    Do any of you actually have functioning Motion detection with CEC on a TV?
    motion-sensorcameramodules
    6 Posts 3 Posters 1.2k Views 4 Watching
      Arynio
      So basically I have been trying the whole day to get any motion detection module to work with CEC. I used to have a normal pc screen and everything worked fine, but it broke so I am now trying to use an old TV that has CEC. But I can’t get any of the module that supports CEC to work, neither with a pir or a webcam.
      So, do any of you have functioning Motion detection with CEC on a TV and could give me tips and tricks which modules work and what your setup is?
        sdetweil @Arynio
        @arynio does the cec command work from the command line?
        once u get that to work find module that will let u specify the commands, or edit the code
          Arynio @sdetweil
          @sdetweil Yes that works, but I am an absolute coding noob, so I don’t know how to edit code or anything
            sdetweil @Arynio
            @arynio all the pir modules do the same thing
            the node_helper.js issues a command to turn off the display and another to turn it back on
            look at the code and you will see a text string
            ‘something …’
            (single or double quotes)
            change the string to what you tested works for each
              dondidge
              I just have to say that this post where Sam points out that:
              "all the pir modules do the same thing
              the node_helper.js issues a command to turn off the display and another to turn it back on"
              I had been looking for some guideposts for a long time in this area, and your post made it clear what was needed, and I was able to do it. Your comments made a huge difference, even two years later.
              Using your technique I was able to fix the monitor on and standby commands in the Remote Control and Pir modules.
              Thanks!
                sdetweil @dondidge
                @dondidge the newer versions of PIR modules handle the CEC commands now…
                some give you config options so you don’t have to edit the code (which is a bad thing for updates)
                but glad you found the forums helpful
