    Cronjob
    17 Posts 5 Posters 8.1k Views 4 Watching
      MadScientist
      Why do you want to restart MM? Maybe pm2 reload mmis the better option.
      CyruS1337C 1 Reply Last reply Reply Quote 0
      • CyruS1337C Offline
        CyruS1337 Project Sponsor @MadScientist
        @MadScientist said in Cronjob:
        Why … that’s actually a good question. The problem is that if I bring the screens for about 5-6 hours and then turn back on that no picture appears on the monitors. Therefore, I would like a regular restart of my MagicMirros.
          MadScientist
          Are you using the GoogleMapsTraffic module? In that case the pm2 reload mm will do. Or a simple Ctrl+R on the mirror. The cronjob should then look something like 55 19 * * * pm2 reload mm (mine is 0 6 * * * pm2 reload mm and it works flawlessly).
          CyruS1337C 2 Replies Last reply Reply Quote 0
            Exactly, I use the modules GoogleMapsTraffi on these two monitors and these two monitors will not wake up after a while, if I turned off the monitors for several hours.
            Then tonight I will try pm2 reload mm. Unfortunately, the command pm2 restart mm did not work. Then I’m curious.
              MadScientist
              Depennding on the other modules you’re using it might be good to reload MM more than once a day. In my case once is enough. Without reloading the screen turns black after more than one day. Depending on your setup it could be better to reload it twice or 4 times a day. In the end the reload is very quick and you won’t notice anything.
                Perfect, did not know that I can reload the MagicMirror. Have always made a restart in the past. I’ll give feedback this evening on whether the cronjob works with the pm2 reload mm command
                • Z Offline
                  Zwirbel
                  @MadScientist : Is there a way to automatically reload MM once or twice a day? I have similar problems with the Netatmo module, which doesn’t pick up new data in the morning (as my WLAN is turned off during the night). A reload fixes this, but I would rather have this automatically (e.g. at 06:00 in the morning for example).
                  Maybe a simple script would help, but I don’t know where to put it.
                    The command works in the console pm2 reload mm
                    If I add it in the cron job, it will not do any reload.
                    Here is the excerpt from the crontab
                    # Edit this file to introduce tasks to be run by cron.
                    # Each task to run has to be defined through a single line
                    # indicating with different fields when the task will be run
                    # and what command to run for the task
                    # To define the time you can provide concrete values for
                    # minute (m), hour (h), day of month (dom), month (mon),
                    # and day of week (dow) or use '*' in these fields (for 'any').#
                    # Notice that tasks will be started based on the cron's system
                    # daemon's notion of time and timezones.
                    # Output of the crontab jobs (including errors) is sent through
                    # email to the user the crontab file belongs to (unless redirected).
                    # For example, you can run a backup of all your user accounts
                    # at 5 a.m every week with:
                    # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
                    # For more information see the manual pages of crontab(5) and cron(8)
                    # m h  dom mon dow   command
                    #MONTAG BIS SONNTAG UM 17:02 MAGICMIRROR RELOAD
                    02 17 * * * pm2 reload mm
                      MadScientist
                      This is my crontab:
                      Are you running crontab -ewith sudo? Because you have to run it as the user that runs MM (= most likely without sudo).
                      Edit: @Zwirbel: For me it works using a cronjob. See what I wrote above and if you have questions regarding crontab, just ask again.
                        Juhuiiiii, finally it worked. Many Thanks
                        I have always used the command sudo crontab -e and with this it did not work.
                        It works fine with the crontab -e command and then 0 6 * * * pm2 reload mm
                        Once again, thank you very much for your help!!!
