    Should I update?
    16 Posts 3 Posters 5.0k Views 4 Watching
      MyMirror
      Hi Sam,
      I have a similar problem.
      My memory card is defective and I had to revert to an older backup.
      Unfortunately, I have been a little lax with the backup, as I always have to get the mirror off the wall a bit awkwardly to back up the SD card.
      I am with the mirror still on Jessie.
      When I stop the MagicMirror with “pm2 stop mm” and also stop node with killall node, I get a message from your scipt (test mode) that node and npm need to be updated.
      How do I get them to the latest version?
      I am rather beginner in Linux - so have understanding for simple queries.
      Can you help me?
      BR
      Jens
        sdetweil @MyMirror
        @mymirror jessie is very old
        4 releases back now. almost nothing will support running there now
        I would also suggest some of the mechanisms to backup over the local network
        https://raspberrypi.stackexchange.com/questions/125137/how-to-backup-entire-raspberry-pi-sd-card-over-network
          MyMirror
          Hi Sam,
          yes i know :-( … very old.
          in the meantime I got the system on “Stretch” and wanted to take the next step to “Buster”.
          But I get the following error (on german):
          PGP error: http://ftp.de.debian.org/debian buster InRelease: The following signatures could not be verified because their public key is not available …
          How can I adjust/correct this?
          Thanks a lot
            sdetweil @MyMirror
            @mymirror i do not know… buster is also not current
              Peter @sdetweil
              @sdetweil finally I tried the update: MM will not start anymore.
              I am on stretch by the way.
              Peter
                sdetweil @Peter
                @peter show me the messages… fromn npm start
                stretch is WAY downlevel…
                need to get to buster(legacy) or bullseye…
                the internet keeps changing things every week… stetch is 4 years old now
                  Peter
                  Is it possible to update without having to start all over?
                  Peter
                    sdetweil @Peter
                    @peter maybe… as i said, stretch is really old…
                    I do not know if you can upgrade OS in place from stretch
                    pretty sure u need to upgrade node and npm too
                    node -v
                    npm -v
                    what pi is this ?
                    uname -a
                    P 1 Reply Last reply
                      Peter @sdetweil
                      @sdetweil I think it is a Pi2b.
                      In 2017 I built this MM and it has been running well since.
                      So, that is my question: update of not.
                      It took me very long to build, and I do not want to start all over again.
                      Peter
                        sdetweil @Peter
                        @peter do not update
                          Peter @sdetweil
                          @sdetweil 😁
                          Saves a lot of work!
                          Maybe I start a fresh install some day.
                          Thanks for your help.
                          Peter
