    Blank screen after updating tonight...
    17 Posts 5 Posters 9.0k Views 5 Watching
      use ctrl-shift-i to open the developers window and select the console tab, scroll around to see any errors, (red text)
      also, if you updated, u generally need to re-run npm install in every module that has a package,json file.
      The Hotword and Assistant will need electron-rebuild more than likely
      • I Offline
        ines
        thank you , i make the npm install in every module with package.json but he doesn’t work
          sdetweil @ines
          @ines ok, we need to see the error… open the developers window
          how do you start MM, with PM2, or something else…
          the pm2.log might help too if used
          • I Offline
            ines
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm/snowboy.node’
            this the error that i ve faced after the new update
              sdetweil @ines
              @ines ok, you need to follow the instructions in hotword for the electron-rebuild
              But maybe in kiosk mode, you may meet some error like this;
              Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/electron-v2.0-linux-arm/snowboy.node'
              In that case, you need to rebuild some binaries to match with Electron version.
              cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
              npm install --save-dev electron-rebuild
              npm install nan
              ./node_modules/.bin/electron-rebuild   # It could takes dozens sec.
                note that you will have the same problem in Assistant too
                see
                https://forum.magicmirror.builders/topic/10189/mmm-assistantmk2-breaks-with-mm-v2-7-0
                thedoorsfanaticT N 2 Replies Last reply Reply Quote 0
                • I Offline
                  ines
                  @sdetweil said in Blank screen after updating tonight...:
                  thank you @sdetweil , the problem was solved you need to make the electron-rebuilt into mmm-assistantMk2 and mmm-hotword too
                  • thedoorsfanaticT Offline
                    thedoorsfanatic @sdetweil
                    Sorry, I am a beginner from Germany. Maybe you can help.
                    It won’t let me update because of this message:
                    “Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden”
                    which translates to:
                    “Your local changes in the following files would be overwritten by the merge”
                    and then it lists like 5 or 6 package.json files. What can I do?
                    Danke/Thanks!
                    My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
                      sdetweil @thedoorsfanatic
                      @thedoorsfanatic you can pout those changes away temporarily with
                      git stash
                      after installing, if u want those back,
                      git stash pop
                      N thedoorsfanaticT 2 Replies Last reply Reply Quote 0
                      • U Offline
                        uatuba
                        I got it working by removing MMM-PIR-Sensor and reinstalling it. Simply updating it did not work.
                        • N Offline
                          nakedrabbit @sdetweil
                          @sdetweil Thanks for these leads! Now that you mention it, why would I not need to do this… I’ll let you know how it goes…
                          • N Offline
                            @sdetweil LIKE A CHARM. All is well with Assistant and Hotword, just as you describe. MMM-Buttons also required and npm install, as well as MMM-PIR-Sensor. So, basically, maintenance on all the plugins.
                              git stash
                              Thanks for your quick reply and your tipp that worked for me.
                              After git stash I updated MM to 2.7.1 and then I cd 'ed into every installed module and did npm install.
                              Excuse my bad English and sorry to bug you and thanks again fpr your time!
                              Noob from Germany
