    Weather not displaying envcanada provider
    14 Posts 5 Posters 6.4k Views 5 Watching
      sdetweil @lexcyr
      @lexcyr can I show the mm startup messages
      L 1 Reply Last reply
      • L
        lexcyr @sdetweil
        @sdetweil here is it:
        • crazylegsC
          crazylegs @lexcyr
          @lexcyr
          I notice you have provCode commented out in your config file. The envcanada provider requires that parm, so uncomment and see if your problem is resolved.
          • L
            lexcyr @crazylegs
            @crazylegs Already and still not working
              sdetweil @lexcyr
              @lexcyr using your config, and the MM config set to address:“0.0.0.0”
              I see in the dev window
              Access to XMLHttpRequest at
              'https://thingproxy.freeboard.io/fetch/https://dd.weather.gc.ca/citypage_weather/xml/QC/s0000620_e.xml' from origin 'http://0.0.0.0:8090' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
              but using address:“localhost” works ok
              • L
                lexcyr @sdetweil
                @sdetweil Thank you.
                you are right it’s working with localhost, but now i don’t know how to make it listen to other interface in the sametime to be able to access to it remotely. :(
                  sdetweil @lexcyr
                  @lexcyr try this, not sure
                  find the ip address of the pi,
                  ipconfig, look in your router, …whatever way
                  replace
                  address:"localhost",
                  with
                  address:"???",
                  like on my machine
                  address:"192.168.2.106",
                  where ??? is the ip address
                  in my MMM-Config, this address choice is in the dropdown list
                  • L
                    lexcyr @sdetweil
                    @sdetweil Just tried it, now i am able to remotely connect to MM but the weither is gone again :(.
                      sdetweil @lexcyr
                      @lexcyr bummer
                      this may need a proxy to get around this… (code change)
                        joebloe
                        I have the same problem with envcanada provider. I start a fresh installation and it’s always in loading mode.
                        I use version 2.18.
                        Do you have a solution ou an eta for a fix ?
                        Thanks!
                        karsten13K 1 Reply Last reply
                        • karsten13K
                          karsten13 @joebloe
                          found a solution meanwhile, will provide a PR in the github repo
