    Trying to write my own Module...
    31 Posts 5 Posters 23.1k Views 5 Watching
    • N
      nbrenn @strawberry 3.141
      @strawberry-3.141 Thanks for the snippet! I have a better idea of how to extract the data from the XML with your example.
      If I want to simply output what you have provided in your post, would I need to simply put your snippet into my getDom() function and add the .name to my .css file (similar to how I have the .watts)?
      So I know that’s probably incorrect, but I just tried it and an error returned:
      Cannot read property getElementsByClassName of null. I think that I am having trouble understanding how to create the div object for which to add in the data.
      cowboysdudeC strawberry 3.141S 2 Replies Last reply
      • cowboysdudeC
        cowboysdude Module Developer @nbrenn
        @nbrenn post what you’ve rewritten so they can better understand where your error may be and what I do [whcn I added humidity to the stock weather app] was to look at other modules and pick it apart to see how they were using div and such for styling to better get an understanding how it fit together. These guys are awesome, they like to help!
        Actually posting what you have now would help me too! :) I’m trying to create something myself.
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @nbrenn
          @nbrenn I’m assuming that you saved your server response into this.xml
          getDom: function(){
            if(this.xml){
              var channels = this.xml.getElementsByTagName("channel");
              for(var i = 0; i < channels.length; i++){
                for(var n = 0; n < channels[i].children.length; n++){
                  if(channels[i].children[n].tagName === "name" || channels[i].children[n].tagName === "watts"){
                    var element = document.createElement("div");
                    element.classList.add(channels[i].children[n].tagName);
                    element.innerHTML = channels[i].children[n].textContent;
                    wrapper.appendChild(element);
            } else {
              wrapper.innerHTML = "NO DATA";
            return wrapper;
          this would create two div container for every channel one for the name and the other for watts. each of them would have the css class .name or .watts
          • N
            nbrenn
            Thanks for the great support.
            I currently have no errors with what you’ve helped provide me with. However, it displays the else condition, and NO DATA.
            Right now, my MMM-EMonitor.js looks like the following:
            Module.register ("MMM-EMonitor", {
                //default module config.
                defaults: {
                    // Insert defaults here
                    interval: 900000 // Every 15 mins
                getStyles: function() {
                    return ["MMM-EMonitor.css"];
                // Define the start sequence
                start: function() {
                    Log.log("Starting module: " + this.name);
                    //this.securitykey = REDACTED;
                    this.url = 'https://api.emonitor.us/location/getCurrentData?security_key=REDACTED';
                    this.getCurrentData(this);
               getCurrentData: function(that) {
                   that.sendSocketNotification('GET-CURRENT-DATA', that.url);
                   setTimeout(that.getCurrentData, that.config.interval, that);
               getDom: function(){
              	if(this.xml){
              	} else {
              	return wrapper;
            and my css looks like the following:
            .MMM-EMonitor .centered {
                text-align: center;
            Like I mentioned, the NO DATA is showing up. The security key is working, and returns the XML which I have in my original post.
              mochman Module Developer
              You don’t have this.xml defined anywhere in your script. If you look at @strawberry-3-141’s post, it says:
              You need to create a function that uses the URL and saves that data in a variable called xml. Since your program never does that, this.xml isn’t defined so your if/else always goes to “NO DATA”.
              Why do you have
              in your program? Did you just see it in another persons code? This code snippet sends your URL to node_helper.js. Are you using that node_helper to pull the XML data from the website? If so, you’re going to need a socketNotificationReceived function to get the data and put it into the xml variable.
              The modules documentation shows you some examples of that.
              • N
                nbrenn
                Ahh, that makes sense. I do not have a node_helper.js, and I had the getCurrentData function because I tried to replicate a different module. I will remove these lines of code since they serve no purpose for me at the moment.
                I’ll try to take a look at examples to see how to save the data into the xml variable, so that this.xml can be used.
                  MMM-EMonitor.js
                      defaults: {
                          interval: 900000, // Every 15 mins
                          security_key: null,
                          animationSpeed: 1000
                      start: function() {
                          this.loaded = false;
                          this.xml = null;
                          this.url = 'https://api.emonitor.us/location/getCurrentData?security_key=';
                          setInterval(this.getCurrentData(), this.config_interval);
                     getCurrentData: function() {
                          var self = this;
                          var xhttp = new XMLHttpRequest();
                          xhttp.onreadystatechange = function() {
                                  if (this.readyState == 4 && this.status == 200) {
                                          self.xml = self.parseXML(this.responseText);
                                          self.loaded = true;
                                          self.updateDom(self.config.animationSpeed);
                          xhttp.open("GET", this.url+this.config.security_key, true);
                          xhttp.send();
                     getDom: function(){
                          if(!this.loaded) {
                                  wrapper.innerHTML = "Loading...";
                                  return wrapper;
                          if(this.xml !== null){
                           var table = document.createElement("table");
                           table.classList.add("xsmall", "table");
                             var row = document.createElement("tr");
                                  var element = document.createElement("td");
                                  row.appendChild(element);
                             table.appendChild(row);
                           wrapper.appendChild(table);
                          } else {
                                  console.log("Returned no Data");
                          return wrapper;
                     parseXML: function(xmlStr){
                          return ( new window.DOMParser() ).parseFromString(xmlStr, "text/xml");
                  Your config.js should have:
                                          module: 'MMM-EMonitor',
                                          position: 'top_left',
                                                  security_key: 'XXXXXXXXXXXXXXX'  //your security key
                  This just displays everything in a large table. You may want to modify the for loop to not display data when the wattage is 0, that should get rid of a bunch of rows.
