    MMM-Remote-Control module not showing FA icons before menu items
    4 Posts 3 Posters 2.0k Views 3 Watching
      dzsoo
      After a clean install of MagicMirror2 with no errors, i also installed the MMM-Remote-Control module which is not showing the icons before menu items. Can anyone help about this issue?
        sdetweil
        yes, some of the icons changed names… there are a couple other topics on the fa icons
        • I Offline
          ianperrin @dzsoo
          @dzsoo said in MMM-Remote-Control module not showing FA icons before menu items:
          See this post
          Because MMM-Remote-Control menus are created differently to a standard module, a change is required to the modules code in order to adopt the update to Font Awesome icons.
          There is a pull request with the fix, so please bear with @Jopyth whilst he tests the change
          "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
            dzsoo @ianperrin
            @ianperrin thank you for helping out. I followed the instructions and now the icons are showing.
