    How to change the path of a picture in magicmirror , using MMM-imageSlideshow
    17 Posts 2 Posters 6.3k Views 2 Watching
    • E Offline
      emrhssla @sdetweil
      not about path update
      about replacing a picture with an overwritten one dynamically.
        sdetweil @emrhssla
        @emrhssla should be able to without problem… either write code to do it… or launch a shell cp command (copy)
          sdetweil
          also, MMM-ImageSlideshow only gets the file list once… then reshows it over and over…
          MMM-ImagesPhotos refreshes the list every 60 seconds… ( getInterval: 60000)
          • E Offline
            emrhssla
            MMM-Testpython.js
            var Testpythons;
            Module.register("MMM-Testpython", {
                defaults: {},
                start: function (){
                    Testpythons = this;
              getDom: function() {
                var element = document.createElement("div")
                element.className = "myContent"
                element.id="divid"
                element.innerHTML = "Hello, World!!! " + this.config.foo
                var subElement = document.createElement("p")
                subElement.innerHTML = "Click"
                subElement.id = "clickid"
                element.appendChild(subElement)
                return element
              notificationReceived: function(notification, payload, sender) {
                switch(notification) {
                  case "DOM_OBJECTS_CREATED":
                  var elem = document.getElementById("clickid")
                  elem.addEventListener("click", () => {
                    Testpythons.sendSocketNotification("TEST")
                    console.log(" click success !")
                    elem.innerHTML = "click success"
                    break
                  case "AFTERCLICK":
                    console.log("Socket recevied payload : "+payload)
                    var elemk = document.getElementById("clickid")
                    Testpythons.sendNotification('SHOWCHANGEDIMAGE');
                    elemk.innerHTML = payload
                    break
            node_helper.js(in MMM-Testpython)
            var NodeHelper = require("node_helper");
            var {PythonShell} = require('python-shell');
            var socketTestpython;
              start: function() {
                socketTestpython=this;
                console.log(this.name+"node_helper started")
                  case "TEST":
                    console.log("notification : " + notification)
            	    PythonShell.run('/home/pi/Desktop/BeautyMirror/modules/MMM-Testpython/before.py', null, function (err, result) {
                        if (err) throw err;
                        console.log(result);
                        socketTestpython.sendSocketNotification("AFTERCLICK",result);
                    break
            MMM-ImageSlideshow.js
            I added only the following code from the original module code.
            notificationReceived: function(notification, payload) {
            		Log.info(this.name + " - received notification: " + notification);
            		if(notification === "DOM_OBJECTS_CREATED"){
            			this.hide()
            		if(notification === "SHOWCHANGEDIMAGE"){
            			var self = this;
            			self.updateDom();
            			self.show();
            console is success…
            image before capture
            capture image
            after caputure
            • E Offline
              emrhssla @emrhssla
              not changed in screen omg…
                sdetweil @emrhssla
                @emrhssla if u stop mirror and restart, does the new image appear? (as u overlaid the old one)…
                if not, then your overlay function doesn’t work…
                  sdetweil
                  and another test, open a browser on mm, then use the full file url to the new image file
                  file:///home/pi/MagicMirror/modules/MMM-ImageSlideshow/…
                  and see if the pic opens
                  • E Offline
                    emrhssla @sdetweil
                    Clicking makes the capture and overwrite the file successful in the process where the magic mirror is run. But it doesn’t appear on the screen.
                    When the magic mirror is turned off and restarted, a new image will appear successfully.
                    I think the code is working properly, but the MMM-imageSlideshow module is not being renewed.
                    • E Offline
                      emrhssla @sdetweil
                      Are you saying to run chrome and put fil://~ in url?
                        sdetweil @emrhssla
                        @emrhssla yes, just adding another way to verify that the file was changed… u reported it is ok…
