    Should I update?
    16 Posts 3 Posters 4.9k Views 4 Watching
      Peter @sdetweil
      @sdetweil thanks!
      I noticed your script, but was wondering if it would work because I am so much behind.
      I think I still run MM 1.x
      And I love my MM.
      Peter
        sdetweil @Peter
        @peter make a backup of the MM folder before starting
        the script will work, or I will fix it…
        P 2 Replies Last reply Reply Quote 0
          Peter @sdetweil
          @sdetweil great!
          Peter
            MyMirror
            Hi Sam,
            I have a similar problem.
            My memory card is defective and I had to revert to an older backup.
            Unfortunately, I have been a little lax with the backup, as I always have to get the mirror off the wall a bit awkwardly to back up the SD card.
            I am with the mirror still on Jessie.
            When I stop the MagicMirror with “pm2 stop mm” and also stop node with killall node, I get a message from your scipt (test mode) that node and npm need to be updated.
            How do I get them to the latest version?
            I am rather beginner in Linux - so have understanding for simple queries.
            Can you help me?
            BR
            Jens
              sdetweil @MyMirror
              @mymirror jessie is very old
              4 releases back now. almost nothing will support running there now
              I would also suggest some of the mechanisms to backup over the local network
              https://raspberrypi.stackexchange.com/questions/125137/how-to-backup-entire-raspberry-pi-sd-card-over-network
                MyMirror
                Hi Sam,
                yes i know :-( … very old.
                in the meantime I got the system on “Stretch” and wanted to take the next step to “Buster”.
                But I get the following error (on german):
                PGP error: http://ftp.de.debian.org/debian buster InRelease: The following signatures could not be verified because their public key is not available …
                How can I adjust/correct this?
                Thanks a lot
                  sdetweil @MyMirror
                  @mymirror i do not know… buster is also not current
                    Peter @sdetweil
                    @sdetweil finally I tried the update: MM will not start anymore.
                    I am on stretch by the way.
                    Peter
                      sdetweil @Peter
                      @peter show me the messages… fromn npm start
                      stretch is WAY downlevel…
                      need to get to buster(legacy) or bullseye…
                      the internet keeps changing things every week… stetch is 4 years old now
                        Peter
                        Is it possible to update without having to start all over?
                        Peter
                          sdetweil @Peter
                          @peter maybe… as i said, stretch is really old…
                          I do not know if you can upgrade OS in place from stretch
                          pretty sure u need to upgrade node and npm too
                          node -v
                          npm -v
                          what pi is this ?
                          uname -a
                            Peter @sdetweil
                            @sdetweil I think it is a Pi2b.
                            In 2017 I built this MM and it has been running well since.
                            So, that is my question: update of not.
                            It took me very long to build, and I do not want to start all over again.
                            Peter
                              sdetweil @Peter
                              @peter do not update
                                Peter @sdetweil
                                @sdetweil 😁
                                Saves a lot of work!
                                Maybe I start a fresh install some day.
                                Thanks for your help.
                                Peter
