    Should I update?
    16 Posts 3 Posters 5.0k Views 4 Watching
      sdetweil @MyMirror
      @mymirror jessie is very old
      4 releases back now. almost nothing will support running there now
      I would also suggest some of the mechanisms to backup over the local network
      https://raspberrypi.stackexchange.com/questions/125137/how-to-backup-entire-raspberry-pi-sd-card-over-network
        MyMirror
        Hi Sam,
        yes i know :-( … very old.
        in the meantime I got the system on “Stretch” and wanted to take the next step to “Buster”.
        But I get the following error (on german):
        PGP error: http://ftp.de.debian.org/debian buster InRelease: The following signatures could not be verified because their public key is not available …
        How can I adjust/correct this?
        Thanks a lot
          sdetweil @MyMirror
          @mymirror i do not know… buster is also not current
            Peter @sdetweil
            @sdetweil finally I tried the update: MM will not start anymore.
            I am on stretch by the way.
            Peter
              sdetweil @Peter
              @peter show me the messages… fromn npm start
              stretch is WAY downlevel…
              need to get to buster(legacy) or bullseye…
              the internet keeps changing things every week… stetch is 4 years old now
                Peter
                Is it possible to update without having to start all over?
                Peter
                  sdetweil @Peter
                  @peter maybe… as i said, stretch is really old…
                  I do not know if you can upgrade OS in place from stretch
                  pretty sure u need to upgrade node and npm too
                  node -v
                  npm -v
                  what pi is this ?
                  uname -a
                    Peter @sdetweil
                    @sdetweil I think it is a Pi2b.
                    In 2017 I built this MM and it has been running well since.
                    So, that is my question: update of not.
                    It took me very long to build, and I do not want to start all over again.
                    Peter
                      sdetweil @Peter
                      @peter do not update
                        Peter @sdetweil
                        @sdetweil 😁
                        Saves a lot of work!
                        Maybe I start a fresh install some day.
                        Thanks for your help.
                        Peter
