    Default calender change Header position
    6 Posts 2 Posters 2.0k Views 2 Watching
      Scool
      Hey guys,
      i’m completly new in this world, but the possibilities are great.
      The modul default calendar is set with “top-right”, now the header is also at the right side of the modul.
      I search the .css and the calendar.js, but i couldn’t find the possibility to set header “margin:left” oder “float:left” wthatever.
      is would be very nice, if somebody could help me ;-)
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "MMM-DigClock",
      			position: "top_right",	// This can be any of the regions.
      				showDate: true,
      				showWeek: false,
      				showSeconds: false,
      				dateFormat: "ddd, ll",
      				timezone: "Europe/Berlin"
      			module: "weatherforecast",
      			header: "WIE WIRD DAS WETTER?",
      				locationID: "yyyyyyy",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "xxxxxxxx"
      			header: "Termine xxxxxxxx",
      				timeFormat: "absolute",
      				maximumEntries: "5",
      				maximumNumberOfDays: "365",
      				getRelative: 48,
      						symbol: "calendar-check",
      						url: "webcal://xxxxxxxxxxxxx"
      			module: "MMM-EasyPix",
      					picName: "vp_2.png", // Enter the picture file name.
      					maxWidth: "33%",        // Size picture precisely. Retains aspect ratio.
      					sounds: ["1.mp3", "me2.mp3"],  // mp3 sound file names in quotes seperated by commas for Hello-Lucy
      					updateInterval: 30 * 60 * 1000,     // updates display
      					animationSpeed: 3000,
      				position: "top_center",
      					maxWidth: "66%",        // Size picture precisely. Retains aspect ratio.
      			module: "MMM-EARTH",
      			position: "bottom_right",
      				mode: "Natural",
      				rotateInterval: 15000,
      				MaxWidth: "35%",
      				MaxHeight: "35%",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Tagesschau",
      						url: "http://www.tagesschau.de/xml/rss2"
      						title: "Der Spiegel",
      						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss"
      				showSourceTitle: true,
      				showPublishDate: true
        dxfan227
        Try
        div.module.calendar header {
        if that doesnt work, give me a few hours to get home and actually look at my custom.css file
          Scool
          where should i write this code?
          custom.css??
          actually she look like this (with your Command):
           body {
            dxfan227
            ill get you the full code in a few hours…yes in custome css but you will also need to alight the text properly too.
              dxfan227
              sorry here was s the css code
              .calendar header {
               	text-align: center // Change this to whatever you want....right,center or left
                Scool
                Thank you!
                i’ll try and give you feedback!
