require (internal/modules/cjs/loader.js:723:19)
                at require (internal/modules/cjs/helpers.js:14:16)
                at Object. (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5)
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.18.0 config:check: node js/check_config.js
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.18.0 config:check script.
                npm ERR! /home/pi/.npm/_logs/2022-01-17T13_53_04_242Z-debug.log
                  sdetweil @onis_uk
                  @onis_uk said in Updated MM and now i get white screen with "ERR_CONNECTION_REFUSED":
                  see https://github.com/MichMich/MagicMirror/issues/2772
                  O 2 Replies Last reply Reply Quote 0
                  • O Offline
                    onis_uk @sdetweil
                    ok thanks! looks like I only had version 11.14 installed, just updating now
                    • O Offline
                      onis_uk @sdetweil
                      @sdetweil I cant seem to update node beyond 11.15, any ideas why??
                      pi@raspberrypi:~ $ sudo n latest
                      installing : node-v11.15.0
                      mkdir : /usr/local/n/versions/node/11.15.0
                      fetch : https://nodejs.org/dist/v11.15.0/node-v11.15.0-linux-armv6l.tar.xz
                      installed : v11.15.0 (with npm 6.7.0)
                        sdetweil @onis_uk
                        @onis_uk armv6… hm… will have to work on this later today.
                        off to pick up grandson…
