    RMV module issue (no live data)
    10 Posts 2 Posters 2.7k Views 2 Watching
      drfukc
      I try to setup the RMV module, but constantly fail with this message on the mirror: [Loading data] and nothing happens after.
      This message on the mirror stays forever and is never replaced with real time-table data.
      For testing I am working with a minimal setup: Clock in the upper left corner and the ‘MMM-RMV’ module in the upper right corner.
      This is my ‘MMM-RMV’ section:
             module: 'MMM-RMV',
             position: 'top_right',
                     apiKey: '12345678-1234-1234-1234-123456789abc',
                     stationId: '30000001', // default is: '30000001' - 'Frankfurt (Main) Hauptwache'
                     fDestination1: 'Frankfurt (Main) Hauptbahnhof', // default is: 'Frankfurt (Main) Hauptbahnhof'
      On the console that is used to launch the mirror application (npm start) I get the following error message:
      “Error: No connection data received. Error Code: 500”
      The HAFASReST Interface documentation tells me the following about the Error Code 500:
      Error Code 500:
      • SVC_SMS: fail to send sms
      • SVC_FAILED_SEARCH: unsuccessful search
      • SVC_NO_RESULT: no result found
      • SVC_NO_MATCH: no match found
      • INT_ERR: internal error
      For testing purposes I invalidate my apiKey into something random and receive this Error Code 403:
      Error Code 403:
      • API_AUTH: access denied for ‘key’ on ‘service’
      So I trust my real apiKey is valid and accepted by RMV.
      The other the base modules plus MMM-GoogleMapsTraffic or MMM-SoccerLiveScore are fully functional.
      Replacing this character ’ by this " has no effect in the script.
      Does anyone have an idea what may go wrong here, why am I not receiving live RMV transport data?
      Cheers
      ukc
        drfukc
        Additional information:
        Since I edit my files on a Windows machine, I want to double check the encoding of the config.js file (ANSI; UTF-8; etc).
        To verify the encoding, I execute this command in the MagicMirror/config directory: [file -i *]
        file -i *:
        config.js: text/plain; charset=us-ascii
        config.js.sample: text/plain; charset=us-ascii
        config.js.sample.js: text/plain; charset=us-ascii
        config.original.js: text/plain; charset=us-ascii
        Above outcome looks OK for me on my Raspberry Pi.
        Cheers
        ukc
          drfukc
          @all
          now I found the issue and created a Github pullrequest for the RMV module:
          In addition to the regular config file, RMV ships by default with another file:
          /home/pi/MagicMirror/modules/MMM-RMV/MMM-RMV.js
          In this file you will find below variables that are prefilled with data that will in most cases not work for the average user:
          stationId: '', // update required here
          fDestination1: '', // update required here
          fDestination2: '', // update required here
          These variables need updates.
          After a successful update, the RMV module does work nicely even with buses :-)
            sdetweil @drfukc
            @drfukc those variables are documented as needing entries in the config section in config.js
            Station ID and apiKey
            An apiKey has to be requested at RMV - opendata.
            The stationId can be found in file 'StationID.txt' or at RMV - opendata.
            The correct station name is in column 'E'.
            Note: The stations have to be added in german only.
            Config Options
            fDestination1	'Frankfurt (Main) Hauptbahnhof'
            The final stop of the train line has to be added here! (station name)
            default value: 'Frankfurt (Main) Hauptbahnhof'
            fDestination2	'Frankfurt (Main) Flughafen Regionalbahnhof'
            default value: 'Frankfurt (Main) Flughafen Regionalbahnhof'
            note that dest 3,4,5 are marked optional, where 1 and 2 are not
            maybe doc update
              drfukc
              I am unsure if we are talking about the same thing.
              I understand you are referring to this file:
              /home/pi/MagicMirror/config/config.js
              I see the issue in this file:
              To get it to work, both files need to be edited in the current version.
                sdetweil @drfukc
                @drfukc i looked at the source for the module u described, I see your pull request…
                		fDest: 'true',
                		fDestination2: 'Frankfurt (Main) Flughafen Regionalbahnhof',
                		fDestination3: '',
                		fDestination4: '',
                		fDestination5: '',
                		lines: '', // "S1, U1,Tram 11"
                because they are in the defaults section of the code, all u have to do is set them in the config entry for this module in config.js
                that will override the defaults
                   module: "MMM-RMV",
                   position: "center",
                       		fDestination3: 'something',
                       		fDestination4: 'something else',
                       		fDestination5: 'and even more',
                  sdetweil
                  and the MMM-MRV.js code says (for example)
                  else if (trains.direction === this.config.fDestination1 || trains.direction === this.config.fDestination2 || trains.direction === this.config.fDestination3 || trains.direction === this.config.fDestination4 || trains.direction === this.config.fDestination5)
                  					if (trains.Product.catOutL == "S-Bahn" || trains.Product.catOutL == "Niederflurstraßenbahn")
                  					{	countedLinesTram = countedLinesTram + 1;	}
                  					else if (trains.Product.catOutL == "U-Bahn")
                  					{	countedLinesSub = countedLinesSub + 1;	}
                  					else if (trains.Product.catOutL == "Niederflurbus" || trains.Product.catOutL == "Bus")
                  					{	countedLinesBus = countedLinesBus + 1;	}
                  					else if (trains.Product.catOutL == "RB" || trains.Product.catOutL == "RE" || trains.Product.catOutL == "IC" || trains.Product.catOutL == "ICE" || trains.Product.catOutL == "R-Bahn" || trains.Product.catOutL == "EC")
                  					{	countedLinesTrain = countedLinesTrain + 1;	}
                  					else
                  					{	countedLines = countedLines + 1; }
                  you should not have to edit the code
                    drfukc
                    I have not edited the code, I have created a pull-request.
                    All I can see it that it is working in my environment with my proposed change but not with the default values.
                    In case other users have a similar issue, I suggest to give it a try.
                      sdetweil @drfukc
                      @drfukc said in RMV module issue (no live data):
                      well, you edited the source file, which is the same…
                      it doesn’t matter what the defaults are (what u changed)…
                      just set the values in config (as the deverloper expects you to do), and all is good…
                      your ‘’ vs the original produce the same results… it doesn’t work…
                      it was expected that you would put values in config, they override the defaults…
                        drfukc
                        if you are the author of the RMV module its perfect, if you are not the author of this module it is perfect as well.
                        However, please accept that in my case the “MMM-RMV.js” requires auditing, otherwise it will not work.
                        I would be more than pleased if all editing can be done in the “config.js”, at least in my case it does not work.
                        The default values do not seem to be overriden.
                        Any idea why?
