    rpi dont wake up my screen anymore
    10 Posts 2 Posters 2.9k Views 2 Watching
      seramik
      i shut down my mirror every night with crontab :
      " poweroff"
      i 've putted a button on RUN contact to put on the rpi
      but i dont know why it dont work anymore
      my rpi dont wake up my screen automaticaly
      my rpi work welle but i need to use my old remote for put on my screen
      my screen is an TV with hdmi cable
        sdetweil @seramik
        @seramik what changed?
          seramik
          i changed my screen during a month and i upgrade mm² to last version
            sdetweil @seramik
            @seramik ah, latest version… will need to go to the MMM-PIR folder and do
            npm install electron-rebuild
            then
            ./node_modules/.bin/electron-rebuild
            to fix one of the modules MMM-PIR uses
              seramik
              i dont have PIR module,
              so no MMM-PIR folder ?
                sdetweil @seramik
                @seramik sorry, what code runs the
                that code needs to be recompiled
                  seramik
                  no codes, i use the RUN and PEN holes on the card,
                  exemple but me, i only use one button
                    sdetweil
                    ok, missed the whole thing… sorry
                    so, you power off the pi with code
                    then hit connect the RUN pin to power the PI back up
                    but the new(er) monitor doesn’t come back on?
                      seramik
                      that is right
                      the monitor is the same as before, ( just test another one during one month)
                      but before it does work( with old version)
                        seramik
                        my bad
                        @ninjabreadman said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                        @E3V3A Some monitors, but almost all television displays turn off after delay (and then cannot be woken in software).
                        i will put a relai on GPIO and it will work
                        at start( when my run button is pressed) it will shut off and shut on the monitor
                        /solved
