MM 2.18 not starting, crashes on startup [exit_code=512]
9 Posts 2 Posters 1.5k Views 2 Watching
    p1lspeda
    I ran into a really annoying problem.
    All I wanted to do, was update a newsfeed. Unfortunately it went all downhill from there.
    What I have done so far:
    • fresh install
    • manually installed missing modules via npm e.g. npm install request
    • adjusted permissions for chrome sandbox
    This all has not resulted in success.
    As my MM wouldn’t boot up into “normal” mode, i.e. MM shows up with all the bells and whistles (via pm2), I did the following:
    • I disabled all modules and started adding one module at a time, starting with just the clock
    • I started MM in servermode
    • connected via VNC to my MM
    • opened chrome and opened 127.0.0.1:8080
      This resulted in a MM interface with a clock.
      My MM seems to generally be working.
    I went through and added one module at a time and repeated above mentioned steps.
    Last module, that caused trouble was MMM-CalendarWeek.
    This could be a coincidence though.
    The pm2 log states
    pi@magicmirror:~ $ ./MagicMirror/run-start.sh
    [16.02.2022 20:04.41.387] [LOG]   Starting MagicMirror: v2.18.0
    [16.02.2022 20:04.41.405] [LOG]   Loading config ...
    [16.02.2022 20:04.41.418] [LOG]   Loading module helpers ...
    [16.02.2022 20:04.41.422] [LOG]   No helper found for module: MMM-Cursor.
    [16.02.2022 20:04.41.425] [LOG]   No helper found for module: clock.
    [16.02.2022 20:04.41.866] [LOG]   Initializing new module helper ...
    [16.02.2022 20:04.41.868] [LOG]   Module helper loaded: MMM-PublicTransportHafas
    [16.02.2022 20:04.41.993] [LOG]   Initializing new module helper ...
    [16.02.2022 20:04.41.996] [LOG]   Module helper loaded: MMM-Fuel
    [16.02.2022 20:04.42.057] [LOG]   Initializing new module helper ...
    [16.02.2022 20:04.42.059] [LOG]   Module helper loaded: MMM-Weather
    [16.02.2022 20:04.42.060] [LOG]   No helper found for module: MMM-Year-Progress.
    [16.02.2022 20:04.42.584] [LOG]   Initializing new module helper ...
    [16.02.2022 20:04.42.586] [LOG]   Module helper loaded: MMM-Holiday
    [16.02.2022 20:04.43.072] [LOG]   Initializing new module helper ...
    [16.02.2022 20:04.43.074] [LOG]   Module helper loaded: MMM-DWD-Pollen
    [16.02.2022 20:04.43.117] [LOG]   Initializing new module helper ...
    [16.02.2022 20:04.43.119] [LOG]   Module helper loaded: newsfeed
    [16.02.2022 20:04.43.120] [LOG]   All module helpers loaded.
    [16.02.2022 20:04.43.292] [LOG]   Starting server on port 8080 ...
    [16.02.2022 20:04.43.317] [LOG]   Server started ...
    [16.02.2022 20:04.43.319] [LOG]   Connecting socket for: MMM-PublicTransportHafas
    [16.02.2022 20:04.43.321] [LOG]   Connecting socket for: MMM-Fuel
    [16.02.2022 20:04.43.323] [LOG]   Starting module helper: MMM-Fuel
    [16.02.2022 20:04.43.324] [LOG]   Connecting socket for: MMM-Weather
    [16.02.2022 20:04.43.326] [LOG]   Connecting socket for: MMM-Holiday
    [16.02.2022 20:04.43.327] [LOG]   Starting node_helper for: MMM-Holiday
    [16.02.2022 20:04.43.329] [LOG]   Connecting socket for: MMM-DWD-Pollen
    [16.02.2022 20:04.43.330] [LOG]   MMM-DWD-Pollen helper started ...
    [16.02.2022 20:04.43.331] [LOG]   Connecting socket for: newsfeed
    [16.02.2022 20:04.43.332] [LOG]   Starting node helper for: newsfeed
    [16.02.2022 20:04.43.333] [LOG]   Sockets connected & modules started ...
