    Time wont change even if timezone is correct - WIFI
    6 Posts 3 Posters 4.0k Views 2 Watching
      seklind
      Re: Time is not changing
      Im trying to get the right time on my raspberry pi 3 but even if the timezone if correct it wont change the actual clock over WIFI. It works if im connected via ethernet. Has anyone solved this?
        mochman Module Developer
        Did you try this yet? If so, what other things have you tried?
        • A
          AAPS
          I have it set up on my raspberry pi 3 too, but I use Ethernet for the whole thing. All I did was go to the menu, and after searching around a bit, I found out how to change the settings for time ( I put EST since I live in the east of the USA). It changed right away. I hope this helps and sorry if it doesn’t.
            seklind
            Thanks for the answers, had a bit of vacation during christmas but will sure try this! Will come back with results in a while :)
            • A
              AAPS
              By the way, have you set up motion detection? I am trying to, but I don’t have any idea what to do. Do you know?
                seklind @AAPS
                @AAPS hey! I havent done that yet but i think i will do, will keep you posted when im done, BTW check this one out https://helentronica.com/2016/01/11/magic-mirror-with-motion-detector/
