    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • N
      nikobelohlav
      is there a way to use a PIR sensor and the PIR module to make the PI load a black screen saver so that it looks like the screen went off but really didnt and then when the PIR sensor picks up motion the screen saver is “turned off” like it would normally do.?
      cruunnerrC 2 Replies Last reply
      • cruunnerrC
        cruunnerr @nikobelohlav
        @nikobelohlav
        yes it is.
        Just use the external script from this tutorial. Change the content of the monitor_off.sh and monitor_on.sh to the following:
        monitor_off:
        export DISPLAY=:0
        xset dpms force off
        monitor_on:
        export DISPLAY=:0
        xset dpms force on
        I will add this options to the tutorial later. ;)
        Mykle1M 1 Reply Last reply
        Reply Quote 2
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @cruunnerr
          @cruunnerr
          Those commands look familiar. :-)
            Peter
            Nice tutorial!
            Time to connect the Pir to the Pi.
            Thanks!
            Peter
            • cruunnerrC
              @nikobelohlav @ninjabreadman
              Alright, i add this option to the tutorial. Hope you enjoy :)
              If there are any suggestions on the scripts i am using please tell me. I am not a programmer so it could be, that the scripts aren’t as “clean” as they could be.
              D 1 Reply Last reply
              • OdomLinxO
                OdomLinx
                1. disable the HDMI port with
                vcgencmd display_power 0
                and enable with
                vcgencmd display_power 1
                Most monitors then go into standby. Some also show ‘NO Signal’.
                E 1 Reply Last reply
                • E
                  E3V3A @OdomLinx
                  @OdomLinx copy paste error?
                  “Everything I do (here) is for free – altruism is the way!”
                  OdomLinxO 1 Reply Last reply
                  • OdomLinxO
                    OdomLinx @E3V3A
                    @E3V3A Yes copy paste error, I adjusted it
                    • E
                      E3V3A
                      Most modern monitors also have a PowerSave function that completely turn off the monitor when there is no HDMI signal, after a set amount of time. So I guess experimentation will be needed as to what really happen after you have turned it off using either:
                      1. vcgencmd display_power 0
                      2. sudo tvservice -o
                      3. DISPLAY=:0 xset dpms force off (Notice, it’s not necessary to export!)
                      4. xset -display :0 dpms force off
                      The first 2 turn off HDMI and most likely put your monitor into PowerSave mode, eventually.
                      The last 2 only blanks the screen (visible when dark), and does not disable HDMI signals.
                      N 1 Reply Last reply
                      • N
                        ninjabreadman @E3V3A
                        @E3V3A Some monitors, but almost all television displays turn off after delay (and then cannot be woken in software).
                        That, and some folks have complained that they can’t hear a podcast or Alexa because their integrated speakers turn off when the monitor is in powersaving.
                        You’re right, it takes some experimentation to tailor to a given use case/situation depending on requirements.
                          MadScientist
                          I would like to use the MMM-PIR-sensor module to trigger the relay to power off the LCD. However, whenever I set
                          relayPIN: 27, in the config.js, the motion detector doesn’t do anything anymore. Anyone know what else I have to change in the config? It’s working just fine without the relay.
                          Config working without relay (switches off HDMI):
                                          module: 'MMM-PIR-Sensor',
                                                  sensorPIN: 22,
                                                  relayPIN: false,
                                                  powerSaving: true,
                          Not working with relay:
                                                  sensorPIN: 22,
                                                  relayPIN: 27,
                                                  relayOnState: 1,
                                                  powerSaving: true,
                          The problem is I am using a V59 LCD controller board which doesn’t power on again once the HDMI is re-activated.
                          • cruunnerrC
                            cruunnerr
                            1. Can u turn on GPIO27 with gpio -g write 27 1 and off with gpio -g write 27 0 ?
                            2. Have u tried just to connect a LED on GPIO27 ?
                            3. What relay do u use and how exactly is it connected? ?
                              MadScientist
                              Hmm, I get
                              Unable to determine hardware version. I see: Hardware   : BCM2835
                               - expecting BCM2708 or BCM2709. Please report this to projects@drogon.net
                              when I run gpio -g write 27 1 .
                              randomnoiseR 1 Reply Last reply
                              • cruunnerrC
                                cruunnerr
                                @MadScientist said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                                Huh… a quick google search tells, that this could be several causes. Some wrote to update or downgrade the kernel., some wrote to update wiring pi and so on.
                                So its not a problem of the module at all. I’m sorry but for the first u should try to google.
                                Maybe start with this: https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=182191
                                However you should start a new thread if you cannot get to target :(
                                • randomnoiseR
                                  randomnoise @MadScientist
                                  Hmm, I get
                                  I had the same issue. I just followed the instructions on the wiring pi site to install. Don’t have my notes but there was a different version depending if you use wiringpi or wiring-pi. I’ll see if I can find the right one.
                                  • randomnoiseR
                                    randomnoise
                                    So I think as wiring-pi is the npm specific version the reason it didn’t work was because they haven’t compiled it to work with the pi3 chip.
                                    Try http://wiringpi.com/download-and-install/
                                      MadScientist
                                      Thanks so far. I did npm uninstall wiring-pi and installed wiringpi via git. Now I don’t get the error anymore but the relay still does nothing. It’s getting late and won’t have the time today anymore to look into it. Let me know if you have other ideas and I will continue tomorrow.
                                      Thanks so far.
                                      • randomnoiseR
                                        randomnoise
                                        I think I kept the npm wiring-pi on there as well… There’s probably some other stuff in there that makes it work in mm.
                                        • cruunnerrC
                                          cruunnerr
                                          U could also quick try the script from this tutorial (at point 5). It will be done in 2 minutes ^^
                                          Maybe u missed the connection?
                                            MadScientist
                                            Two minutes if you know what you’re doing…
                                            The problem is I don’t have a button. I did create the relay.py script and run it. It triggers the relay exactly once and then stays like this. I can’t even stop the script anymore once it’s running…
                                            Man, I really thought setting up the relay would be as easy as adding one line to the config. Wish I had tried to set it up earlier.
                                            Still need help with this. :-(
                                            • 1 / 9
