    Motion Detector and OSX
    6 Posts 2 Posters 1.2k Views 2 Watching
    • 0 Offline
      0v3rNuLL
      hi everyone!
      I succesfully run MM2 on a macmini late 2009. Currently im testing some modules and so far so good except for one module Motion detector. I was looking on the code on node_helper.js and found the line with the command “vcgencmd display_power 0”.
      In OSX not work but “pmset displaysleepnow” to put the screen on sleep does the trick and " caffeinate -u -t 1" to wake up.
      So i replace the command
      if (result) {
      				exec("vcgencmd display_power 0", function(err, out, code) {
      					if (err) {
      						console.error("MMM-MotionDetector: error deactivating monitor: " + code);
      					} else {
      						console.log("MMM-MotionDetector: monitor has been deactivated");
      to
      if (result) {
      				exec("pmset displaysleepnow", function(err, out, code) {
      					if (err) {
      					} else {
      Its looks like work but im getting this message on console log “pmset displaysleepnow blocked by app electron.js” and the screen keeps alive.
      Is there a way to solve this?
      Or maybe toggling the body to hide to get the black screen?
      Thanks in advance and sorry for my bad english :)
        sdetweil
        @0v3rNuLL said in Motion Detector and OSX:
        there is an npm module to work around that it appears
        https://electronjs.org/docs/api/power-save-blocker
        0 1 Reply Last reply Reply Quote 1
        • 0 Offline
          0v3rNuLL
          hi sdetweil!
          I try on node_helper.js located on MMM-MotionDetector at the begining and did not work still getting display slep prevented by electron
          here is the part i change
          //////Original code/////
          const NodeHelper = require("node_helper");
          const exec = require("child_process").exec;
          const { powerSaveBlocker } = require('electron');
          const id = powerSaveBlocker.start('prevent-app-suspension');
          console.log(powerSaveBlocker.isStarted(id));
          powerSaveBlocker.stop(id)
          Its the correct place ?
          Sorry but im totally new on node.
          Thanks in advance
            sdetweil @0v3rNuLL
            complete node helper
            	start: function () {
            		this.started = false;
            		this.isMonitorOn(function(result) {
            			console.log("MMM-MotionDetector: monitor on " + result);
            	activateMonitor: function () {
            			if (!result) {
            				let id = powerSaveBlocker.start('prevent-app-suspension');
            				if(powerSaveBlocker.isStarted(id))
            				exec("vcgencmd display_power 1", function(err, out, code) {
            					if (err) {
            						console.error("MMM-MotionDetector: error activating monitor: " + code);
            					} else {
            						console.log("MMM-MotionDetector: monitor has been activated");
            	deactivateMonitor: function () {
            			if (result) {
            					if (err) {
            					} else {
            	isMonitorOn: function(resultCallback) {
            		exec("vcgencmd display_power", function(err, out, code) {
            			if (err) {
            				console.error("MMM-MotionDetector: error calling monitor status: " + code);
            				return;
            			console.log("MMM-MotionDetector: monitor " + out);
            			resultCallback(out.includes("=1"));
            	// Subclass socketNotificationReceived received.
            	socketNotificationReceived: function (notification, payload) {
            		if (notification === "MOTION_DETECTED" && this.started === false) {
            			console.log("MMM-MotionDetector: MOTION_DETECTED, score " + payload.score);
            			this.started = true;
            			this.activateMonitor();
            		if (notification === "DEACTIVATE_MONITOR" && this.started === false) {
            			console.log("MMM-MotionDetector: DEACTIVATE_MONITOR");
            			this.deactivateMonitor();
            • 0 Offline
              0v3rNuLL
              Finally figured it out, this module now can put the screen off and on (osx el capitan).
              Here is the modification for node_helpder.js
              var cmd=require('node-cmd'); // install node-cmd (npm install node-cmd) first and add excute command osx style then change exec to cmd.get <-- return the result to analize
              			if (!result) {
              				cmd.get('caffeinate -u -t 1', function(err, out, code) {
              					if (err) {
              					} else {
              			if (result) {
              				cmd.get('pmset displaysleepnow', function(err, out, code) {
              					if (err) {
              					} else {
              		cmd.get('pmset -g powerstate IODisplayWrangler | tail -1 | cut -c29', function(err, out, code) {
              			if (err) {
              				return;
              		resultCallback(out.includes("4")); // <4 is off
              This can be marked as SOLVED :slightly_smiling_face:
              • 0 Offline
                0v3rNuLL @sdetweil
                Icant post the entire code so, link to pastebin :)
                node_helper.js