    [16.02.2022 20:05.07.955] [LOG]   Launching application.
    **[2139:0216/200529.312115:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=512
    [2139:0216/200529.355982:ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service.
    [2283:0216/200530.410224:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
    [2309:0216/200530.708608:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
    [2259:0216/200530.832997:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.```**
    pi@magicmirror:~ $ npm -v
    8.3.1
    pi@magicmirror:~ $ node -v
    v16.14.0
    pi@magicmirror:~ $ cat /etc/os-release
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    I really have no idea what else I can do.
    Any help is much appreciated
    P
    S 1 Reply Last reply Feb 16, 2022, 7:33 PM Reply Quote 0
    • S Away
      sdetweil @p1lspeda
      @p1lspeda see
      P 4 Replies Last reply Feb 16, 2022, 8:57 PM Reply Quote 0
        p1lspeda @sdetweil
        Thanks for the link (I had already searched through that topic).
        I can’t find anything related there though to my problem.
        I cannot find any clues in regards to my ERROR
        All my modules load correctly
          p1lspeda @sdetweil
          Ran my config (I just commented the various modules within the config) with just the default “clock” module and still got the Error msg,
          Does that prevent them (= the unwanted modules) from being loaded ?
          pi@magicmirror:~/MagicMirror $ ./run-start.sh
          [17.02.2022 06:27.16.057] [LOG]   Starting MagicMirror: v2.18.0
          [17.02.2022 06:27.16.075] [LOG]   Loading config ...
          [17.02.2022 06:27.16.085] [LOG]   Loading module helpers ...
          [17.02.2022 06:27.16.090] [LOG]   No helper found for module: MMM-Cursor.
          [17.02.2022 06:27.16.094] [LOG]   No helper found for module: clock.
          [17.02.2022 06:27.16.096] [LOG]   All module helpers loaded.
          [17.02.2022 06:27.16.292] [LOG]   Starting server on port 8080 ...
          [17.02.2022 06:27.16.318] [LOG]   Server started ...
          [17.02.2022 06:27.16.320] [LOG]   Sockets connected & modules started ...
          [17.02.2022 06:27.16.736] [LOG]   Launching application.
          [17158:0217/062738.598660:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=512
          [17158:0217/062738.647202:ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service.
          [17230:0217/062739.406765:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          [17256:0217/062739.710018:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
          [17200:0217/062739.830940:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
            p1lspeda @sdetweil
            I’ve done some more investigating.
            After running the run-start.sh script and noticing that MM doesn’t start as intended, I stop MM by pressing ctrl+c within the terminal.
            I can see via VNC that “Electron” shuts down.
            So I assume that my problem has something to do with electron
            pi@magicmirror:~ $ cd MagicMirror
            pi@magicmirror:~/MagicMirror $ ./node_modules/.bin/electron --version
            v16.0.9
            See screenshot:
            Hope this helps trying to figure out what I going on.
            P
              p1lspeda @sdetweil
              This is really weird, trying to launch chromium (as in your run-start.sh) give’s me an Error
              pi@magicmirror:~ $ chromium-browser
              [0217/142409.967126:ERROR:elf_dynamic_array_reader.h(61)] tag not found
              S 1 Reply Last reply Feb 17, 2022, 2:00 PM Reply Quote 0
              • S Away
                sdetweil @p1lspeda
                @p1lspeda see this post, for a possible fix
                https://forum.magicmirror.builders/topic/10322/flashing-and-green-lines-after-couple-of-minutes/2?_=1645106186637
                P 1 Reply Last reply Feb 17, 2022, 2:39 PM Reply Quote 0
                  p1lspeda @sdetweil
                  things are getting better (but still really weird).
                  I disabled the OpenGL driver and now my MM is 96% back up and running.
                  MMM-CalendarWeek causes MM not to show up.
                  After disabling it within the config.js, its up and running.
                  Thanks for all your help!
                  S 1 Reply Last reply Feb 17, 2022, 9:45 PM Reply Quote 0
                  • S Away
                    sdetweil @p1lspeda
                    @p1lspeda see that link I posted above about blank screen
