It seems like MagicMirror is already installed.
My install was working great, but after an update it broke and after trying several fixes with no success I thought an easier route would be to just install again as a fresh start.
I’ve renamed the MagicMirror folder on the Pi, and I’m using the following command to install
bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
However the install fails with this error
To prevent overwriting, the installer will be aborted.
Please rename the ~/MagicMirror folder and try again.Even after deleting the folder completely it still gives the same error.
Does anyone have any ideas?
@kellogg76 I’d format the card and then reinstall from scratch
@kellogg76 - With the latest update of Raspbian, the installation script has not kept up with the changes. I would try a manual install instead.
You’ve already deleted the folder, so run:
cd ~ git clone https://github.com/MichMich/MagicMirror.git cd MagicMirror npm install npm start
Let us know if you hit any errors.
