    I'm tired with Magic Mirror 6 update
    8 Posts 2 Posters 2.5k Views 2 Watching
      Smotx
      to be a great guy, i have launch update of MM2.5 to 2.6…
      But now : MM is dead !
      1 hour i try to repair but nothing…
      pi@raspmagicmirror1:~ $ npm start
      npm ERR! path /home/pi/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2019-03-09T16_22_37_115Z-debug.log
      pi@raspmagicmirror1:~/MagicMirror $ npm start
      > magicmirror@2.6.0 start /home/pi/MagicMirror
      > sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-03-09T16_37_18_471Z-debug.log
      pi@raspmagicmirror1:~/MagicMirror $ ^C
      pi@raspmagicmirror1:~/MagicMirror $ npm install
      > magicmirror@2.6.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      audited 220 packages in 23.111s
      found 4 low severity vulnerabilities
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
      > cd fonts && npm install
      audited 1 package in 2.135s
      found 0 vulnerabilities
      npm WARN grunt-stylelint@0.10.0 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      added 1 package from 1 contributor, removed 1 package and audited 2427 packages in 128.03s
      found 11 vulnerabilities (6 low, 5 moderate)
      help me, please.
        sdetweil @Smotx
        @Smotx and then
        npm start
        in the MagicMirror folder again
          Smotx
          sh run-start.sh
          npm ERR! file sh
          npm ERR! magicmirror@2.6.0 start: sh run-start.sh
          npm ERR!
          npm ERR! /home/pi/.npm/_logs/2019-03-09T16_53_16_968Z-debug.log
            Smotx
            So i have try
            pi@raspmagicmirror1:~/MagicMirror $ npm install electron
            and now :
            > electron@2.0.18 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            internal/modules/cjs/loader.js:550
                throw err;
            Error: Cannot find module '../dotjs/validate'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15)
                at Function.Module._load (internal/modules/cjs/loader.js:475:25)
                at Module.require (internal/modules/cjs/loader.js:598:17)
                at require (internal/modules/cjs/helpers.js:11:18)
                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/ajv/lib/compile/index.js:8:25)
                at Module._compile (internal/modules/cjs/loader.js:654:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
                at Module.load (internal/modules/cjs/loader.js:566:32)
                at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
                at Function.Module._load (internal/modules/cjs/loader.js:498:3)
            npm ERR! errno 1
            npm ERR! electron@2.0.18 postinstall: `node install.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the electron@2.0.18 postinstall script.
            npm ERR!     /home/pi/.npm/_logs/2019-03-09T16_57_50_712Z-debug.log
              Smotx
              LOOOOL.
              Sooo i try
              pi@raspmagicmirror1:~/MagicMirror $ npm install stylelint@^9.0.0
              and result… tada … !
              > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
                  throw err;
              npm ERR! errno 1
              npm ERR! electron@2.0.16 postinstall: `node install.js`
              npm ERR!
              npm ERR! Failed at the electron@2.0.16 postinstall script.
              npm ERR!     /home/pi/.npm/_logs/2019-03-09T17_05_00_446Z-debug.log
                Smotx
                So :
                I have rename /MagicMirror/ to /BackMM/
                I have launch a new fresh install of MM 2.6
                Copy /modules/ , /config/ & /css/ from /BackMM/
                and launch MM
                It’s ok
                if it helps someone.
                *I have a little error, but i don’t know why.
                Starting node_helper.js for MMM-TPLink.
                Connecting socket for: MMM-Remote-Control
                Starting node helper for: MMM-Remote-Control
                Connecting socket for: MMM-AlexaOnOff
                Module helper started for MMM-AlexaOnOff
                Launching application.
                **ERROR! Could not find main module js file for modules
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections tha                                               t are not handled will terminate the Node.js process with a non-zero exit code.
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 8): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 9): TypeError: Cannot read property                                                'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 10): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 11): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 12): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 13): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 14): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 15): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 16): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 17): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 18): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 19): TypeError: Cannot read propert                                               y 'refs' of undefined
                (node:15900) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 20): TypeError: Cannot read propert                                               y 'refs' of undefined**
                Sat Mar 09 2019 18:49:08 GMT+0100 (CET): Triggering Xiaomi Gateway connect
                Create new news fetcher for url: https://www.francetvinfo.fr/monde.rss - Interval: 300000
                starting internet monitor node helper
                FREEBOX: "CONNECT" [object Object]
                  sdetweil @Smotx
                  @Smotx typically you also must npm install in each module folder if they have a package.json file so that their components are at the same level
                  I would start with each module over the defaults and comment them out, and back in one by one
                    Smotx
                    @sdetweil said in I'm tired with Magic Mirror 6 update:
                    Ok, i’ll try
