    Trying to write my own Module...
    31 Posts 5 Posters 22.4k Views 5 Watching
    • N Offline
      nbrenn
      Thanks for the great support.
      I currently have no errors with what you’ve helped provide me with. However, it displays the else condition, and NO DATA.
      Right now, my MMM-EMonitor.js looks like the following:
      Module.register ("MMM-EMonitor", {
          //default module config.
          defaults: {
              // Insert defaults here
              interval: 900000 // Every 15 mins
          getStyles: function() {
              return ["MMM-EMonitor.css"];
          // Define the start sequence
          start: function() {
              Log.log("Starting module: " + this.name);
              //this.securitykey = REDACTED;
              this.url = 'https://api.emonitor.us/location/getCurrentData?security_key=REDACTED';
              this.getCurrentData(this);
         getCurrentData: function(that) {
             that.sendSocketNotification('GET-CURRENT-DATA', that.url);
             setTimeout(that.getCurrentData, that.config.interval, that);
         getDom: function(){
        	if(this.xml){
         	 var channels = this.xml.getElementsByTagName("channel");
         	 for(var i = 0; i < channels.length; i++){
          	   for(var n = 0; n < channels[i].children.length; n++){
             		if(channels[i].children[n].tagName === "name" || channels[i].children[n].tagName === "watts"){
                	var element = document.createElement("div");
                	element.classList.add(channels[i].children[n].tagName);
                	element.innerHTML = channels[i].children[n].textContent;
                	wrapper.appendChild(element);
        	} else {
          		wrapper.innerHTML = "NO DATA";
        	return wrapper;
      and my css looks like the following:
      .MMM-EMonitor .centered {
          text-align: center;
      Like I mentioned, the NO DATA is showing up. The security key is working, and returns the XML which I have in my original post.
        mochman Module Developer
        You don’t have this.xml defined anywhere in your script. If you look at @strawberry-3-141’s post, it says:
        I’m assuming that you saved your server response into this.xml
        You need to create a function that uses the URL and saves that data in a variable called xml. Since your program never does that, this.xml isn’t defined so your if/else always goes to “NO DATA”.
        Why do you have
        in your program? Did you just see it in another persons code? This code snippet sends your URL to node_helper.js. Are you using that node_helper to pull the XML data from the website? If so, you’re going to need a socketNotificationReceived function to get the data and put it into the xml variable.
        The modules documentation shows you some examples of that.
        • N Offline
          nbrenn
          Ahh, that makes sense. I do not have a node_helper.js, and I had the getCurrentData function because I tried to replicate a different module. I will remove these lines of code since they serve no purpose for me at the moment.
          I’ll try to take a look at examples to see how to save the data into the xml variable, so that this.xml can be used.
            MMM-EMonitor.js
                defaults: {
                    interval: 900000, // Every 15 mins
                    security_key: null,
                    animationSpeed: 1000
                start: function() {
                    this.loaded = false;
                    this.xml = null;
                    this.url = 'https://api.emonitor.us/location/getCurrentData?security_key=';
                    setInterval(this.getCurrentData(), this.config_interval);
               getCurrentData: function() {
                    var self = this;
                    var xhttp = new XMLHttpRequest();
                    xhttp.onreadystatechange = function() {
                            if (this.readyState == 4 && this.status == 200) {
                                    self.xml = self.parseXML(this.responseText);
                                    self.loaded = true;
                                    self.updateDom(self.config.animationSpeed);
                    xhttp.open("GET", this.url+this.config.security_key, true);
                    xhttp.send();
               getDom: function(){
                    if(!this.loaded) {
                            wrapper.innerHTML = "Loading...";
                            return wrapper;
                    if(this.xml !== null){
                     var table = document.createElement("table");
                     table.classList.add("xsmall", "table");
                       var row = document.createElement("tr");
                            var element = document.createElement("td");
                            row.appendChild(element);
                       table.appendChild(row);
                     wrapper.appendChild(table);
                    } else {
                            console.log("Returned no Data");
                    return wrapper;
               parseXML: function(xmlStr){
                    return ( new window.DOMParser() ).parseFromString(xmlStr, "text/xml");
            Your config.js should have:
                                    module: 'MMM-EMonitor',
                                    position: 'top_left',
                                            security_key: 'XXXXXXXXXXXXXXX'  //your security key
            This just displays everything in a large table. You may want to modify the for loop to not display data when the wattage is 0, that should get rid of a bunch of rows.
            • N Offline
              nbrenn
              This is awesome.
              A few clarifying questions:
              • Is the purpose of the xhttp.open("GET"... line to make the API call to the website? Is this when the connection is made to the XML page?
              • So, you’re going through each "channel" and creating a row in the table for each channel? And then for each channel’s name and wattage, a data object is created?
              • If I didn’t have any .css file, would the data still show up?
              Thanks for the clarifications, and again, thanks for the great support. This community is top-notch!
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @nbrenn
                @nbrenn
                1. yes the xmlhttprequest is also better known as ajax request
                2. for each channel a row will be created and for name and watts a column will be created with their specific values
                3. the data will still be displayed, but without any custom styling
                • N Offline
                  nbrenn
                  I’m trying to display just the names where the watts that are != 0. I want both the values greater than 0 and the values less than 0 (in order to include the negative values from the solar generation).
