MagicMirror² v2.12.0 is available! For more information about this release, check out this topic.
[ORDER CLOSED] Two way mirror order in Germany
  • What size of display are you using for a 0.4m² mirror?
  • @KrawallKurt
    Hi KrawallKurt,
    in a first stepp, i will just use a part of the 0,4 with an 14" display.
    but i will increase now the size to be able to upgrade later to a 42" IR Frame setup.
    @yawns
    could you please update my record as following
    0.970 x 0.563 = 0.546 m²
  • @Goldjunge_Chriz Thx for your work 🙂
    I would also like to order 70cm x 50cm with polished edges.
  • # username sizes (m) area (m²) location additional comments pickup/delivery latest date of order
    01 yawns ~ 0.8 * 0.8 ~ 0.64 Germany, Cologne polished edges delivery Summer 2017 🙂
    02 gustav1976 0.6 * 1.8 1.08 Germany, Koblenz polished edges delivery
    03 gustav1976 1.0 * 1.2 1.20 Germany, Koblenz polished edges delivery
    04 gustav1976 1.4 * 0.8 1.12 Germany, Koblenz polished edges delivery
    05 lolobyte 0.8 * 0.6 0.48 Germany, Heilbronn polished edges pickup ASAP
    06 lolobyte 0.8 * 0.6 0.48 Germany, Heilbronn polished edges pickup ASAP
    07 Jeff 1.0 * 0.6 0.6 Germany, Karlsruhe polished edges pickup
    08 Ashidian 0.69 * 0.435 0.3 (pay 0.4) Germany, Rostock polished edges delivery
    09 cpramhofer 1.2 * 0.7 0.84 Austria, Vienna polished edges delivery
    10 Schlachtkreuzer ~ 1.0 * 1.0 ~ 1.0 Austria, Vienna polished edges delivery 2 months
    11 mcg 0.5 * 1.0 0.5 Germany, Ludwigshafen polished edges pickup in Heilbronn mid of January
    12 cfenner 0.667 * 0.667 0.45 Germany, Mannheim polished edges pickup in Heilbronn don’t care 😉
    13 sero 0.5 * 0.4 0.2 (pay 0.4) Germany, Stuttgart polished edges pickup in Heilbronn
    14 Deepgear 0.46 * 1.5 0.69 Germany, Pforzheim just cut pickup ASAP
    15 Binog 0.8 * 0.5 0.4 Germany, Cologne polished edges delivery
    16 yaye 0.5 * 0.4 0.2 (pay 0.4) Germany, Stuttgart polished edges pickup in Heilbronn
    17 Ali Baba 0.4 * 1.0 0.4 Germany, Hoyerswerda just cut delivery
    18 mantha 0.563 * 0.97 0.55 Germany, Ulm polished edges pickup in Heilbronn asap
    19 fox 0.7 * 0.4 0.28 (pay 0.4) Germany, Schwabmünchen polished edges delivery
    20 wiloo 0.7 * 0.5 0.35 (pay 0.4) Germany, Traunstein polished edges delivery
    Total 12.43 (11.76)
  • @cpramhofer
    I just saw that you changed your size from 0,476 x 0,82 to 1,2 x 0,7. In this size I can not send your mirror any more. This size would mean bulky goods and give a shipping price of approx 100 Euro to Austria (without packaging costs). In order to ship it as an international standard package, a maximum belt size of 300 cm should be adhered to. (Length + 2 * width + 2 * height). Within Germany larger packages can be sent, but unfortunately not in neighboring countries.
    @schlachtkreuzer6
    This also applies to you. Your mirror is also too big for shipping to Austria.
    I’m sorry for you both.
    Would you like to reduce your mirrors or should I remove you from the list?
    Or would you like to spend your holiday in beautiful Germany and pick up the mirror here? 🙂
  • @Goldjunge_Chriz said in Two way mirror order in Germany:
    @All
    How would it be if we let the order still run until january 15th and set next Sunday at 10 pm as a deadline for the orders?
    Sounds good to me! 🙂
    Is there a way to notify all people that replied to this thread?
  • Hallo an alle!
    Bin auch an dem Spiegel interessiert. Ich benötige einen mit 1,1m x 0,7m mit polierte Kanten.
    Ich bin von Österreich und würde den Spiegel, wenn es keine Möglichkeit zum versenden gibt, auch selber abholen und mir gleich Köln anschauen 🙂
    Brauchen würde ich den Spiegel so bald als möglich -> Rahmen und Fernseher sind fertiggestellt 😉
    Mit bestem Dank im Voraus!
  • Hallo @XxX_Cobra_XxX
    Deine Größe ist wie in meinem Post von gestern abend beschrieben leider ebenfalls zu groß zum versenden per Standartversand. Deshalb wäre Abholen natürlich super !
    Könntest du in diesem Zug vielleicht sogar die beiden Spiegel der anderen beiden Jungs aus Wien mitnehmen ? Dann wäre das Versandproblem hier ebenfalls gelöst 🙂
  • Hallo @Goldjunge_Chriz
    Ja klar ist kein Problem wenn die beiden einverstanden sind und die Transportkosten (Spritkosten) mit mir teilen würden.
    Liebe Grüße Cobra
  • @XxX_Cobra_XxX
    Wenn es ist kann ich mich auch anschließen. Dann kannst du dir evtl auch ein bisschen was sparen 😃
    Ich würde laut GoogleMaps direkt auf deinem weg nach Wien liegen.
