    Starting over on MM install - still shows errors
    4 Posts 2 Posters 981 Views 2 Watching
    • F Offline
      fribse
      Hi Guys
      I’m having some problems with the installation.
      I’ve done a brand new Raspbian Buster install.
      Fully updated.
      I then ran @sdetweil 's install script.
      I’m now modifying the module config one by one, and installing the custom modules.
      I’ve yet to install a custom module, so far I have changed the software to da-DK, I’ve made the compliments module fetch my gist compliments file, and I’ve changed the calendar module to use a danish provider.
      I already see these two messages:
      0|MagicMirror  | [3635:0225/103036.868905:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMirror  | [3680:0225/103037.331723:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
        sdetweil @fribse
        @fribse as I recall these are incorrect error messages, reported against electron.
        nothing we can do about them
        • F Offline
          fribse @fribse
          So I did a new install completely from scratch on a Raspbian Buster, and did a ‘manual’ install this time, still same error:
          [25.02.2022 16:00.46.615] [LOG] Launching application.
          [1789:0225/160048.427469:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          [1828:0225/160048.917933:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
          Monitor is in portrait mode, these settings are in boot/config.txt
          display_rotate=1
          enable_uart=1
          avoid_warnings=1
            sdetweil @fribse
            • F Offline
              fribse @sdetweil
              @sdetweil Ok, good to know, so at least it’s not them making problems for MMM-ScreenCast and MMM-RemoteControl.
