    Problems after updating MMM-Homematic
    4 Posts 3 Posters 457 Views 3 Watching
    • T Offline
      TheBassfly
      Hello
      Today I saw that my Homematic Module wasn’t running anymore and the Mirror showed me, that an update is available.
      So, I got into my Terminal and tried to update it.
      I have to say that the “git pull” command never worked here and I always got the message that the git-process was still active on another repository. so I deleted the folder of the module and used “git clone” again.
      after the installation of the new modules I got a few error meeesgaes from the mirror.
      could you eventually help me out, as I’m not understanding what’s wrong.
      (> magicmirror@2.18.0 start
      [18.01.2022 16:55.48.324] [LOG] Starting MagicMirror: v2.18.0
      [18.01.2022 16:55.48.346] [LOG] Loading config …
      [18.01.2022 16:55.48.371] [LOG] Loading module helpers …
      [18.01.2022 16:55.48.416] [LOG] Initializing new module helper …
      [18.01.2022 16:55.48.422] [LOG] Module helper loaded: updatenotification
      [18.01.2022 16:55.48.431] [LOG] No helper found for module: clock.
      [18.01.2022 16:55.49.486] [LOG] Initializing new module helper …
      [18.01.2022 16:55.49.491] [LOG] Module helper loaded: MMM-DarkSkyForecast
      [18.01.2022 16:55.49.507] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-Homematic/node_helper.js
      [18.01.2022 16:55.49.511] [LOG] Loading module helpers …
      [18.01.2022 16:55.49.514] [LOG] Initializing new module helper …
      [18.01.2022 16:55.49.515] [LOG] Module helper loaded: updatenotification
      [18.01.2022 16:55.49.519] [LOG] No helper found for module: clock.
      [18.01.2022 16:55.49.524] [LOG] Initializing new module helper …
      [18.01.2022 16:55.49.528] [LOG] Module helper loaded: MMM-DarkSkyForecast
      [18.01.2022 16:55.49.537] [ERROR] App threw an error during load
      [18.01.2022 16:55.49.543] [ERROR] Error: Cannot find module ‘request’
      Require stack:
      • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
        at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:785:27)
        at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
        at Module.require (node:internal/modules/cjs/loader:1012:19)
        at require (node:internal/modules/cjs/helpers:94:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-Homematic/node_helper.js:3:17)
        at Module._compile (node:internal/modules/cjs/loader:1116:14)
        at Object.Module._extensions…js (node:internal/modules/cjs/loader:1169:10)
        [18.01.2022 16:55.49.546] [ERROR] Whoops! There was an uncaught exception…
        [18.01.2022 16:55.49.561] [ERROR] Error: Cannot find module ‘request’
        Require stack:
        at Object.Module._extensions…js (node:internal/modules/cjs/loader:1169:10) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/pi/MagicMirror/modules/MMM-Homematic/node_helper.js’,
        ‘/home/pi/MagicMirror/js/app.js’,
        ‘/home/pi/MagicMirror/js/electron.js’,
        ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
        undefined
        [18.01.2022 16:55.49.570] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [18.01.2022 16:55.49.572] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [18.01.2022 16:55.50.346] [LOG] Launching application.
        [9324:0118/165551.733110:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
        [9346:0118/165552.114655:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      • mumblebajM Offline
        mumblebaj Module Developer @TheBassfly
        @thebassfly said in Problems after updating MMM-Homematic:
        The above is your error:
        Please see the below for solutions:
        S T 2 Replies Last reply Reply Quote 0
          sdetweil @mumblebaj
          @mumblebaj changed link to remove latest post number, 1st post is the right answer
          • T Offline
            TheBassfly @mumblebaj
            @mumblebaj
            Thank you.
            The solution was a little misunderstanding, but I figured it out, and now it seems to work.
