    calendar: maximumNumberOfDays is ignored
    Scheduled Pinned Locked Moved Solved Bug Hunt
    3 Posts 2 Posters 3.0k Views 1 Watching
      binderth
      Platform [ Raspberry Pi 2/3, Windows, Mac OS X, Linux, Etc … ]: Raspberry pi 3
      Node Version [ 0.12.13 or later ]: ? did a new install yesterday
      MagicMirror Version [ V1 / V2-Beta ]: V2
      Description: While showing a google calendar, the argument “maximumNumberOfDays” is ignored.
      Steps to Reproduce: configure a google calendar, add “maximumNumberOfDays” with a low value
      Expected Results: calendar entries shown in Magic Mirror should be max days as described in the value
      Actual Results: calendar entries above maximumNumberOfDays are shown also
      Configuration: What does the used config.js file look like? (Don’t forget to remove any sensitive information.)
      module: ‘calendar’,
      header: ‘Müllkalender’,
      position: ‘top_left’,
      symbol: ‘calendar-times-o’,
      url: ‘webcal://calendar.google.com/calendar/ical/xxx%40group.calendar.google.com/private-xxx/basic.ics’,
      maximumNumberOfDays: ‘7’,
      user: ‘xxx@xxx.de’,
      pass: ‘xxx’
      Additional Notes: none
        broberg Project Sponsor @binderth
        @binderth You have the maximumNumberOfDays in the wrong place,
        it should be outside the calendar array
                 user: ‘xxx@xxx.de’,
                 pass: ‘xxx’
          binderth @broberg
          @broberg said in calendar: maximumNumberOfDays is ignored:
          thanks, that did the trick. I got the “README.md” wrong! ;)
