    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • cruunnerrC
      cruunnerr @nikobelohlav
      @nikobelohlav
      yes it is.
      Just use the external script from this tutorial. Change the content of the monitor_off.sh and monitor_on.sh to the following:
      monitor_off:
      export DISPLAY=:0
      xset dpms force off
      monitor_on:
      export DISPLAY=:0
      xset dpms force on
      I will add this options to the tutorial later. ;)
      Mykle1M 1 Reply Last reply
      Reply Quote 2
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @cruunnerr
        @cruunnerr
        Those commands look familiar. :-)
          Peter
          Nice tutorial!
          Time to connect the Pir to the Pi.
          Thanks!
          Peter
          • cruunnerrC
            @nikobelohlav @ninjabreadman
            Alright, i add this option to the tutorial. Hope you enjoy :)
            If there are any suggestions on the scripts i am using please tell me. I am not a programmer so it could be, that the scripts aren’t as “clean” as they could be.
            D 1 Reply Last reply
            • OdomLinxO
              OdomLinx
              1. disable the HDMI port with
              vcgencmd display_power 0
              and enable with
              vcgencmd display_power 1
              Most monitors then go into standby. Some also show ‘NO Signal’.
              E 1 Reply Last reply
              • E
                E3V3A @OdomLinx
                @OdomLinx copy paste error?
                “Everything I do (here) is for free – altruism is the way!”
                OdomLinxO 1 Reply Last reply
                • OdomLinxO
                  OdomLinx @E3V3A
                  @E3V3A Yes copy paste error, I adjusted it
                  • E
                    E3V3A
                    Most modern monitors also have a PowerSave function that completely turn off the monitor when there is no HDMI signal, after a set amount of time. So I guess experimentation will be needed as to what really happen after you have turned it off using either:
                    1. vcgencmd display_power 0
                    2. sudo tvservice -o
                    3. DISPLAY=:0 xset dpms force off (Notice, it’s not necessary to export!)
                    4. xset -display :0 dpms force off
                    The first 2 turn off HDMI and most likely put your monitor into PowerSave mode, eventually.
                    The last 2 only blanks the screen (visible when dark), and does not disable HDMI signals.
                    N 1 Reply Last reply
                    • N
                      ninjabreadman @E3V3A
                      @E3V3A Some monitors, but almost all television displays turn off after delay (and then cannot be woken in software).
                      That, and some folks have complained that they can’t hear a podcast or Alexa because their integrated speakers turn off when the monitor is in powersaving.
                      You’re right, it takes some experimentation to tailor to a given use case/situation depending on requirements.
                        MadScientist
                        I would like to use the MMM-PIR-sensor module to trigger the relay to power off the LCD. However, whenever I set
                        relayPIN: 27, in the config.js, the motion detector doesn’t do anything anymore. Anyone know what else I have to change in the config? It’s working just fine without the relay.
                        Config working without relay (switches off HDMI):
                                        module: 'MMM-PIR-Sensor',
                                                sensorPIN: 22,
                                                relayPIN: false,
                                                powerSaving: true,
                        Not working with relay:
                                                sensorPIN: 22,
                                                relayPIN: 27,
                                                relayOnState: 1,
                                                powerSaving: true,
                        The problem is I am using a V59 LCD controller board which doesn’t power on again once the HDMI is re-activated.
                        • cruunnerrC
                          cruunnerr
                          1. Can u turn on GPIO27 with gpio -g write 27 1 and off with gpio -g write 27 0 ?
                          2. Have u tried just to connect a LED on GPIO27 ?
                          3. What relay do u use and how exactly is it connected? ?
                            MadScientist
                            Hmm, I get
                            Unable to determine hardware version. I see: Hardware   : BCM2835
                             - expecting BCM2708 or BCM2709. Please report this to projects@drogon.net
                            when I run gpio -g write 27 1 .
                            randomnoiseR 1 Reply Last reply
                            • cruunnerrC
                              cruunnerr
                              @MadScientist said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                              Huh… a quick google search tells, that this could be several causes. Some wrote to update or downgrade the kernel., some wrote to update wiring pi and so on.
                              So its not a problem of the module at all. I’m sorry but for the first u should try to google.
                              Maybe start with this: https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=182191
                              However you should start a new thread if you cannot get to target :(
                              • randomnoiseR
                                randomnoise @MadScientist
                                Hmm, I get
                                I had the same issue. I just followed the instructions on the wiring pi site to install. Don’t have my notes but there was a different version depending if you use wiringpi or wiring-pi. I’ll see if I can find the right one.
                                • randomnoiseR
                                  randomnoise
                                  So I think as wiring-pi is the npm specific version the reason it didn’t work was because they haven’t compiled it to work with the pi3 chip.
                                  Try http://wiringpi.com/download-and-install/
                                    MadScientist
                                    Thanks so far. I did npm uninstall wiring-pi and installed wiringpi via git. Now I don’t get the error anymore but the relay still does nothing. It’s getting late and won’t have the time today anymore to look into it. Let me know if you have other ideas and I will continue tomorrow.
                                    Thanks so far.
                                    • randomnoiseR
                                      randomnoise
                                      I think I kept the npm wiring-pi on there as well… There’s probably some other stuff in there that makes it work in mm.
                                      • cruunnerrC
                                        cruunnerr
                                        U could also quick try the script from this tutorial (at point 5). It will be done in 2 minutes ^^
                                        Maybe u missed the connection?
                                          MadScientist
                                          Two minutes if you know what you’re doing…
                                          The problem is I don’t have a button. I did create the relay.py script and run it. It triggers the relay exactly once and then stays like this. I can’t even stop the script anymore once it’s running…
                                          Man, I really thought setting up the relay would be as easy as adding one line to the config. Wish I had tried to set it up earlier.
                                          Still need help with this. :-(
                                          • cruunnerrC
                                            cruunnerr
                                            Ah I see…
                                            I will write u this evening. We will get it working ;)
                                            • 1 / 9
