    MMM-Podcast2 - MM doesnt start config.js
    2 Posts 2 Posters 524 Views 2 Watching
    • F Offline
      FlorianRD
      Hello
      Since an update from MagicMirror failed, I had to reinstall everything.
      Everything works except for Podcast2. I copied it to the modules folder as usual and then chose npm install. After configuring the config.js file (as in the example), the mirror no longer starts. Boots up but doesn’t load the config.js properly.
      Does somebody has any idea?
        sdetweil @FlorianRD
        @florianrd can you sj
        how the messages from startup?
        npm start or pm2 logs if using pm2
