    Blank screen after updating tonight...
    17 Posts 5 Posters 7.7k Views 5 Watching
    • I Offline
      ines
      @sdetweil said in Blank screen after updating tonight...:
      ./node_modules/.bin/electron-rebuild
      thank you @sdetweil , the problem was solved you need to make the electron-rebuilt into mmm-assistantMk2 and mmm-hotword too
      • thedoorsfanaticT Offline
        thedoorsfanatic @sdetweil
        Sorry, I am a beginner from Germany. Maybe you can help.
        It won’t let me update because of this message:
        “Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden”
        which translates to:
        “Your local changes in the following files would be overwritten by the merge”
        and then it lists like 5 or 6 package.json files. What can I do?
        Danke/Thanks!
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          sdetweil @thedoorsfanatic
          @thedoorsfanatic you can pout those changes away temporarily with
          git stash
          after installing, if u want those back,
          git stash pop
          N thedoorsfanaticT 2 Replies Last reply Reply Quote 0
          • U Offline
            uatuba
            I got it working by removing MMM-PIR-Sensor and reinstalling it. Simply updating it did not work.
            • N Offline
              nakedrabbit @sdetweil
              @sdetweil Thanks for these leads! Now that you mention it, why would I not need to do this… I’ll let you know how it goes…
              • N Offline
                @sdetweil LIKE A CHARM. All is well with Assistant and Hotword, just as you describe. MMM-Buttons also required and npm install, as well as MMM-PIR-Sensor. So, basically, maintenance on all the plugins.
                  git stash
                  Thanks for your quick reply and your tipp that worked for me.
                  After git stash I updated MM to 2.7.1 and then I cd 'ed into every installed module and did npm install.
                  Excuse my bad English and sorry to bug you and thanks again fpr your time!
                  Noob from Germany