                  I attempted to modify the getDom. It is displaying every names in the .XML and shows the watts value only if it is != 0. But how do I also remove the names that are 0? The output currently looks like the following:
                  Power Panel        66
                  Outlets            20
                  Heat Pump
                  Oven
                  East Solar Panel  -70
                  West Solar Panel  -50
                  getDom: function(){
                          if(!this.loaded) {
                                  return wrapper;
                                  if (channels[i].children[n].textContent != 0){
                          } else {
                          return wrapper;
                    Looks like you need to modify your other if/then statement. The one you’ve modified checks both the name and watts to see if they are !=0. Since the name always !=0, it’s displayed.
                    • N Offline
                      nbrenn
                      It looks like the values are not updating. (The wattage values didn’t change at all overnight).
                      Should the line:
                      be changed to:
                      setInterval(this.getCurrentData(), this.interval);
                      Are we calling the interval variable in the config incorrectly?
                      Thanks!
                        @nbrenn this.config.interval
                        • N Offline
                          nbrenn
                          For posterity, I modified the if statement as follows, to remove the row items that have a 0 for wattage:
                          if (channels[i].children[n].textContent != 0) {
                               element.innterHTML = channels[i].children[n].textContent;
                          else {
                               table.removeChild(row);
                            Glad it all worked out for you!
                            • N Offline
                              nbrenn
                              I’m working on getting historical data (my API has a function getHistoricalData). The XML looks like the following:
                              <Time Time="2016-11-03 00:00:00">
                              <channel channel="194882" name="Main Power Main Panel">
                              <kWh>0.319</kWh>
                              </channel>
                              <channel channel="194885" name="Outlet 1">
                              <kWh>0.000</kWh>
                              </channel>
                              <channel channel="194886" name="Solar Panel 1">
                              <kWh>-5.737</kWh>
                              </channel>
                              <channel channel="194887" name="Solar Panel 2">
                              <kWh>-4.877</kWh>
                              </channel>
                              The difference between this XML output, and the XML output from my getCurrentData call, is that name is not it’s own element. With the old function, <name> was in brackets. Now, it is name = ....
                              Would be getDom be the same as it was for getCurrentData, or is it different since it’s name= and not it’s own <name> ... </name>
                                You’re going to have to modify the code to get that info. Take a look here for info on how it’s done.
                                N 2 Replies Last reply Reply Quote 0
                                • N Offline
                                  nbrenn @mochman
                                  @mochman Thanks for sharing the link to the w3 schools page! I managed to get it working by following the example on the website. Glad I learned something in the process! Happy New Year!
                                  • N Offline
                                    nbrenn @mochman
                                    @mochman ->
                                    How would I go about formatting my table? I would like to have each column have it’s own title, like “Load” and “kWh”. Is it also possible to put them into a tabulated table?
                                    My getDOM currently looks like the following:
                                    getDom: function(){
                                            if(!this.loaded) {
                                                    return wrapper;
                                    		name = channels[i].getAttribute('name');
                                    		if(channels[i].children[n].tagName === "kWh"){
                                    			element.innerHTML = name + channels[i].children[n].textContent;
                                            } else {
                                            return wrapper;
                                      You should just need to put
                                      var header = document.createElement("th");
                                      var header2 = document.createElement("th");
                                      header.innerHTML = "Load";
                                      row.appendChild(header);
                                      header2.innerHTML = "KWh";
                                      row.appendChild(header2);
                                      before
                                      You can add a title by modifying your config.js file to add a header.
                                      The documentation for that is here.
                                      • N Offline
                                        nbrenn @mochman
                                        @mochman Thanks a lot! I’ll take a look at the documentation and try your suggestion.
                                        Have a good weekend!
                                        • N Offline
                                          nbrenn @mochman
                                          @mochman I have another question. As shown below in the attached image, I am appending the name to the kWh values. How do I put the name into the Load column and the numbers into their kWh column?
                                          In this case, the “name” is in the same object as the channel, so that’s why I extracted it the way I do in my code… I have the name as a variable, but I can’t seem to put it into it’s own column.
                                          Code:
                                             getDom: function(){
                                                  if(!this.loaded) {
                                                          return wrapper;
                                          	 header2.innerHTML = "kWh";
                                          			element.innerHTML = name + " " + channels[i].children[n].textContent;
                                                  } else {
                                                  return wrapper;
                                          • N Offline
                                            nbrenn
                                            I am trying to begin the next iteration of my module.
                                            I have the real-time energy usage, and monthly power usage being displayed in a list in the top left and right corners of my mirror.
                                            I am hoping to do something similar to the following:
                                            • Take a value from my Monthly Usage, and then display it in the center of my mirror with a sentence like, “Your monthly power usage is: XXX Watts”.
                                            Since this monthly energy usage module is in the top right of my mirror, how would I extract a value or variable from that module and then display it into the center of the mirror.
                                            So basically, I have a long list of power usages being displayed on my mirror, but I would like to display a sentence or two about that data on another part of my mirror - extracting a value from the module and displaying it in the center of the mirror. Can this be done using the same .js code in the module, and just modifying the .css?
                                            strawberry 3.141S 1 Reply Last reply Reply Quote 1