                  • N
                    nbrenn
                    This is awesome.
                    A few clarifying questions:
                    • Is the purpose of the xhttp.open("GET"... line to make the API call to the website? Is this when the connection is made to the XML page?
                    • So, you’re going through each "channel" and creating a row in the table for each channel? And then for each channel’s name and wattage, a data object is created?
                    • If I didn’t have any .css file, would the data still show up?
                    Thanks for the clarifications, and again, thanks for the great support. This community is top-notch!
                    • strawberry 3.141S
                      @nbrenn
                      1. yes the xmlhttprequest is also better known as ajax request
                      2. for each channel a row will be created and for name and watts a column will be created with their specific values
                      3. the data will still be displayed, but without any custom styling
                      • N
                        nbrenn
                        I’m trying to display just the names where the watts that are != 0. I want both the values greater than 0 and the values less than 0 (in order to include the negative values from the solar generation).
                        I attempted to modify the getDom. It is displaying every names in the .XML and shows the watts value only if it is != 0. But how do I also remove the names that are 0? The output currently looks like the following:
                        Power Panel        66
                        Outlets            20
                        Heat Pump
                        Oven
                        East Solar Panel  -70
                        West Solar Panel  -50
                        getDom: function(){
                                if(!this.loaded) {
                                        return wrapper;
                                        if (channels[i].children[n].textContent != 0){
                                } else {
                                return wrapper;
                          Looks like you need to modify your other if/then statement. The one you’ve modified checks both the name and watts to see if they are !=0. Since the name always !=0, it’s displayed.
                          • N
                            nbrenn
                            It looks like the values are not updating. (The wattage values didn’t change at all overnight).
                            Should the line:
                            be changed to:
                            setInterval(this.getCurrentData(), this.interval);
                            Are we calling the interval variable in the config incorrectly?
                            Thanks!
                            • strawberry 3.141S
                              @nbrenn this.config.interval
                              Reply Quote 2
                              • N
                                nbrenn
                                For posterity, I modified the if statement as follows, to remove the row items that have a 0 for wattage:
                                if (channels[i].children[n].textContent != 0) {
                                     element.innterHTML = channels[i].children[n].textContent;
                                else {
                                     table.removeChild(row);
                                  Glad it all worked out for you!
                                  • N
                                    nbrenn
                                    I’m working on getting historical data (my API has a function getHistoricalData). The XML looks like the following:
                                    <Time Time="2016-11-03 00:00:00">
                                    <channel channel="194882" name="Main Power Main Panel">
                                    <kWh>0.319</kWh>
                                    </channel>
                                    <channel channel="194885" name="Outlet 1">
                                    <kWh>0.000</kWh>
                                    </channel>
                                    <channel channel="194886" name="Solar Panel 1">
                                    <kWh>-5.737</kWh>
                                    </channel>
                                    <channel channel="194887" name="Solar Panel 2">
                                    <kWh>-4.877</kWh>
                                    </channel>
                                    The difference between this XML output, and the XML output from my getCurrentData call, is that name is not it’s own element. With the old function, <name> was in brackets. Now, it is name = ....
                                    Would be getDom be the same as it was for getCurrentData, or is it different since it’s name= and not it’s own <name> ... </name>
                                      You’re going to have to modify the code to get that info. Take a look here for info on how it’s done.
                                      N 2 Replies Last reply
                                      • N
                                        nbrenn @mochman
                                        @mochman Thanks for sharing the link to the w3 schools page! I managed to get it working by following the example on the website. Glad I learned something in the process! Happy New Year!
                                        • N
                                          nbrenn @mochman
                                          @mochman ->
                                          How would I go about formatting my table? I would like to have each column have it’s own title, like “Load” and “kWh”. Is it also possible to put them into a tabulated table?
                                          My getDOM currently looks like the following:
                                          getDom: function(){
                                                  if(!this.loaded) {
                                                          return wrapper;
                                          		name = channels[i].getAttribute('name');
                                          		if(channels[i].children[n].tagName === "kWh"){
                                          			element.innerHTML = name + channels[i].children[n].textContent;
                                                  } else {
                                                  return wrapper;
                                            You should just need to put
                                            var header = document.createElement("th");
                                            var header2 = document.createElement("th");
                                            header.innerHTML = "Load";
                                            row.appendChild(header);
                                            header2.innerHTML = "KWh";
                                            row.appendChild(header2);
                                            before
                                            You can add a title by modifying your config.js file to add a header.
                                            The documentation for that is here.
