    Can I make a touch mirror?
    2 Posts 2 Posters 1.5k Views 1 Watching
    • wiresharkW Offline
      wireshark
      My mirror is round.
      Therefore, IR Touch Frame can not be used.
      In other ways, I bought a touch foil.
      It works well, but looks a twisty line in the touch area.
      I want to purchase and use a capacitive touch monitor.
      Will the touch work even if there is glass (4mm) on top of it?
      Who has solved this problem?
      • brobergB Offline
        broberg Project Sponsor
        depends on the touch film of the screen, might work, might not. If you have the the screen directly under the glass (not two way mirror glass btw, metal disrupts the field). it should be strong enough.
        What Touch foil did you buy? Never seen the lines layed out like that before (usually it’s designed as a straight line grid).
